03-01-2021, 04:15 AM | #3939 | |
Rep 1,048
Kri |
03-01-2021, 06:47 PM | #3941 |
Rep 5
03-03-2021, 08:23 AM | #3942 |
Rep 8
Thank you for the files. I see that in the PX6 folder, there is only one folder for MCU. Is that only compatible with Android 8.1 or it can also work with Android 9?
03-13-2021, 09:31 AM | #3943 |
Rep 7
UPDATE: mine was an unlucky one and I had to wire into the 12V reverse light and ground. The camera only worked when the ground was on the same circuit as the rear lights.
03-13-2021, 04:47 PM | #3944 |
Rep 4
Hello guys
already installed a SD625 unit on my e82 and are awesome but have a issue when play audio on zlink app over spotify , when play music sometimes music skip a bit like a cd scratched and continue playing , this same issue happens with apple music and already tested my phone with library downloaded and playing over streaming and issue are same , tested on another unit with wired carplay and issue are inexistent , any have this same issue ? |
03-15-2021, 01:06 AM | #3945 | |
Rep 6
I suppose they could be feeding it higher voltage at lower current, but that seems out of spec. I’m working on upgrading my 8.8 to 10.25. I got the same brand/series panel, but in 10.25. All specs are the same except for backlight. 10.25” calls for 29-30v~ @ 250ma. Think I’ll just have to source my own external driver rather than trying to figure out WTF they’re doing on these units. |
03-15-2021, 03:25 PM | #3946 |
Rep 16
Current setup: 2014 F10, NBT
I have made the decision to get Apple CarPlay to extend my enjoyment of the car for another few years! Both options below also support Android auto. After much research, I have two options and I need your help in deciding: 1. Andream MMI box ($249) Link 1009798 Pros: Everything remains OEM on the surface. less things that might break since it is only a box. Several generations already. Cons: No touchscreen (drive controls) Note: this goes by several other names, details here 2. Andream 10.25" Touch screen ($289) Link 1009799 Pros: Larger screen than OEM. touchscreen. Cons: Reliability (eg resistance to heat). Fit and finish quality. First generation product. Does not dim at night. Note: this is the one without an entire android OS. Thoughts? experience with any of these? |
03-18-2021, 02:59 PM | #3947 | |
Rep 47
Hello again! I have a problem and I do not know how to solve it, these days and I tried to move google to the internal apps in the way that it says here in the forum, (through ADB) but it always gives me an error, it tells me that it cannot find the priv-app folder (and exists 100%). leaving me the folder in the device directory! and it won't let me delete it ... who could tell me what's going on? and what is failing? thanks to all! |
03-18-2021, 07:57 PM | #3949 | |
Rep 2,366
Drives: E63 645Ci
03-21-2021, 02:51 PM | #3950 |
Rep 3
Can anyone help me
I installed my headunit a few back (10.25 android 9 andream px6) and GPS is a bit slow and the sound is for the navigation is only coming from one speaker on the left for it any tips or tricks Any recommendations on downloads or apps Everything else is working fine Thanks |
03-25-2021, 07:15 AM | #3951 | |
Rep 1
After adb commands new settings do not persist after reboot. Please advice. Thank you |
03-30-2021, 10:58 AM | #3952 |
Rep 2
Hey Guys,
I've recently installed the 10.25 android 9 HU, but I'm getting some rattling sound when travelling through rough road or yellow line. When I hold on to the HU the rattling sound is not there. I've tighten the bracket screw but it doesn't seems to get rid of the rattling. Is anyone facing the same issue? |
03-30-2021, 11:03 AM | #3953 | |
Rep 2,366
Drives: E63 645Ci
LittleSamurai4.50 |
03-30-2021, 03:25 PM | #3954 |
Rep 592
03-31-2021, 10:37 AM | #3955 |
Rep 2
03-31-2021, 11:28 AM | #3956 | |
Rep 2,366
Drives: E63 645Ci
04-02-2021, 04:01 AM | #3957 |
Rep 4
https://mega.nz/folder/NNxk0Z6S#876H.../file/cNZHQQCa
dGS-CIC-GTL-210126.zip looks like it is broken, can someone upload it again ? (EDIT) Now Works Thank You!!!! Last edited by rodriguezstyle; 04-02-2021 at 04:27 AM.. |
04-02-2021, 05:30 AM | #3958 | |
Rep 6
Hi Kri, I have DroidUK 10.25" snapdragon unit with Ksw-Q-Userdebug_OS_v2.7.9 firmware. I don't have root option on the device. How can I install your Google zoom with tasker project? Also, I am interested to get your Google voice as currently it is not functioning from my steering wheel "voice" button. Please advice how-to do these two. Thanks in advance. Nabidur |
04-11-2021, 11:08 AM | #3960 |
Rep 5
******ion bluetooth problem
hello
Last weekend i did a firmware update to 2.5.3 on my HU Android but the bluetooth is not working now. I can connect my phone by BT but 1 or 2 second later the phone is disconnected. I tried to install and older firmware but same problem. Could you help me ? what can i do? Thank You!! |
