BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Suspension | Chassis | Brakes > M3/M4 brake conversion for all F3*
proTUNING Freaks
      02-06-2021, 06:43 AM   #1
Belong
Drives: E60 m5, F81, m550d
Hi guys
New to the forum here...
Im selling brackets for the front and the rear for the F3* platform to succesfully use the M3/M4 380mm front discs and rear 370ers discs on the f3* platform.
1 series and 2 series also available but will only go in the front, since the rear have a 160mm handbrake ( with which this conversion wont work.
You can contact me on instagram: EstorilV10
Im also doing custom Big Brake kits for lots of other cars as well..
I have adapters for the 340mm Msport BRembo calipers to 380 m3/m4
as well as adapters for the 370mm MPerformance calipers to 380 m3/m4 discs
and for the rears to use the 370 mm M3/M4 rears discs
Rears will only work if you have the larger 18.5cm handbrake.
ill try to update this post soon with some pics , if there are people interested..
      02-06-2021, 03:34 PM   #2
SantaEugence
Drives: F30 330d xDrive Auto
Originally Posted by Belong View Post
Hi guys
I have adapters for the 340mm BRembo calipers to 380 m3/m4
as well as adapters for the 370mm calipers to 380 m3/m4 discs
Ill post pics here if people are interested ( just need to find out which pic hosting progr )
In the meantime you can have a look on instagram on my F81 Touring project
:EstorilV10
Sorry for the ignorance but how would I know if I have the larger 18.5cm handbrake? I have the usual blue M Sport Plus brakes...
      02-07-2021, 03:48 AM   #3
Belong
If you fill in the last 7 digits of your VIN on realoem.com
go into the brake parts menu
it shows you in the handbrakeparts submenu which one you have ...
it shows with a D: 16 or a D:18.5 ( D - Diameter )
      02-07-2021, 08:30 AM   #4
SantaEugence
Ah you're talking about the brake disc dust shield being either 16cm or 18.5cm, gotcha
      02-07-2021, 09:02 AM   #5
Belong
No im not!
      02-07-2021, 12:03 PM   #6
SantaEugence
No im not!
Sorry not the dust shield, the supporting ring inside, number 6 in this diagram? Didn't realise they came in different sizes.
Have you got a picture of these brackets? How have they been made/designed/tested?
      02-07-2021, 01:04 PM   #7
Belong
Correct, over 90 sets sold already.. proven good to up to 640BHP on a driftcar, and yes theyre very quality made.. no backyard tuning crap
      02-27-2021, 10:08 PM   #8
2liver2life
Drives: 2017 430ix
Are you shipping to the US?
      03-03-2021, 06:23 PM   #9
Belong
I could.....
      03-04-2021, 01:33 PM   #10
SantaEugence
Are these the same ones that required part of the rear caliper body to be trimmed away...
      03-11-2021, 06:08 PM   #11
Belong
there is no other option then that.... and its just a tiny bit to make room for the bolt..
      03-11-2021, 06:09 PM   #12
Belong
      03-11-2021, 06:22 PM   #13
jackstrath
Scotland
659
Drives: 16' F31 340i & 03' Focus RS
Whats happened to your other threads?
      03-11-2021, 10:01 PM   #14
Logicoeur
Logicoeur's Avatar
991
Drives: F30 335i xDrive
Photos of the trimming?
      03-12-2021, 03:00 AM   #15
Belong
I deleted my "project topic" 3 replies... so isnt worth to keep updated
you can follow me on instagram : EstorilV10
      03-14-2021, 03:18 PM   #16
1QuikWS6
No 55mph
1QuikWS6's Avatar
1621
Drives: F32 435ix MSport
Do these adapters work on xdrive?
      03-14-2021, 07:19 PM   #17
Belong
No difference in RWD or Xdrive... Xdrive always have bigger rear handbrake - 18.5cm so rear conversion will also work..
1QuikWS61620.50
      12-17-2021, 02:10 PM   #18
Kamigouki
Drives: 2017 BMW 340i xdrive
Hi guys
Do you have any pics from the back with your bracket installed? Why is no one doing this mod, it seems amazing and functional?
      12-22-2021, 03:54 AM   #19
Belong
Why is no one doing this mod... i think over the last years weve sold over 100 sets.. the only downthing about this setup is money.. M3 rotors are alot better then the crappy mperformance or Msport ones and yes they cost a lot more.. And they look 3259329532952379752 times better.
      01-25-2022, 11:59 AM   #20
MikeeM
Drives: BMW F32 430d 190kw
Hi, I have the front brakes from the M4 at home and I'm wondering if it is worth for me to put it on the F32 430d. How much would cost the front brackets stand alone?
Thanks
      01-25-2022, 08:06 PM   #21
Logicoeur
Logicoeur's Avatar
991
Well it's very likely because 10mm is not a big difference for this car. The same calipers bolt on, without any additional bracket (that also requires shaving the upright), with readily available 370mm rotors. It's almost a no brainer. If someone is really that interested in their brakes they will go after a GT kit, Ap Racing, etc.
      01-27-2022, 09:01 AM   #22
Boostedphil698
Boostedphil698's Avatar
Drives: 2015 BMW 435i Xdrive MSport
2015 BMW 435XI  [0.00]
2009 Honda Civic  [0.00]
Would have been easier to just bolt on the M Performance BBK designed for our cars. The kit uses the same calipers as the F8X cars. Just my 2 cents.
2015 435i Xdrive (Klaus)
Stanced 8th Gen Honda Civic (The daily)
