01-27-2019, 08:54 PM | #1 |
Rep 34
Rough idle/misfire: fixed by unplugging MAF sensor?!?!
My 435i has a rough idle and misfire which I can’t seem to fix. Today I made an interesting discovery for which I seek this group’s input. The idle smoothes out if I simply unplug the MAF sensor! I’ve been driving with MAF unplugged for a day now and if I didn’t know better I’d call this totally fixed. Any ideas what I should try next? Here is a video demonstration of the symptom, and the “fix”
https://www.dropbox.com/s/afzt8ihjsu...%20PM.mov?dl=0 Quick history: car has 85K miles and was running perfect but leaking oil (of course!). So I spent 2 days doing all the engine maintenance: new valve cover and gaskets; new spark plugs; new oil filter housing gaskets and fasteners; new serpentine belt; walnut blasted intake valves. Upon finishing all that work, engine fired right up. But this rough idle started happening right away. Using ISTA-D, I have “reset adaptations” a couple times. I also pulled the plugs and checked the gap. Getting error codes 140010, 140002, 140102, etc in ISTA. |
02-02-2019, 10:25 AM | #7 |
Rep 270
have you tried cleaning the MAF?
2013 328i xDrive | M Performance Exhaust | Injen Intake | DEPO Headlights |
2019 440i xDrive | Muffler Delete | |
02-02-2019, 12:26 PM | #8 |
Boost Addict
334
Rep 349
Hmmm can be a "vacuum" leak with the valve cover project.
The turbo maybe pulling air other than from the MAF, causing issues. Check all the intake connections to the Valve Cover, like the PCV system. Your car is made to incorporate MAF readings in its calculations. Also check the entire intake system since you also did a walnut blast, there maybe leaks there too.
S55 M2C | Three Pedal Club | E30TU
Rebound152.50 |
02-03-2019, 12:21 AM | #9 |
Rep 1,117
Drives: 2015 BMW M235i
how were the intake valves after 85k and on what oil and interval? Just curious because I thought this was mostly an n54 issue
02-03-2019, 06:53 AM | #10 |
Rep 66
I'm interested in hearing about the intake valves state at 85k on an n55. Any pics from the overhaul?
15 Estoril/Coral 435i coupe M-sport
96 Estoril/M-Cross M3 coupe 85 Delphin/Comfort 318i coupe |
02-03-2019, 08:59 AM | #11 |
Rep 230
Q: how did the internals look when you opened it? Any rust on VANOS?
You mentioned you replaced the cover. Why? Any chance new cover is defective and leaks air in PCV system? Last edited by F30ed; 02-03-2019 at 03:16 PM.. |
02-03-2019, 03:36 PM | #12 |
Luxury at the redline :)
9105
Rep 7,563
02-03-2019, 07:34 PM | #13 |
Rep 2,357
msquaredF33
I have been driving with the MAF unlugged for the last four years. As stated above I also started doing this with JB4 and now that the JB4 is retired I continue with MHD where I have had my tuner program the MAF out. When the MAF signal is gone the DME default to Alpha N (I believe). Which does not care about your intake. Win-win
(A Dane in China) Last edited by harkes; 02-03-2019 at 07:42 PM.. |
02-03-2019, 07:40 PM | #14 |
Rep 2,357
This is simply not correct. The CEL is exactly what it is an abbreviation for Check Engine (Light). Something is wrong - usually minor stuff or a temporary hiccup. Car will usually continue to drive like normal.
(A Dane in China) Last edited by harkes; 02-03-2019 at 07:50 PM.. |
02-04-2019, 07:31 PM | #16 | |
Rep 34
02-04-2019, 07:41 PM | #17 | |
Rep 34
Before After |
02-04-2019, 08:16 PM | #18 | |
Rep 34
I suppose there is a possibility the new cover is defective. I’d not considered that. Thanks for the idea, will explore this one. |
02-05-2019, 08:31 AM | #20 |
Rep 230
msquaredF33, another idea - since you removed/installed intake manifold, air leak can be somewhere in that area, anywhere after MAF sensor. Misfire can be due to lean mixture at low RPM, fuel/air ratio is so low that it can not ignite sometimes. When the engine warms up, fuel injection at idle drops to minimum, that is when it becomes very sensitive to any air leaks. Again, just an idea...
juliomadara721.00 |
05-31-2019, 10:24 PM | #21 |
Rep 55
Hey @msquaredF33 did you figure out or resolve your issue?
I’m having the same thing happen to me after I replaced the oil cooler/oil filter housing gaskets. I did have to move intake manifold back to get to gain access to one of the oil filter housing bolts (as is the case with anyone who does this job). After putting everything back together it fired right up and ran perfectly for 5 mins. I turned it off for an hour or so. Then when I started it back up rough idle and CEL occurred. So if you fixed your issue I’d REALLY like to know what the fix was. Thanks man! |
mcintoshf30184.00 |
05-31-2019, 11:26 PM | #22 | |
Rep 55
