06-17-2019, 10:09 PM | #1 |
Rep 296
Drives: 2024 M2
Speed Limit Information SLI Emulator BMW F30 F31 F32 F36 Retrofit USA Stock
peed Limit Information Emulator for BMW F series NBT with LCD Dashboard display Retrofit This Emulator use display limit data embedded in navigation map on cluster or head up display (if car has HUD). Please make sure that BMW map for your area are contain speed limit information (SLI) Not plug and play, coding is required after installation. USA STOCK You can get it very fast!! coding thread: https://f30.bimmerpost.com/forums/sh....php?t=1541914 buy link: https://www.ebay.com/itm/173859567326 |
06-30-2019, 02:55 PM | #2 |
Rep 296
Drives: 2024 M2
bump
07-05-2019, 11:37 AM | #3 |
No 55mph
1621
Rep 8,476
I assume this unit will only display km/h text as the units instead of mph?
07-05-2019, 11:49 AM | #4 |
Rep 296
Drives: 2024 M2
07-05-2019, 11:54 AM | #5 |
No 55mph
1621
Rep 8,476
I understand that the actual digits can be displayed in mph & be correct - I mean the text after and/or under the digits
That was the issue with these from the start - company selling on ebay actually said they finally had one that would display mph text, but then took it down off ebay after the 1st customers returned cause it didn't work Haven't seen one since then If you can show me a screen where the text is 'mph' then I'd be interested I know it's a little thing but I don't want to see metric on my dash or HUD
sxmarsha7.50 |
08-19-2019, 09:17 AM | #6 | |
Rep 724
08-19-2019, 09:46 AM | #7 | |
No 55mph
1621
Rep 8,476
sxmarsha7.50 |
01-09-2020, 03:00 AM | #8 |
Rep 26
This is genuinely my first post ever on a forum! I've used them for years for yeilding information from you cleaver people however never actually posted! So now its time for me to pay back what I've learned!
I spent days working out all the information on how to get SLI, it turns out I don't have the correct camera and only have the HBA camera! Suck right? Then I found this retrofit! Great, yay! ummmmm no maybe not! KMP/h umm no thanks! That sucks! Anyway, last night at 1:30 AM with work the next day I gave up realizing I thought I would never have SLI, well I found this! Won't let me post the link. Bmw custom retrofit . Com All one word. And search for BMW KAFAS 1/2 - Speed Limit Info Activator Which yes is more expensive but as proven in this post below, it works in MPH! https://f30.bimmerpost.com/forums/sh....php?t=1678986 Well, I have just ordered it and I'll let you know how it goes, but in short, it is possible to get MPH on the SLI retrofit emulator. |
1QuikWS61620.50 |
01-20-2020, 05:07 PM | #9 |
Rep 26
So I finally got my SLA Adapter,
Installed it with taps into the back of the Cluster and coded it, didn't work. was raging.... Cutting a long story short, the wiretaps were shit. So I cut the CANH, CANL, +12v, and ground, soldered the emulator into the lines, silicone and heatsinked them, followed by using wire harness strapping, then 3M the emulator onto the back of the cluster. Looks a pro job, you'd never know its aftermarket and works great! MPH FTW.
Did my post help? Click "Appreciate!" Automotive Electronics | Coding | ECU | Automotive Paint Works | F30 | E46 | E91 | E87 |
