09-04-2016, 02:48 AM | #1 |
Rep 320
Intermediate oil change?
Morning Chaps,
I've never subscribed to the 2 year service intervals on my cars & prefer to at least have an annual oil change. I've just bought a 65 plate 320d M Sport with 7k miles on it & have been thinking of putting it in for an oil change in between services. My first service is due next July, in 12k miles according to the on board computer. Chances are I'll keep this car for a few years. What do people think? Is it common place to conduct an intermediate oil change? Cheers, Col |
09-04-2016, 02:56 AM | #2 |
Rep 1,201
I do this, every 9k she gets new oil. oil is good these days so their I'm sure there is no real need to do it but it doesn't cost a lot and helps me sleep better:
MashinBenzin8453.00 |
09-04-2016, 02:57 AM | #3 |
Rep 3,216
I do it. My background is in oil longevity (I used to work for one of the majors, at a large facility in Runcorn), so I know just how knackered oil is after 15-18k miles.
It all depends on how long you intend to keep the car. If, like lots on here you're on a PCP or intend to get rid after 2-3 years, then it doesn't matter. When something goes wrong, it'll be someone else's problem. If, on the other hand, you like to keep your cars for a long time, then doing additional oil changes makes a lot of sense. My on-board systems seem to go with an oil change every 18k miles. So I get an intermediate done at the 9k point, but tell the dealership NOT to reset the service indicator at those changes, but I DO want them to update the onboard service record. As a guide, my local dealership charges £160 for oil and filter change. Oil changes are cheap. Engines are expensive. |
09-04-2016, 09:09 AM | #5 | |
Rep 15,858
Part of my reasoning is the type of use, low annual mileage and short trips of ~25 miles a time from cold. Regular longer trips, I wouldn't be so concerned. The other reason, BMW engines are not 100% reliable for timing chain and guide issues. Opinion is divided on whether long oil service intervals are partly to blame, better safe than sorry if we intend to run the car long term. |
09-04-2016, 09:14 AM | #6 |
Rep 1,643
Drives: 2020 Audi SQ7 & 2019 AM DB11
Location: The Democratic Peoples Republic Of South East England
I'm going to do an oil change at 12 months will I should be on approx 8k.
I will just use a BMW specialist and supply them the parts and not change the computer. |
09-04-2016, 09:16 AM | #7 | |
Rep 8,780
I might consider doing the same, as my car will probably be kept for a few years and will do a lot of very short runs <10 miles mixed with 100 mile runs.
Drives - 2020 LR Discovery HSE-L Previous - 2019 LR Discovery HSE-L // 2016 F36 440i // 2009 E90 320D SE |
09-04-2016, 09:35 AM | #8 | |
Rep 15,858
I believe the interim oil service has delayed the mileage countdown a small amount, maybe a 1,000 miles or so. But won't affect the next oil service as it will be timed out, rather than a mileage issue. |
09-04-2016, 01:18 PM | #10 | |
Rep 8,780
I think I will do just the same. My 320D had the timing chain replaced under warranty at 95k miles and, whilst I know the N47 has a flaw in that respect, I do wonder if it would have been fine without having gone 22k between oil changes.
09-04-2016, 07:20 PM | #11 |
Fool
1857
Rep 3,542
I tried the same, they said they couldn't update the service record without resetting the counters. They apparently did the change (and billed me for it) but there's nothing on my idrive to tell me such, I just have a piece of paper.
09-04-2016, 08:23 PM | #12 |
Rep 4
Oil and filter changed at 2,250m DIY...not running a new car for 18,000m on original oil...no chance. I'll do another around 7,250m. That will take me close to the first dealer service to maintain warranty... 2 years.
6 litres of Fuchs GT1 0w-20 ACEA A1/B1 Longlife -14FE+ and a genuine BMW filter 11 42 8 583 898 from stealers.
One should treat others as one would like others to treat oneself.
09-04-2016, 11:42 PM | #13 |
Rep 699
I don't subscribe to these mid service oil changes. If they were needed the manufacturer wouldn't hesitate to recommend them and I'm sure the dealer would appreciate the additional income. I wonder if premature engine wear is happening because the engine will be run without oil pressure for a few seconds at each change.
This weekend I have traded my 130k 320d which has suffered no engine problems and in fact hasn't even used any oil at all. My service intervals were al 19 or 20k. |
09-05-2016, 01:46 AM | #16 | |
Rep 3,216
15-18k mile oil is pretty well knackered. Lubricating properties largely gone. Mostly broken down on a molecular level. Acidic contaminant neutralisers used up. Quite simply, the fleet market wanted longer service intervals for cheaper lease costs. They generally get rid of their cars at 3 yrs old. The balance point in terms of risk of failure / cost of servicing has been calculated out. Most of those reported N47 timing chain problems are down to a lack of lubrication, in one way or another. Take out the ones where negligent owners have let the oil level drop, and what you find are worn out oils failing to lubricate the timing chain, and/or the oil spray nozzles to the timing chain becoming blocked by suspended general crud, due to the suspension agents in the oils being used up. In either type of case, the chain isn't getting lubricated, and stretches, jumps or snaps. |
MashinBenzin8453.00 Kal1013105.00 |
09-05-2016, 03:13 AM | #17 | |
Rep 8,780
When I bought my E90 320D, I was completely unconvinced by the long service intervals, but let them run as I always intended extending the warranty (I was aware of the N47 timing chain problem). The 'plan' worked as the dealer picked up on the timing chain rattling during a routine visit (I hadn't noticed at that point and perhaps the car could have carried on for some time without popping). As you have highlighted, it's not necessarily low oil levels that cause a problem. I always kept mine topped up and it used very little between services - I think I bought 2 or 3 litres over the years. So it was full - but only with life-expired oil for perhaps 50% of the time
09-05-2016, 03:21 AM | #18 | |
Rep 1,858
my independent carried out an interim oil change for me and updated the online bmw service record for me and left the counters untouched. the car didn't show the extra oil service on the car e-service log until I had the dealer service carried out at 17k miles tho |
09-05-2016, 03:31 AM | #19 | |
Rep 15,858
Use does make a lot of difference and diesel engines with DPF regeneration can add to the problem with oil dilution. The comment that you say it never used oil, is an unknown, if you don't have the old oil analysed. Engine can use oil and still not drop on the dipstick. Oil dilution with diesel fuel, is masking oil consumption in some diesel engines. Users being oblivious to what's going on inside the engine. Even the latest petrol DI engines are putting more carbon into the oil, it's one reason I've opted for the interim change in my car, the oil is going black, not what we'd see in older petrol engines in good condition, at the same oil service mileage. I fully understand the manufacturer's stance, but their hand is often forced by outside demands, like the fleet users. Even so, in the US market BMW have pulled back on oil service intervals, even back to 1-year maximum. I think there would be outrage in the UK, if we reverted back to having oil changes at a maximum of one year, regardless of mileage. |
09-05-2016, 05:47 AM | #20 |
Rep 1,829
Drives: Alpina G21 D3S
I always do an intermediate oil change. Usually at 7-10k intervals. Never leave it in there for 18-20k. My current 335i is coming up for 1200 miles from new, so I'll drop the oil and change the filter. I do that with all new cars, whether bought outright, or on PCP or whatever. Just a peace of mind thing.
09-05-2016, 07:59 AM | #21 |
Rep 762
i'm planning to do this on mine. Will likely throw it at dealer to do it but is it easy to DIY...done lots of changes on old cars, but wonder what access is like to sump and filter?
intermediate, oil, oil change, service |
