BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > F30 DIYs and Coding Discussions > Changing default Edrive modes on 330e
      11-02-2021, 04:40 AM   #1
blackcat06
Drives: BMW 330e F30
Hi guys,
My 330e always starts up on Max edrive mode, is there a way to code the default edrive mode to something else? Like Auto edrive or Save battery?
Thanks
      11-05-2021, 01:48 AM   #2
blackcat06
No one knows how to do this?
      11-11-2021, 10:14 PM   #3
blackcat06
Guess PHEV's are really uncommon in this forum
      11-14-2021, 06:11 AM   #4
RuleNormaliai
RuleNormaliai's Avatar
235
Drives: 2022 G20 330E
try to see if ICM module has something like "ICMKOD_B_Init...."
| MGU Patching/Virginizing | ConnectedDrive activation for US cars in EU (Only MGU/ATM2) | Feature Installer codes | Map Updates | CarPlay activations. | NBT EVO GPS Connector installs. | NBT EVO repairs | Remote BMW Coding |
      11-16-2021, 01:19 AM   #5
captainfast
Drives: F30 330e 2016
Mine always starts in Auto eDrive mode as all 330e should. Not sure why yours starts up that way.
To answer your question though, I'm not sure as I haven't dabbled in coding myself.
      11-22-2021, 01:43 AM   #6
Mental
Drives: F30
Originally Posted by blackcat06 View Post
Hi guys,
Thanks
Do you have E-Sys available?
As the post above mentioned, it should be possible to code via ICMQL or BDC.
      11-22-2021, 07:58 AM   #7
tiq80
Estonia
Drives: 330e f30
So is mine: always starts in Auto eDrive mode. Someone have done some coding there.
If you want to change the drive mode at startup you need to change ICM/IcmKod_B_InitEco (The vehicle will start in drive mode Eco Pro every startup).
      11-23-2021, 03:01 AM   #8
blackcat06
Hi Mental,
I do have E-Sys, but my SVT doesnt have ICMQL or BDC, I only have ICM don't know if that makes any difference.
In ICM there is a line for IcmKod_B_InitEco and mine is set to nicht_verbaut [00].
Mine starts in Max Edrive everytime and I really want to change it to Auto Edrive everytime I start.
Auto Edrive and in Comfort mode
      11-23-2021, 03:03 AM   #9
blackcat06
Hi Tiq80,
I would like to start my car in to comfort mode in Auto Edrive not Eco pro.
      11-23-2021, 07:47 AM   #10
Mental
Drives: F30
When IcmKod_B_InitEco is set to 00 (nicht verbaut), the default mode should be Comfort (at least for regular - non 'e' cars).
Maybe in your case it is set to 01, and that is why it is starting in Max eDrive mode.
      11-23-2021, 03:14 PM   #11
blackcat06
At 00 at the moment mine starts in Max Edrive and in comfort mode.
Isn’t Icmkod_B_InitEco for the drive modes only ie. eco pro, comfort and sports and not the edrive modes?
      11-23-2021, 03:15 PM   #12
blackcat06
All I want really is to be able to change the default edrive mode to Auto and still have the drive mode in comfort every time I start up.
      11-24-2021, 07:28 AM   #13
tiq80
Estonia
Drives: 330e f30
In newer cars there is a option to choose max eDrive (1:14). If I looked in my car's HU with esys I saw things like Battery Control etc. I could have the max eDrive picture but I could not make the change. I could not make the tick in the box. This was: HU_NBT2/3000 HMI/EV_CONF_STARTUP_MODE. This activates the MMI checkbox for Max-eDrive as startup mode. Maybe this will work in your car but on my car this did't work.
      12-06-2021, 08:39 AM   #14
Mental
Drives: F30
If you had a backup/.ncd file of the FEM module, I could compare it with another vehicle, which starts in auto eDrive.
      12-19-2021, 02:54 PM   #15
rallakias
Greece
Drives: F30-330e
I want the exact opposite!
My car starts in Auto edrive-comfort and I would like it to be Max edrive-comfort!
      01-06-2022, 10:48 AM   #16
01daell
Drives: BMW 330E
As above, I would also like my car to start in Max e-drive by default. Any suggestions?
      06-18-2023, 07:18 AM   #17
CrazyCatDad
Drives: 330e
Mine is a 2017 330e. On older models, you aren't allowed to configure the e-drive settings. I don't know what yr they started allowing it. Only coding engine you can do with Bimmercode and Carly on startup is changing if it starts in ecopro, comfort, sport, sport plus. If you want it to start up in another edrive other than "auto", you need to take it to the dealer so they can code it with their high end equip.
