11-21-2021, 12:40 PM | #1 |
Rep 32
VDC unit not responding
Hi All
So I recently had battery disconnected to do some work, when I reconnected it I got “chassis function restricted” and the car is stuck in comfort mode, I checked error code on bimmerlink and I get “vertical dynamics management control unit does not respond” Not checked on Esys as i don’t have laptop with me but does it sound like VDC has died? Or does anyone know anything I can try Cheers |
11-21-2021, 01:53 PM | #2 |
Rep 2,047
Have you tried clearing fault code? Sometimes this may happen when module loses power. Clearing fault code is first option to try.
I doubt the module died, it may need coding since it may have reset due to power loss during battery disconnection. What do you mean by stuck in comfort mode? |
11-21-2021, 02:03 PM | #3 |
Rep 32
Hi,
Yes tried clearing code but it doesn’t clear, By “comfort mode” I mean driving mode, I.E sport, comfort, eco pro. What would actually need coding if that is the issue? |
11-22-2021, 01:35 AM | #5 |
Rep 32
Hi yes, checked fuses, they are all ok,
Re coding, I mean what would actually need coding on the module? I wouldn’t have thought it would lose memory just because battery was disconnected, The battery is also in good condition and kept on a maintainer when car is not used for any length of time, and I don’t get any low voltage warnings so doubt it is a low voltage issue |
11-22-2021, 02:39 AM | #6 | |
Rep 2,047
If the module is receiving power then the issue will be software related. There might be corrupt files or missing causing this issue. Using Esys you can check the ECU and see in the listed file if any contains FFFFF or is missing cafd file. |
11-02-2023, 05:54 AM | #7 |
Rep 17
Drives: w e90 320d
Sorry for hijacking this post but did you get this sorted. My Bmw F15 cannot connect to the vdc unit as it's showing up red in ista plus. Do I need esys to reset this ecu and also what would the procedure be sorry I've no clue with these softwares. Any help is appreciated.
11-02-2023, 07:41 AM | #8 |
Rep 2,047
Using tool32
ZGW_01.prg steuern_flexray_pfad ==>F5 steuern_reset_learn_flexray==>F5 This should reset flexray configuration. If it still doesnt appear then the VDC isnt responding. PM me i can help you remotely using ENET cable. |
