10-12-2022, 10:11 AM | #1 |
Rep 56
Photos and Input on adding a Stealth PPF Wrap on BSM
Hello there,
I apologize if this has been covered before and I have seen a few samples in different older threads but can anyone provide input on getting a stealth PPF wrap on a BSM G82 and what it looks like? Looking for input on looks, maintenance, price, and longevity. Thanks in advance! |
10-12-2022, 03:33 PM | #2 | |
Rep 828
Perf: Carbahn Stage 2, Eventuri Intake, PSI Midpipe, Remus Race Exh
Susp: Turner Skid Plate/Strut Brace, KW v4, F-L Monoball, MS: Camber Plates, Spacers, SPL Rear Cosmetic: MPerf: Splitter, Side Vents, Sill Plates, Door Projectors; IND CF Roundels/Float Center Caps, Vorsteiner Grill, Xpel: Stealth PPF, Fusion Plus Ceramic, XR Plus 5/20/70 Last edited by m4ml; 10-12-2022 at 07:45 PM.. |
10-12-2022, 05:20 PM | #3 |
Rep 1,172
So, you have a frozen paint or is that how it looks after the wrap?
I’m thinking you don’t have frozen paint. BSM = Black Sapphire Metallic? If so, that’s awesome that you get the best of both worlds. Matte when you want it, metallic when you don’t. Also, are there any downsides to a wrap? Does it smell bad (it’s vinyl right?) Does it ever leave residue when it comes off? How do you get it off? Edit: just noticed there are far more than usual interesting cars in the background of these pics. Were you at a car show or something? Beatles, Porsches, supras lol. If only the road looked like this everyday. I’ve never seen a parking lot like that. Last edited by DO444; 10-12-2022 at 06:03 PM.. |
10-12-2022, 07:44 PM | #4 | |
Rep 828
Yes, BSM is Black Sapphire Metallic. There is no noticeable smell, and it's not something that I had even considered LOL. This isn't a "wrap" per se, it's a Paint Protective Film (PPF). Some would argue that there is no difference, but at least to me, the difference is that a wrap changes the color, texture, has graphics, etc., but isn't intended to protect the paint (of course it does to some extent just by being a sacrificial layer). Whereas PPF is designed specifically to protect the paint (and look good) with more protective properties than a vinyl wrap. In the case of XPel Stealth PPF that is on my car, it was designed for frozen paints to keep the matte finish. Let's face it, you don't want to put gloss PFF on a frozen paint, it defeats the entire purpose. But, if you put that same Stealth PPF on a gloss car you get the matte finish without changing the color. As long as price isn't an issue for you, then in my opinion there isn't really a down side to PPF. I've never taken it off, so I really can't answer that question for you, nor whether it leaves a residue or not.
Susp: Turner Skid Plate/Strut Brace, KW v4, F-L Monoball, MS: Camber Plates, Spacers, SPL Rear Cosmetic: MPerf: Splitter, Side Vents, Sill Plates, Door Projectors; IND CF Roundels/Float Center Caps, Vorsteiner Grill, Xpel: Stealth PPF, Fusion Plus Ceramic, XR Plus 5/20/70 |
Westside Guy6778.50 |
10-12-2022, 08:13 PM | #5 | |
Rep 1,172
10-13-2022, 02:03 PM | #8 |
Rep 828
It's lowered on KW HAS with 12mm front/15mm rear spacers.
01-06-2024, 07:34 AM | #9 | |
Rep 206
How did your wrap shop handle the little round sensors around the lower portion of the vehicle (most prevalent in the front, back portions - your last photo shows them off well)? Curious if they did really small fine cuts to wrap those, or if they left them exposed gloss, etc. |
m4ml1993.00 |
01-06-2024, 03:22 PM | #10 |
F15 daddymobile
2420
Rep 3,573
IMO, stealth wrapping a paint with an amazing metallic flake like BSM detracts from the look of the paint. There's nothing better than BSM glossing and shining in the sun.
01-06-2024, 11:26 PM | #11 | |
Rep 828
aug0211170.00 |
01-06-2024, 11:31 PM | #12 | |
Rep 828
With my G82 I decided to go with Stealth PPF for a couple of reasons. First, I still wanted black, but something different, and second, the paint chips in the front end of my F82 drove me crazy. You can still see the sapphire flake depending on the lighting though. The second photo's gold reflection is actually the sapphire coming through the PPF.
aug0211170.00 |
