09-03-2018, 04:05 PM | #199 | |
Rep 2,382
09-07-2018, 07:22 AM | #201 |
Rep 1,499
I"m not sure as I've been a Verizon customer ever since I've e owned a cell phone and hotspot is included, but it looks like you'll need to modify your plan.
09-07-2018, 08:55 AM | #202 |
Rep 2,382
Really? I have the unlimited plan as well and have a hotspot available. Do you have the slower-speed unlimited plan?
2013 F30 328i: MHI Big Turbo, GFB DV+, Mishimoto CAI, ER TIC/CP/Catless DP, AWE Touring Quad Exhaust w/ Resonated Midpipe, NGK LI Plugs, BM3 with PTF Stage 2 91 AGG Tune, Fuel-it Stage 2 LPFP, Solowerks S1 Coilovers, and DEPO/M-Sport Retrofit |
09-07-2018, 11:04 AM | #203 |
Rep 179
My cellular plan was set up a long time ago but it was the fastest at the time. I’ll check with ATT again but i called before anr they said since i have unlimited LTE we cannot have the hotspot feature
09-07-2018, 11:09 AM | #204 |
Rep 348
09-07-2018, 01:22 PM | #205 | |
Rep 2,653
09-08-2018, 12:45 AM | #206 | |
Rep 10,473
They do not have a Hotspot Provision as you have actual unlimited data. Today’s “unlimited” plans only have roughly 22 Gb of data....not truly unlimited, but they do allow for a Hotspot |
09-08-2018, 07:59 AM | #207 |
Rep 179
You got it. My plan was grandfathered in from years ago. It truely is unlimited data and not capped off. It does not slow down either. I guess i have to stick to the laptop way
09-10-2018, 08:54 AM | #208 |
Rep 2,382
Yeah, such a pain in the ass. Get stellar speeds up to 22GB and then after that, they can throttle you when it's "congested/busy" (aka all the time).
09-10-2018, 10:12 AM | #209 |
Rep 415
Hi guys I’m having some issues connecting my iPhones hotspot to the OBD agent. I know the device works as I have used it multiple times by connecting my iPhone via usb to the OBD agent device.
I’ve followed the BM3 troubleshooting guide with no success. I assume disconnecting the neg terminal on the battery achieves the same thing as the ground as per the troubleshooting guide. Any other suggestions? |
09-11-2018, 06:55 PM | #210 |
Rep 519
Has anyone had luck with OBD extension cables? I tried this one and it intermittently worked and that's not good enough.
Veepeak OBD-II OBD2 Extension Cable -... https://www.amazon.com/dp/B01C2M2ZZG?ref=yo_pop_ma_swf
2019 M2 Comp, MT, BSM
2015 X5 Msport, CB (Hers) 2014 M235i MT, BSM, MPE, Dinan Springs (Sold) |
09-12-2018, 09:39 PM | #211 | |
Rep 267
iKKEGOL 1ft Feet 30cm/12" OBD II OBD2 16 Pin Male to Female Extension Cable Car Diagnostic Extender Cord Adapter https://www.amazon.com/dp/B00L4207IS..._M2CMBbK4XJVAM |
stroker1562.50 |
09-16-2018, 08:31 PM | #212 | ||
Rep 519
09-17-2018, 01:17 PM | #214 |
Rep 2,382
What do you need an extension for? The ENET cable I have is ridiculously long.
09-17-2018, 01:19 PM | #215 | |
Rep 519
09-17-2018, 01:30 PM | #216 |
Rep 2,382
You can also unclip the connector and tuck it away. I have mine like that but accessible through the small hole, so I can pull it out if need be.
stlb5217.00 |
09-17-2018, 02:55 PM | #217 | |
Rep 415
09-17-2018, 04:00 PM | #218 |
Rep 2,382
Ensure your hotspot name is all lowercase, same with the password. I've seen that one before. Other than that and ensuring WiFi is turned off and you've followed BM3's troubleshooting guide, that's all I know for the iPhones.
09-17-2018, 05:05 PM | #219 |
Rep 1,499
If you are doing this while at home in your garage make sure you are disconnected from your home wifi. You have to go into settings, wifi, lick on your home network and click "forget this network". Once you've connected your phone hotspot to the wifi agent you can reconnect to your home wifi network.
09-17-2018, 05:31 PM | #220 | |||
Rep 519
