05-12-2015, 04:44 PM | #353 |
Rep 40,733
PM sent.
05-13-2015, 11:28 PM | #355 |
Rep 40,733
PM sent.
05-16-2015, 01:07 AM | #357 |
Rep 40,733
PM sent.
05-22-2015, 08:33 AM | #360 |
Rep 40,733
PM's sent.
05-22-2015, 01:22 PM | #361 |
Rep 8
Hi Shawn,
First of all I really appreciate all the work and effort that you put into this forum and all fellow members! Absolutely great! Secondly I would like to code my 2014 BMW 320dA (F30) to change 6NH to 6NS. I am fully aware of the steps that I need to take to achieve this (read many sources on the internet). I already ordered a ENET cable and downloaded E-Sys ESYS 3.26.1. I believe I will need to use the full version of PSdZData since I will be making changes to the FA-list. Which version of PSdZData do you advice and can you also please share a link towards a torrent or a basic link? Many thanks! Gr. Ruben |
05-22-2015, 01:45 PM | #362 | |
Rep 40,733
05-23-2015, 02:53 PM | #363 | |
Rep 8
I manager to code succesfully 6NH to 6NS, however at the end I got the following error message: [Exception - VCM_BACKUP - 40] job failed with negative response error: code: service returned global negative response description: Service WDBI_FA1 returned a negative response with response code requestOutOfRange; ECU: VCM_BACKUP_ETHERNET severity: ERROR VCM Update: finished with error. [C196] Error in VCM Update: Write FA to the Backup Partner failed. Possibly there is no connection to the Backup Partner. [C097] job failed with negative response error: code: service returned global negative response description: Service WDBI_FA1 returned a negative response with response code requestOutOfRange; ECU: VCM_BACKUP_ETHERNET severity: ERROR [433] Abarbeitung beendet Everything seems to be working and the error message seems to be related to a failed backup. Have you ever seen this error? Thanks in advance! |
05-23-2015, 05:59 PM | #364 | |
Rep 40,733
The instructions state that under E-Sys Options, you are to disable "Update VCM" and "Update MSM". Had you done so, you would not receive this error.
05-24-2015, 06:22 AM | #365 |
Rep 8
05-24-2015, 09:09 AM | #366 |
Rep 8
Hello Shawn,
Small last question! When I try to read the coding data of the CADF from FEM_BODY I get the following error message: cafd_00000794-007_031_012 Fehler: CPS read from ECU "ECUId:FEM_BODY_0x40" failed! [C070] openECUConnection for link FEM_BODY_40_ETHERNET failed with error MCDError Severity: 2051, Error Code: 49184, Description: Object with name not found, Vendor Code: 3, Vendor Description: provided name FEM_BODY_40_ETHERNET doesn't map to an item [1694] This keeps me from coding auto-start-stop.. do you have any clue how to get around this error message? Aparently there is an object which cannot be mapped to an item. Is there a way to walk-around this error? I only need to access the function TCM_MSA_DEFAULT_OFF. Thanks in advance! Ruben |
05-24-2015, 09:20 AM | #367 | |
Rep 8
05-24-2015, 10:00 AM | #368 |
Rep 8
That did the trick, google if your best friend! Thanks for you help, I manager to code everything that I wanted!
05-24-2015, 11:33 AM | #369 | |
Rep 40,733
"FEM_BODY_40_ETHERNET doesn't map to an item" means the wrong series was selected, as in a car without FEM_BODY ECU (e.g. F010) was used.
05-24-2015, 11:34 AM | #370 |
Rep 40,733
Amen to .
05-24-2015, 02:05 PM | #371 |
Rep 8
I believe it was set to default or automatic.. so I was able to connect but not use the FEM_BODY ECU. Anyways, it worked out!
05-24-2015, 05:33 PM | #372 |
Rep 643
Drives: BMW M5 F10
Garage List 2013 BMW M5 [0.00]
2011 Alpina B3S Bit ... [9.50] 2010 Alpina B3 Biturbo [10.00] 2009 Alpina B5S [10.00] |
Hey Shawn, can you pm me whatever I need for E-sys. I already have the PSdZdata and cable is on the way!
05-24-2015, 07:55 PM | #373 |
Rep 40,733
PM sent.
