08-27-2018, 11:40 AM | #1 |
Rep 130
Tire Fitment 328i X Drive 19x8.5 and 19x9
All,
I have been doing TONS of research to get the best tire fitment but have found that we need to be extra careful with Xdrive systems to ensure they are very similar in circumference/diameter. What do you recommend for 19x8.5 offset 33 and 19x9 offset 37? Using the tire calculator the closest seems to be: 19x8.5 = 235/40/19 19x9.0 = 265/35/19 Is this close enough at a .4% difference or do I need to go with a square setup to ensure they are perfect? Is this offset acceptable, I DO NOT want it to 'poke' out! Would appreciate your input as the variables with offsets, widths, height is maddening!!! Thank you in advance!!!!! Fred Last edited by fredsf30; 08-27-2018 at 12:03 PM.. |
08-27-2018, 12:23 PM | #2 |
Rep 4,328
for 8.5/9.0 on xdrive you can run,
225/40(26.1), 255/35(26.0), 0.4%, oem tire set up for bmw staggered, front is a bit stretched on 8.5 235/40(26.4),265/35(26.3), 0.4%, many run this size on x-drive, limited tire selection, this is what i'd do for your x-drive 245/35(25.8), 255/35(26.0), 0.8%, best tire to width fitment, increased front grip reduces understeer while maintaining turn in response 255/35 square, front is slight oversize on 8.5" and optimum tire width for 9" rear. odd to the trained eye, most wouldn't see the difference 245/35 square, front optimum tire width for 8.5, slight stretch on 9" rear, again odd to the untrained eye, most won't know 245/40(26.7) square, same as 245/35 but a profile size taller. reduces wheel gap provides better ride and impact. personally i dont care for the tall beefy look and your N20 engine will feel like a slug and your car will feel less sharp with taller heavier tires. Last edited by alohasurftoad; 08-27-2018 at 12:29 PM.. |
08-27-2018, 12:34 PM | #3 | |
Rep 130
You are an awesome help!!!!! Thank your so much!!!! |
08-27-2018, 12:38 PM | #4 |
Rep 4,328
if you do choose 235/40, 265/35 it will look like thx@wdeerfield except your rear wheel will be poking out 8mm more since his offset is +45 and yours is +37.
https://f30.bimmerpost.com/forums/sh...hlight=vmr+803 |
wdeerfield2746.50 |
08-27-2018, 01:39 PM | #5 | |
Rep 130
Do you think mine will still poke a bit if the rear wheels are 9.0 vs. his 9.5 or should that eliminate that extra bump out? Because I don't want them outside the fender. |
08-27-2018, 01:42 PM | #6 | |
A family of bimmers
2747
Rep 7,742
id recommend 235/265 all day. It is comfortable and looks great even not lowered.
08-27-2018, 01:53 PM | #7 | |
Rep 4,328
if you run 245/255. the slightly stretched rear will have the shoulder 5mm further in than where the 265 shoulder is. the rim edge will still be at the same place, though |
fredsf3024.50 |
08-28-2018, 09:09 AM | #11 |
A family of bimmers
2747
Rep 7,742
et45 on a 9.5 != et45 on a 9.
his wheels are 9inches wide at et37 so the face of the wheel will only be 2mm further out from mine. he wont poke at all.
08-28-2018, 10:15 AM | #12 | |
Rep 4,328
Additional info. Tire section and tread widths vary for same sized tires of different brands and models but my calcs are based as if all tires are equal |
08-28-2018, 10:32 AM | #13 | |
A family of bimmers
2747
Rep 7,742
alohasurftoad3078.00 |
