12-09-2017, 12:50 PM | #1 |
Rep 445
Winter tyres
Swapped to winter wheels today and realised that I bought the wrong tyres for the back wheels. So I’ve got 225/45 up front and 225/40 on the back... do I need to change them urgently or will it be ok for now - 325d m sport on 400m wheels for winter
12-09-2017, 01:32 PM | #3 |
Rep 3,216
It's a 3.5% difference. Certainly not ideal, though it shouldn't cause any damage if the car is sDrive.
xDrive would be a different matter though. |
12-09-2017, 01:58 PM | #4 | |
Rep 15,858
This applies for ABS control function. DSC allows tyre logic tolerance of 3 - 4% for the ASC, without loss of performance on RWD models. ABS is more critical in winter conditions, look out for irregular and/or unexpected ABS/DSC intervention. |
12-16-2017, 04:21 AM | #8 |
Rep 7
Sorry to jump onto another thread however, I didnt want to add yet another winter tyre query thread.
I've got myself a nice new set of 18" wheel for winter - 8 & 8.5 in. I'm getting Continentals to go on them but wondered if fitting 225,60's and 255,55's would be an issue? Also, with that much sidewall, it has potential to look like a landrover OR go the other way and fill the arches nicely. Anyone have any experience fitting large tyres to an F3X? The backup plan is to fit 225,45's and 255,40's Price form tyreleader looks alright. Any help appreciated. |
12-16-2017, 05:03 AM | #9 |
Rep 1,704
Firstly....you are joking, right?
225 60 18 is defiantly the wrong size. The wheels will be too big with a completely different rolling circumference than your originals. 60 is the percentage od the width, so you are getting a sidewall 60% of 225 = 135 mm , as opposed to 45% of 225 which is 101 mm Last edited by sensible; 12-16-2017 at 05:14 AM.. |
12-16-2017, 05:18 AM | #10 |
Rep 7
Cheers,
Thats what I thought. Worth asking though. Update, I cant seem to find 255,40's that match the fronts (TS850P) Do you reckon fitting 45's bot fornt and back would be alright? |
12-16-2017, 05:41 AM | #11 | |
Rep 1,704
BMW recommend 225 45 18 all round for a winter tyre but that isn't ideal for that size wheel either as it is one of the smallest tyres for that wheel....but again it is acceptable for that wheel size. I decided to stick with what is said on my plate inside the door with 8j fronts and 8.5j rears. (M + S stands for mud and snow....winter tyre) |
12-16-2017, 05:51 AM | #12 | |
Rep 1,704
245 40 R18 is a good match and a better tyre size for an 8.5j wheel if you are set on having bigger rear tyres. |
12-16-2017, 06:49 AM | #13 |
Rep 32,881
I couldn’t get my tyre of choice in 255 either (Dunlop winter sport 5), so I put 245/40’s on the rear, and will get the same for the front when they need replacing.
12-16-2017, 07:20 AM | #14 |
Rep 1,704
Wouldn't the 245''s on the rear and 225' work much better that 245 all round considering the fronts are on 8j wheels and they are wide for front tyres?
12-16-2017, 07:27 AM | #15 | |
Rep 32,881
12-16-2017, 08:22 AM | #17 |
Rep 1,704
12-16-2017, 09:05 AM | #18 |
Rep 3,967
That's what I was thinking. Seems the closest you can get to 255/40/18 rears in Michelin crossclimates. The Tyre calculater I used shows only a 1mph difference at 90mph too.
12-16-2017, 11:14 AM | #19 |
Rep 32,881
12-16-2017, 02:06 PM | #20 | |
Rep 3,967
The circumference is only 1inch difference |
12-16-2017, 03:43 PM | #21 | |
Rep 1,704
So your not going for 'winter tyres' then....Cross climates are All Season tyres for all year round. Good tyres if you plan to leave them on all the time, but not as good as having winter tyres and summer tyres. Last edited by sensible; 12-16-2017 at 03:53 PM.. |
12-16-2017, 03:55 PM | #22 | |
Rep 3,967
I use them on my 320d and have been very impressed with them, comparable performance in the summer to the continental run flats I had on before and were very good in the snow we just had in the West Midlands. I'm just sizing them up for the 18" m sport wheels I'll most likely have on the 330/335d I buy soon. 225/45/18 fronts and 255/40/18 rears .. closest I can get for the 8.5j rear wheels is 235/45/18 in cross climates. |
