11-30-2017, 05:18 AM | #177 | |
Rep 1,148
11-30-2017, 05:32 AM | #178 |
Rep 2,152
when did you do it and what you on IOS or Android. im on Android and feature isnt there
Current: BMW M4 F83 - Mods : Pedal Covers, LCI Stereo facia Retrofit and Carbon Rear corner covers
Old: F32 435d M Sport - Mods : HR Sport Springs, 20" Veemann V-FS23 in Gun Metal, M Performance Body Kit, Pedal Covers, Eurspec CF Mirror Caps, More-BHP remap 364 BHP 741 NM, M4 Under Chassis Brace, 15mm Rear ARB, 8.8" Screen Retrofit and LCI Stereo facia Retrofit |
11-30-2017, 05:41 AM | #179 |
Rep 399
11-30-2017, 05:44 AM | #180 |
Rep 2,152
Yea I logged a case and he will reimplement it. Stupid to remove it as not everyone will have the latest software in car. Once I proved I can do it on esys he was happy to read it lol
11-30-2017, 06:31 AM | #181 |
Rep 1,148
12-06-2017, 04:33 PM | #183 |
Rep 431
How does backup work on bimmercode?
If I press backup, does it automatically backup all modules, or do I need to open each module and backup individually? Also, to utilise backup, do I just open backup, then select the date and press done? Thanks for any help. |
12-06-2017, 10:10 PM | #184 |
Rep 7,484
Works with all Fx, Gx and, ix models. I haven't seen battery registration on mine for the F30. You could suggest it to the developer. See what he says.
12-14-2017, 07:11 AM | #185 |
Rep 1,909
New Carly coddle options
Updated Carly today, apparently much more codings for F models, anyone know whats new? will have a look tomorrow when I have time.
Happy Motoring
Evdok |
12-14-2017, 08:17 AM | #187 |
Rep 5,457
Drives: F30
12-14-2017, 01:25 PM | #188 |
Rep 170
From my very limited knowledge, SAT is the regular sport coding, like being able to go to Sport+. 2TB gives you different shifting, S rather than DS when moving the gear selector to the left, and launch control. Also I think when you have 2TB from BMW you get a different shift lever (bigger park button is the visual difference)
12-14-2017, 06:20 PM | #189 |
Rep 5,457
Drives: F30
I already have S when sliding shift lever left. No DS...
I do not have Sport+ or Launch control. Basically Im trying to figure out what transmission coding I can do to enable different features, faster shifting. Not sure how to accomplish this. I have BimmerCode already.... Any help would be greatly appreciated. |
12-17-2017, 06:42 AM | #190 | |
Rep 1,245
I have both, and I much prefer Bimmercode. |
01-03-2018, 08:23 AM | #193 |
Rep 7,484
I would drop the developer an email and ask him to add this back on. Seems like a reasonably helpful guy. Unless you can restore from back up coding? Always good practice to make a back up before you code.
01-03-2018, 08:42 AM | #194 |
Rep 431
lost all my coding when I has mppk fitted.
So decided to bite the bullet and use BimmerCode today. Was just going to start small, and code digital speedo. Started the app, and selected instrument cluster, but no module found came up! Is this normal for a 65 LCI f30? |
01-13-2018, 12:35 PM | #195 |
Rep 8,498
I've been using Carly thus far and, although it can be a slow process to run diagnostics, clear fault codes, and code, it has been reliable.
Bimmercode has some different options, so I thought I'd try it. Can't say I'm impressed. The Bimmercode developer answered a lot of my questions, and advised getting the latest OBD WiFi dongle : VGATE iCar Pro as it's the latest variant. However, it's got generally crap reviews on Amazon so I bought the iCar 3 on the basis that it's newer than the iCar 2. Problem is, although the iCar 3 generates a WiFi SSID "iCar Soft" and my iPhone will connect to it, Bimmercode states that there's no connection. I tried this several times - always the same result. Unlike the Carly Gen2 dongle, the VGATE unit does not have any lights so you can't see if it's active. I'm not using any other software, just Bimmercode. Has anyone else had these issues, and did you manage to resolve them ?
01-13-2018, 12:50 PM | #196 |
Rep 276
You should send it back and get the iCar 2 wifi or Pro. The developer recommended those 2, not the 3, but you chose to ignore him.
One thing to try - put your phone in airplane mode, then turn on wifi and attempt to connect to the iCar. Once connected you will be impressed by the app. |
01-13-2018, 12:52 PM | #197 | |
Rep 7,484
This is with my iCar2 |
01-13-2018, 01:06 PM | #198 | |
Rep 8,498
