11-02-2020, 06:49 AM | #441 |
Rep 1,801
Got a dragy shot of that showing your splits? I'm curious where you're faster.
Europe's fastest (stock block) F31 340i RWD | MPPSK | XHP 3 | Pure800 | Port Meth | Dorch 2 HPFP | MG Flasher
11-02-2020, 10:33 AM | #442 |
Rep 413
It was recorded on a Vbox but I've recently bought a Dragy so once the weather improves I'll post some times.
2017 440i F36 - Drexler LSD - B58TU HPFP - MHD Stage 2 - xHP - 200 Cell DP - MPE
11-02-2020, 04:23 PM | #443 |
Rep 1,801
Well you're still a fair chunk faster than me. Went out tonight and did a 8.68s 100-200.
11-02-2020, 04:34 PM | #444 | |
Rep 1,239
On the stage 2 map Out times are identical.... both 0-60 and 100-200! Iv since changed over to the TU pump and Stage2+ and although the intake temps were about 10oC higher my times didnt improve at all.... Cant wait to try some more draggy runs now the weather is cooling off. |
11-03-2020, 01:03 PM | #445 | |
Rep 1,801
11-03-2020, 01:07 PM | #446 |
Rep 1,239
11-06-2020, 02:06 AM | #447 |
Rep 1,801
Okay got it down a fair chunk more.
This'll do for now. Getting wheelspin like that at 60mph had me worried.
11-06-2020, 07:33 PM | #448 |
Rep 56
Almost there! Hunting for the 340ix stock turbo 1/4 mile record, currently owning it afaik but no valid 10 sec yet.. so close.
2020 M340i xDrive Mineral White Metallic
RIP: 9 second 1/4 BMW 340i xDrive Melbourne Red | Instagram: daddy.340 |
OzBMR574.50 |
11-06-2020, 07:57 PM | #449 |
Rep 1,239
11-08-2020, 03:17 AM | #451 |
Rep 1,010
Mate 100-200 in the 7s on 93 without Ethanol is incredible
Any logs ? Also what do you mean by corrected time ?
2018 340i 8AT RWD - M Sport - Catless MPPSK - Stock Turbo - Stock HPFP
-------- Tunes: Self Made Tunes - MHD ------ Fuel: 92RON/87OCT -------- |
11-08-2020, 03:43 AM | #452 |
Rep 3,877
He means corrected time recalculated for 0 slope. There are apps you can use to do so. Quite useful as in reality you never have 0,00 slope.
11-08-2020, 04:04 AM | #453 |
Rep 1,010
I guessed so but 0.76 slope is worth much more than 0.1 seconds.
Also how is slope correction calculated ?
11-08-2020, 04:09 AM | #454 |
Rep 3,877
No, apparently it's not I seem to be using a different calculator than him as mine has 2 decimal digits, not 3, and still it calculates the same - 7,72.
11-08-2020, 04:17 AM | #455 |
Rep 1,010
In real life with 0 slope I bet his car will run 100-200 in 7.5 seconds.
I've done too many 100-200 Dragy runs and in my car a 1% slope is worth around half a second 100-200. Here are 2 consecutive 100-200 runs on the same road with different slopes. In real life the slope makes much bigger difference than your calculators guys.
-------- Tunes: Self Made Tunes - MHD ------ Fuel: 92RON/87OCT -------- Last edited by IMS-340C; 11-08-2020 at 05:51 AM.. |
11-08-2020, 04:44 PM | #456 | |
Rep 282
https://datazap.me/u/thomas/mhd-ots-...og=0&data=3-20
M140i DP , OPF delete , MHD stg2 93oct , xhp stg3
11-08-2020, 06:31 PM | #457 | |
Rep 585
I don't think 98RON/93 octane. Maybe 102RON fuel on the 93 octane map you could get good ignition timing and 100 - 200 time of 7.8s on that map. Looks more like an E30 result, still good either way
Tesla Model 3 Performance 0 - 60mph 3.1s
M140i LCI Mineral Grey Dorch Stage 2 HPFP, CG Precision DS-1, XHP, MHD Stage 2 HPFP E30 @ E42 100 - 200 6.96s Quarter mile 10.93@127mph |
11-08-2020, 09:14 PM | #458 |
Rep 1,369
Over here in MPH land, had a couple 62-124 mph (100-200 KPH) in the 7.6x realm, but they went blank/invalid? My 8.78 second 60-130 time held up though. Cooler temps help a ton! I'll get new 62-124's tomorrow night.
2017 M240i/ ZF8 Pure Drivetrain Solutions Stage 1 & torque converter/xHP/ DAW Ultra Flow/ DS2/ Nostrum injectors/ E40 Doug Newton tuned/ ER DP/ Remus axle back/ BMS intake/ FTP CP/ M Perf LSD
OzBMR574.50 |
11-09-2020, 12:13 AM | #459 | |
Rep 282
i always thank esso's , but esso or total or shell , dont think it would make that much of a difference . later on i will test the e30 and hpfp maps aswell . temps were cool though , around 10 degrees C
11-09-2020, 02:25 AM | #460 |
Rep 1,801
DSC fully off, stick to the left. I start with kickdown then manually change up.
jackstrath658.50 |
11-09-2020, 03:14 AM | #461 | |
Rep 3,877
Of course the bigger the slope, the bigger any deviation. So a calculated correction does not fully compensate for an uneven terrain. It just mitigates. Keep in mind that the slopes Dragy displays are not 100% accurate either. I do all my runs on the same road (back and forth) and the displayed slope varies more or less every time. (verified with different dragy units) None of this is precise science I suspect 100-200 runs are by nature much more prone to inaccuracies due to the significantly longer distance driven (in comparison to 0-100).
11-09-2020, 12:09 PM | #462 |
Rep 1,239
