12-07-2013, 11:50 PM | #1 |
Rep 7
20" Wheels for 320xi
Just ordered:
Niche M129 Targa Front: 20x8.5 et 35 Rear: 20x10 et 40 Tires are: Hankook Ventus V12 Front: 245/35/20 Rear: 285/30/20 Do you think I will have any problems fitting them? |
12-08-2013, 12:28 AM | #2 |
6580
Rep 5,304
If you are lowered, you will most likely rub. I have the same rear wheel with Hankook V12 at 275/30/20 and it rubs the inner fender liner on full compression. A 285 will most likely rub unless you get more negative camber. I say probably because I don't know the camber settings your car came with.
12-08-2013, 03:34 AM | #3 |
Rep 1,170
Your rear will rub for sure on the outside if you're lowered at all. 20x10 et40 rubs even with a 265 30 20. You're better off going with 255 30 20 and stretching the tire a bit.
F36 435i * MINERAL GREY * ///M Performance | G01 X3 * PHYTONIC BLUE * ///M40i
12-09-2013, 08:16 AM | #5 |
Infidel
122
Rep 1,102
This will affect your performance pretty bad with those 10īs in the rear, the added rotational mass is to big for that engine so it will be noticeable.
Dec. 2022: Fully loaded Carbon Black G08 iX3 LCI M Sport Pro
Former: Glacier Ag. F31 328iA RWD M Sport oct. 2012, sold July 2022 | Sport Automatic | Adap. M Susp. | Pano. Moonroof | 20" ATS Racelight Grey w. Michelin PSS| M Sport brakes | Harman Kardon | Elec. Seats | PDC F&R | ACC Stop&Go | 335i MPE | Perf. Parts | |
12-09-2013, 10:32 AM | #6 |
Rep 222
Plus the added unsprung weight will definitely have a negative effect on acceleration. And not to mention aftermarket 20's on stock height = FAIL
12-09-2013, 12:15 PM | #8 | |
Rep 1,554
Try adding 1-2 degrees of neg camber. It actually won't effect the wear at all. I did this to mine so I could tuck the tires a little bit more and after 7,000 miles, the inside wear is still the same as the outside wear. For the OP, even if you don't lower it, if you put two people in back you will rub. Also if you get the wheels on there and do not want to drop it down a little I would be shocked. Your best bet is to try to cancel the order hoping they have not shipped yet. You should try to go with a ET of 42-45 on the rear with nothing wider than a 275. I am running a 10.5" with a 275. If you are running a 10" I wouldn't go over a 265. |
12-19-2013, 09:16 PM | #10 |
Rep 7
12-20-2013, 09:18 AM | #11 | |
Rep 1,554
I tell people I bought 20s and they say oh it kills your acceleration. My response is dude its a 3 series BMW, it ain't fast no matter how much you mod it. For the price of the 3 series there are plenty of faster cars. Sure it is fun to drive, but if anyone can claim to sit in my car and go back to back with my stock 17s vs my 20s blindfolded and tell me one is faster than the other, they are smoking crack. |
12-20-2013, 10:26 AM | #12 | |
Rep 7
Couldn't agree with you more!
12-21-2013, 07:11 AM | #13 |
Rep 5,140
12-21-2013, 09:43 AM | #14 |
Rep 1,715
You clearly haven't driven a tuned 335 or m3 if you think 3 series are not fast. My buddys 335 runs almost even 1/4 mile as my f13 m6. My 335 will hopefully be getting up there soon.
12-21-2013, 09:00 PM | #16 | |
Rep 222
12-22-2013, 11:10 AM | #17 |
Rep 1,388
^^^+1
12-23-2013, 10:15 PM | #18 |
Rep 371
^^^+2
2014 335i M Sport - Mineral Grey/Coral Red, Nav., Premium, HK, MPE, 8AT. Mods: Macht Schnell Spacers (12mm-front, 15mm-rear) with 403M's, Bilstein B8 Struts/H&R Sport Spring combo, M-Performance black kidney grilles, IND Distribution color-matched reflector inserts and key hole cover.
03-17-2014, 01:28 PM | #19 |
Rep 1,136
what suspension does it rub on? h&r sport springs and stock m sport shocks or coils?
sent from bimmerpost Android app
