03-09-2014, 11:34 AM | #1 |
Yorkshire Sniper
Rep 592
School Boy Error on winter Wheels
After washing my winter wheels today Ive managed to mix them up ..
Does it matter? Apart from drivers side rear ive no idea. ... There all messuring 7.1mm to 7.5mm tread depth... Any ideas. ....?..should I just check which wheel has the closest tread left to the RDS?
Thanks in Advance......
03-10-2014, 12:00 PM | #2 |
Rep 6,811
Drives: E82 135i / E92 328i / E60 550i
If you have directional tires then you will need to re install them the right way. Also if the setup is staggered make sure the wider ones are in the rear.
However, if they are not then you are fine |
