03-11-2014, 06:36 PM | #1 |
Rep 2,567
F30 wheel question
Hi all,
A friend is looking to purchase wheels for his F30 328i. I came across a deal with the following offsets. Would this fit his car? 19x8.5 ET35 and 19x9.5 ET33 235/35R19 and 265/30R19
07 e92 335i - Retired
18 F80 M3CS - Retired 21 G20 330i M-Sport - Current |
03-11-2014, 07:23 PM | #2 |
Rep 536
Fronts are fine but the rears are too aggressive for an F30
I tried the same rear offset and it sticks out way too much. Most I've seen on the rear with a drop suspension on a 19x9.5 rim is et35 |
03-11-2014, 07:48 PM | #3 | |
Rep 2,567
03-11-2014, 09:54 PM | #5 |
Rep 2,567
Thanks bro. What are the offsets for an f30? What sizes do you recommend for 19's?
03-12-2014, 08:46 AM | #6 | |
Rep 1,728
Did you see the 19x9.5 ET35 here on f30post? I have only found a couple of shots on this site with this setup. I have rims with this spec in the rear but I have not seen if these will fit an F32.
'11 Space Grey E92 335xi M-Sport (KWv1 Coils | Saddle Brown | Bamboo) (Returned)
'14 Mineral Grey F32 335i M-Sport (Dinan DHP | LED Lights | Coral Red | Hexagonal Aluminum) (Returned) '16 Mineral Grey F80 M3 ZCP |
03-12-2014, 10:57 AM | #7 |
Rep 2,567
actually, they may be the following... would this fit?
19x8.5 ET33 and 19x9.5 ET35 235/35R19 and 265/30R19
03-12-2014, 11:35 AM | #8 |
Rep 6,811
Drives: E82 135i / E92 328i / E60 550i
03-12-2014, 12:04 PM | #9 |
Rep 2,567
They're the Alufelgen SF-71's in 19's
03-12-2014, 04:37 PM | #11 |
Rep 2,567
Yes lowered.
03-17-2014, 11:39 AM | #13 | |
Rep 202
I have 19x8.5 et 35 up front and 19x9.5 et 38 in back (ZCP reps). You really don't want to go any more aggressive than that. Rears are borderline. |
03-17-2014, 11:48 AM | #14 |
Rep 6,811
Both of those will work. That 19x9 and 19x10.5 is a very common setup from stance or velgen.
03-17-2014, 01:56 PM | #15 |
Rep 25,989
Fronts will fit just fine, but the rears are going to be a bit more aggressive than we recommend. I'd suggest higher offsets out back.
VMR|Wheels | 714.442.7916 |
sales@velocitymotoring.com | www.velocitymotoring.com | facebook | flickr | Instagram |
03-17-2014, 08:16 PM | #16 | |
Rep 1,728
What are your tire sizes?
03-17-2014, 08:54 PM | #17 |
Rep 536
03-17-2014, 11:37 PM | #18 |
Rep 548
wow your getting some bad info. This will defiantly fit, worst case scenario you dial in some negative camber.
