03-13-2014, 07:49 PM | #1 |
Rep 3,066
wheel noob
I'm looking to upgrade my 400M wheels to something else like a VMR or BBS primarily for esthetics; not planning to track the car. As an average noob consumer, what are the noticeable differences between the two that I should consider? To me BBS = high end, VMR = mid-grade. There are a few variables at play: price, weight, durability, fit, appearance.
Assume fit and appearance are constant. As an average noob would a VMR wheel suffice for esthetics? I cant believe a few lbs/corner is going to make a dramatic difference. Opinions? |
03-13-2014, 08:07 PM | #2 |
Rep 188
Well I would go for what the best looking wheel is in your eye if your not after performance, if you don't have a budget go for bbs. Lightweight does make a large difference for unstrung weight. Especially rotational mass. I think it acts as 3 times the deduction for rotating mass, so say you we're using a regular tire that wasn't a runflat (heavy) and a lightweight wheel and you managed to shave 10 lbs per corner, which is 40 lbs but since its rotating all the time it would act like your saving 120 lbs. I'm no expert, just going off what I've read. Hope that helps
03-14-2014, 08:08 PM | #3 |
Rep 3,066
thanks for the explanation Grant.
I would assume that reducing unstrung weight results in the following for our cars: -potential fuel savings -quicker acceleration -improved control during cornering Do I have that correct? |
03-14-2014, 09:31 PM | #4 |
Excited F34 owner
Rep 148
I'd also consider the strength of the wheel and the manufacturing process. I know you're not tracking those wheels. But how r your roads? Full of potholes? Not perfectly maintained? Here in Pittsburgh, people get wheels dented and damaged all the time just due to the road conditions. Therefore, wheel strength was not a non-issue for me when I was considering new wheels, even though I didn't buy them for track.
I hear VMR makes some nice wheels. And of course BBS does. I believe most (all?) VMR wheels are gravity cast, while a lot of the lower cost BBS wheels are low pressure cast. I ended up with some Avant Garde wheels because they're supposed to be a little stronger than VMR (low pressure cast vs gravity cast). But here are lots of people who are happy with their VMR wheels too. |
03-14-2014, 09:33 PM | #5 | |
Rep 188
03-15-2014, 10:56 AM | #6 |
Rep 3,066
Michigan is notorious for pot-holes especially after the winter we are having. However, I can say that I haven't bent a wheel since I was driving a 2001 Cavalier. I hope I don't jinx myself.
What is the construction method of the BMW wheels? I would love to get into a set of BBS CH-R; however, that's a tough pill to swallow cost wise. |
03-15-2014, 11:40 AM | #7 | |
Rep 188
03-15-2014, 02:21 PM | #8 |
Rep 3,066
Ordered a staggered set of 18" Forgestar F14's in Gunmetal. Thanks guys!
dramatic weight saved, and a little bit more pushin' for the cushion. Last edited by drexplode; 03-15-2014 at 09:39 PM.. |
03-18-2014, 12:51 PM | #9 | |
Rep 25,989
VMR|Wheels | 714.442.7916 |
sales@velocitymotoring.com | www.velocitymotoring.com | facebook | flickr | Instagram |
