07-16-2021, 03:20 AM | #1 |
Rep 5
F31 front clunk
Hi everyone, I apologize if this has been discussed before but I couldn't find it.
I own a F31N 2017 which started to develop a clunk when the outside temperature is more than 25°C/77°F and the car is warmed up from driving it. It makes the noise when I start from a standstill, brake and just drive normally. The clunk is coming form the front passenger wheel area and if I kick the tire I can make it to make the noise. Here is the link to a video of how it is after driving in the city when it was 37°C/99°F outside. https://drive.google.com/file/d/1SR2...ew?usp=sharing I took it to the dealer to try and get this sorted but they describe this as a car in "perfect" condition, which I highly doubt. So after that I took it to a local guy where we unscrewed the sway bar and link but it still made when starting and braking. Then we replaced the thrust arm but it still didn't cure the clunk. Right now I'm waiting for hot weather so I can warm up the car and then lift it to try and find the origin but if someone has suggestions they would be greatly appreciated. Thanks in advance. |
07-16-2021, 10:09 AM | #2 |
Car Hypochondriac
335
Rep 901
Damn, thrust arm was going to be my first guess.
Find a better shop, if you can reproduce it that easily, any right-minded mechanic would never tell you it's in "perfect" condition. My thoughts are basically anything else on the suspension... strut mount, the strut itself, lower control arm, maybe the hub/bearing. Edit: this is a RWD model, correct?
Handling mods: Koni yellow - Eibach prokit - Millway street - M Performance LSD - M3 brakes - EBC bluestuff Exterior: Euro LCI tail lights - Shitty ECS CF spoiler - Chinese M performance diffuser Interior: Bavsound stage 1 and subs - custom trunk sub by Mike1327 |
07-16-2021, 01:23 PM | #3 | |
Rep 5
I tried to move the lower control arm whrn the car was on the lift but it didn't have abnormal play in it. The bearing was inspected by the same shop but they wrote it's fine but how much you can believe them is a good question. I have an appointmen at another dealer who is apparently more competent in 2 weeks time to change the brake pads and to take a look at this but I'm still gonna do some research on my own since I do quite a bit of driving and the clunk is driving me insane. And yep it's a RWD. |
07-22-2021, 05:38 AM | #4 |
Rep 5
A little update. Yesterday I got my wheels balanced and while the car was warm and happily making the sound I hate, I asked the guys if I can take a look and I think both of the thrust arm bushings are too soft and the bushing was cracked a bit.
The first time we changed the thrust arm we only replaced the passenger one and not driver side one so that could be the reason the clunk was not cured the first time we tried to diagnose it. Here are the links to the videos (warning to headphone users, the sounds are terrible in the background): https://drive.google.com/file/d/1cVC...ew?usp=sharing https://drive.google.com/file/d/1uGU...ew?usp=sharing If someone has more experience I'd love a comment or some advice, Thanks! |
07-26-2021, 10:12 AM | #5 |
Rep 1,363
I too am suffering a dreaded clunk and after spending time silencing the 6 tons of plastic underneath my car, and replacing perfectly good sway bar end links, I said "Hold on, hold on . . . it's probably the dreaded steering rack clunk."
Got the kit. Got the grease. Waiting for the magic tool to get that cap off. Google "F30/F31 steering clunk". To confirm, 1. Park car on level ground 2. Shut off car completely, like you would when parking 3. Rapidly turn steering wheel left and right 10-15%. Hear the clunk? The EPS steering rack uses a plastic piston to push the pinion and rack together. The piston wears over time since it's made of a material of less resiliency than the replacement part. The fix-it kit is reasonably priced ~USD$30. The grease too is also inexpensive ~USD$9 Except for every single car made with the old piston, no other car would have the problem. Why don't others complain? Two words. LEASE CAR
07-27-2021, 01:00 PM | #6 | |
Rep 3,940
The ZF steering rack thrust bearing can be opened with a standard hex socket. But when you open it and look at the thrust bearing piece, it's actually different than the one used in the Variable Sport Steering rack. I wasn't able to use a needle nose plier to remove it because there's nothing for the plier to grip to in order to pull it out from the rack. The color is also similar to the thrust bearing in the repair kit as opposed to the color of the original VSS rack's thrust bear (white/yellowish). |
ReMiii4021.50 |
07-28-2021, 07:30 AM | #7 |
Rep 1,363
Seems like ZF might have picked the better of the two materials. As for the steering rack itself, it is the Thyssen rack that develops the problem. The fix is a Thyssen fix as well. More importantly, did your steering rack clunk when turning the wheel left and right 10 degrees when the car is off? That is the test for a worn thrust bushing. If the car made no noise, I’d conclude the thrust bushing is not the problem. If you did get the clunk during the test and there is no repair kit for the ZF, that would suck. Does it mean the ZF rack needs replacement? I hope not
07-28-2021, 01:05 PM | #8 | |
Rep 3,940
07-29-2021, 10:12 PM | #9 | |
Rep 1,363
Just like previous 3 series, it seems like the current car is destined to become a cursed rattlebox. I guess podcasts and SiriusXM are going to have to keep my mind off it.
07-30-2021, 06:35 AM | #10 | |
Rep 3,940
07-30-2021, 10:21 PM | #11 |
Rep 1,363
They are original. Might be time for a swap. But I do have some positive news. I swapped out the front thrust arm bushing for millway’s street monoballs today and the thunk is much diminished. It doesn’t seem like the origin of the thunk is gone but the older bushings were making the problem worse. It may indeed be the struts but at 80,000km it seems early for them to begin to die….
08-01-2021, 07:46 PM | #12 | |
Rep 3,940
08-10-2021, 06:10 AM | #14 |
Rep 5
Hi, just to update,
After waiting for ages to get a spot by a reputable dealer they inspected it and found that both thrust arm bushings were the main cause so they replaced them on each side and some other small bushings. Since the car has extended warranty I only had to pay 10% of the price for parts. I've ben driving clunk free for a week now and I couldn't be happier. The only thing that I noticed is that the car feels a bit unstable on the highway, like when it's windy outside and it's pushing the car left and right. And with the steering it feels like there is a small dead zone in the middle. So I'm gonna guess they didn't do the best alignment and I'm gonna take it to a specialist that only deals with wheels and alignments and I'll update if that fixed it. Thank you to everyone that was replying |
08-10-2021, 08:03 AM | #15 | |
Rep 3,940
10-27-2021, 11:22 PM | #16 |
Rep 1,363
Finally fixed the front end clunk. What a relief. It was the left side front strut. Swapped out with after market struts. Much improved handling and clunk is gone.
Polo088161604.00 |
10-28-2021, 07:11 AM | #17 |
Rep 3,940
My issue turned out to be the control arms I bought from RockAuto under the Delphi brand. Go with original unless Lemforder or Meyle HD are options.
10-28-2021, 08:25 AM | #18 | |
Rep 1,363
Question: Have you being hearing of issues with non-BMW branded OEM parts prematurely failing? I've had a couple of mechanics tell me some of the of their most reliable OE suppliers have been sending parts that have failed prematurely.
10-28-2021, 08:35 AM | #19 | |
Rep 3,940
I ended up ordering through FCP Euro because I know there's a good chance I'll have to replace these control arms again later on down the road when they wear out after 50+k miles. |
04-19-2022, 06:49 AM | #20 | |
Rep 1
Thanks! Last edited by amico_polacco; 04-19-2022 at 07:21 AM.. |
05-08-2022, 02:51 PM | #21 | |
Rep 5
The links expired but I generated new ones for you. Hope it helps. https://drive.google.com/drive/folde...ui?usp=sharing |
05-08-2022, 03:00 PM | #22 | |
Rep 3,940
