08-25-2020, 05:40 AM | #1 |
Rep 1,579
Run flat tire recommendation
When I bought my 2012 328i, I immediately replaced the factory run-flat tires with traditional tires. Mainly because of the road noise, but also because of the bumpy ride. That was 7 years ago. Now, I heard that ruin flats have improved considerably as far as quietness and softer on bumps.
What run flats would you recommend, or had luck with that are quiet and offer a comfortable ride? Last edited by fe7565; 08-25-2020 at 05:43 AM.. Reason: tires run flat 328i noise |
08-25-2020, 11:54 AM | #2 |
Rep 10,256
All run flat tires generate more noise than go flat tires. As the tread wears off, run flat tires generate more noise. It's only a question of what's acceptable by your own standards.
Bridgestone Potenza S001 are harsher than other run flat tires. I suggest to exclude these from consideration. I prefer run flat tires due to convenience. My car is on the second set of Pirelli P Zero summer performance tires in OEM size. Please note that these tires will last about 25K miles. |
fe7565552.50 |
08-27-2020, 09:14 PM | #3 |
Rep 1,579
Thank you for your input. I use 225/50-17 PIRELLI CINTURATO P7 tires. They are really good in cornering, no hydroplane in rain (until about 30K-40K) quiet, and last very very long time 40K-50K. But I blew two of them because of the lousy potholes in my high-tax city where money does not go into fixing public roads. Both tires had a huge bubble in them in the side.
08-30-2020, 12:55 PM | #4 | |
Rep 3
Some that I know of are not newer than 7 years, including the: Pirelli Cinturato P7 All Season Run Flat (originally supplied) Pirelli Cinturato P7 Rujn Flat (summer tire, not all season) - improvement in performance over the Pirelli Cinturato P7 All Season Run Flat a few Bridgestone and Continental models |
fe7565552.50 |
08-31-2020, 06:20 PM | #5 |
Rep 2,805
Drives: F33 430 and F39 M35i
My ‘18 came with 18” Bridgestone Driveguards and they were a big improvement over whatever Bridgestones I had on my ‘09. I always switch to goflats anyway. But I will be putting Driveguards back on when I give my daughter the car next month for her 18th birthday
fe7565552.50 |
09-01-2020, 09:09 AM | #6 | |
Rep 495
The only difference in run-flats vs go flats is that run flats have thicker sidewalls. Summer tires are usually loud, and 19" summer tires are going to be louder than 18" grand touring no matter their construction. |
09-14-2021, 02:59 PM | #7 | |
Rep 1,579
09-15-2021, 03:03 PM | #8 | |
Rep 495
09-15-2021, 03:22 PM | #9 | |
Rep 1,579
Now, why don't you tell us about your experience with run-flats since I am looking for one that is quiet and corners well. What do you recommend and how does is stack up based on your experience with run-flats vs go-flats? By the way: I put 35,000 miles on the go-flats Pirellis (each set), but had two bubbles in them because of potholes. I figured run-flats would have fared better but seems like they are just as prone to that. Last edited by fe7565; 09-15-2021 at 03:29 PM.. |
Stuart j55.00 |
09-15-2021, 04:09 PM | #10 | |
Rep 495
I've never noticed a particular difference in tire noise between 18-19" sets on my Mk7 GTi or 340i. I've had Conti EC Sports, Conti EC DW, Michelin A/S 3+, Bridgestone S-04, S-001 run flats (came on the 340i when bought), and my winter set of Pirellis Sottozero 3 RFTs. They're all about the same subjectively, with the all season Michelins probably being the loudest. Tire noise is due more to tread pattern than sidewall thickness. |
fe7565552.50 |
09-15-2021, 07:58 PM | #11 | |
Rep 1,579
Let's leave it at this: your subjective hearing is different than my my subjective hearing when it comes to tires. This was back in 2013, and it was my first ever run-flat tires. As a matter of fact I wasn't even aware that these were run-flat tires until started to wonder why they are so loud and handled differently. The replacement go-flat tires were the same brand and model as the OEM run-flat ones (Pirelli Cinturato All Season) and the difference was immediately noticeable. Handling also improved as I expected since I had an X3 prior to buying this 328i. Again, I could post various links by Edmunds, Bimmerfest, etc on noise and handling, but I am not here for a pissing contest. I hoped (and heard) that run-flats got much better since. I came back to this thread because I am looking into going back to run flats after the two bubbles incidents in the regulars tires. Will check into the brands you listed that worked for you. Since you have 18-19 in tires, not sure how much of that translates into my 17 in tire size. |
09-15-2021, 08:35 PM | #12 | ||
Rep 1,641
fe7565552.50 |
09-15-2021, 10:13 PM | #13 | |
Rep 282
09-16-2021, 09:56 AM | #14 | ||
Rep 1,641
Anyway, just my thoughts for what it is worth. |
fe7565552.50 |
09-16-2021, 05:54 PM | #15 |
Rep 1,579
Thank you fo the inputs. I also read that increasing the run-flats at least +2 but as high as 36/38 does make a huge difference in handling for sure, and noise for some. But was not aware about lasting measurably longer...although makes sense: less contact with surface means less wear. Of course, overinflating will wear out the top/middle fast.
So need to monitor wear for a while after finding the proper pressure. One thing that helped me with even wear tremendously was paying for a good laser alignment after mounting new tires. I am usually cheap, but that one paid off in the past with two subsequent sets of tires by adding about 10K miles more to 30K miles of previous life on same part number. |
09-16-2021, 06:04 PM | #16 | |
Rep 1,641
fe7565552.50 |
09-17-2021, 05:13 PM | #17 | |
Rep 495
