12-21-2021, 12:38 PM | #23 |
Rep 416
I got this one (I have an M Sport) and I am very satisfied with it. Basically it is a tight fitting rubber sleeve/pouch in which you put the key fob and a quite heavy metal frame, which consists of two halves that are screwed together. It is a very exact fit and makes the fob looks and feel a lot more premium because of added weight and touchy temperature. You have to press the buttons quite hard as they are under a thick layer of rubber. Had mine for a couple of months now and it's holding up very well. Just a few minor scratches and that's because I sometimes have it in the same pocket as my home keys.
I did remove the weird round thing on the hanger and replaced it with an epoxy round M-Sport badge. First I put an epoxy BMW roundel but that did not look good with the closing button being an emblem already. You can find these all over Chinese websites, ebay etc. Feels like very good value for money. Last edited by MidtownMike; 12-21-2021 at 12:45 PM.. |
12-21-2021, 01:25 PM | #24 | |
Rep 708
https://www.aliexpress.com/item/1005002673588496.html |
12-21-2021, 05:14 PM | #25 | |
Rep 18
Btw, I'm getting this cover from Etsy. Totally handmade & can be custom made, wth any accents or no accents & personalization |
12-21-2021, 05:17 PM | #26 |
Rep 18
Have you guys seen the Auto Addictz key fob covers? I know they make an aluminum one for the blade keys, but I think they might also make this for the F series gen of keys
12-21-2021, 05:53 PM | #27 | |
Rep 708
12-21-2021, 06:35 PM | #28 | |
Rep 18
I saw another guy in a X5 thread say he got his roundel off, his key was like mine, but it had the black plastic buttons with the metal trim on the sides. My key is the key has all aluminum trim & buttons (dunno if it's built differently & you're not able to change out buttons/logo on it?) And yes, I went ahead & ordered the black leather key cover with the M thread accent on the side. That should be in next week |
12-21-2021, 09:27 PM | #29 |
Rep 708
I don’t know but if my key fob is that banged up (not just the roundel, but overall fob), i would just buy a brand new housing, transfer the alarm electronics and the blade key to the new housing, and done with it.
Not sure why you want to make your life so difficult by pulling out the roundels when there is an easy way to replace the whole housing… |
12-21-2021, 09:37 PM | #30 | |
Rep 18
Is transferring the guts of the key to a new housing complicated? This is the 1st I've heard of this. I know all about changing out the battery & the roundel...didn't know you could swap out the guts (I've heard to steer clear of the cheap "replacement keys" on eBay, etc because they're not programed for your car. There was never any further discussion of buying a replacement key & just swapping out the guts.) Is eBay the place to find a replacement housing, or are these mass produced & sold elsewhere? |
12-21-2021, 09:58 PM | #31 |
Rep 2,815
Drives: F33 430 and F39 M35i
If my keyfob was banged up, I’d just go about my day as long as it worked.
I can’t remember the last time I actually touched a button. Comfort access is a wonderful thing. It goes in my pocket at the beginning of the day and comes out at the end. |
12-21-2021, 10:16 PM | #32 | |
Rep 18
Lol, agreed! I hardly ever *use* the key...well, I use it to get into my trunk because for the life of me I CANNOT get my trunk to open using my foot (and yes, I've tried all the tricks mentioned & it's not valet locked - I double checked that today.) Maybe it's because I'm a woman, LOL...I use a Louis Vuitton coin case/key chain for all my keys, including the car key. I just hate how the logo was worn down the bare metal & now it looks doubly worse because of my efforts trying to pry it off like was possible on previous BMW keys. I've got a nice black leather with M stitching fob cover coming, so I'll most likely just put the replacement key fob logo over the scratched up logo. Since this key is the full metal version, I'm leaning towards the logos on these keys not being removable. |
12-22-2021, 02:41 AM | #36 |
Rep 2,815
I actually got these cheapo covers for my f33 and f39 so the buttons wouldn’t get pushed by other stuff in my pocket.
12-22-2021, 07:58 AM | #37 |
Rep 16,140
I don't have CA, but my fob still stays in my pocket. It took maybe a week for me to know which button was which by feel alone without having to look at the fob.
12-23-2021, 03:03 AM | #39 |
Rep 1,509
There's a TSB about setting the remote trunk release so it doesn't work unless the car is unlocked. I took it to the dealer and they did it for no charge under warranty. I couldn't figure out how to do it myself.
12-23-2021, 04:42 AM | #40 |
Rep 5,458
Drives: F30
Used a rubber band for a couple weeks to help the Nappa leather form to the key.
12-23-2021, 05:27 AM | #41 |
Rep 18
12-23-2021, 05:28 AM | #42 |
Rep 5,458
Drives: F30
Technical Service Bulletin
12-23-2021, 05:57 AM | #43 | |
Rep 5,399
To solve the trunk opening issue, I used BimmerCode to set my trunk not to open unless I'm in range and hold down the trunk unlock button for 10 seconds. I also used one of these leather key protectors. It really prevents the key wear and tear that has been a problem with my other cars. It helps prevent keys from being accidentally pressed in my pocket. https://www.kiesmotorsports.com/prod...8;_ss=r?aff=22 |
12-23-2021, 07:42 AM | #44 |
Rep 16,140
It also will wipe any coding you've done and remove some coding options, like the number of turn signal blinks with a half swipe of the turn signal stalk. I passed on two years of prepaid (there's no such thing as free) maintenance so they couldn't screw up my coding.
johnung4535.50 |
fob, key, trunk |
