10-18-2019, 02:08 PM | #1 |
Rep 4,131
FBO: Logs
Guys, I’m getting a nasty cut out on pump fuel - it started with my JB4 MAP5 a few weeks ago. I didn’t use the logging capability at the time, so I didn’t know what happened, but it was like hitting a flat spot while at WOT.
I thought it was because I was aggressive, doing multiple runs in a quick succession at the drag strip, as it never happened before or afterwards. Fast forward to this week, I get an amazing tune from StageFP, which is head and shoulders above anything I had with the JB4. But then I ran into an issue - the car cut out pretty violently At WOT, setting of the CEL for misfires. Checking the logs, the car’s fuel pressure dropped off hard. I sent the log to Bob, and he backed off the tune. The new one feels comparable to the JB4 in terms of power, but smoother. I did a few runs on this map, and all seemed fine, but then the issue reared it head again. This time, I noted that the fuel gauge was just under 1/4 tank, and I got a log to capture it. It’s never happened on the stock tune, but it happening more frequently now, even on a less aggressive tune. Any way to test the fuel pump itself? I have no plans for PS2 turbos, and port fuel injection - I just want my car to work. What can/should I do? Edit: Logs https://datazap.me/u/amuroray/stage-...og=0&data=3-17 https://datazap.me/u/amuroray/stage-...og=0&data=3-17
Mods: Yes.
10-18-2019, 04:07 PM | #3 |
Rep 4,131
10-18-2019, 08:48 PM | #5 |
Rep 1,115
I wouldn't worry about the LPFP and there's no reason to get an upgraded one unless you're going port injection. Run it hard at a full tank and see if the issue happens again.
10-19-2019, 10:34 AM | #8 |
1296
Rep 3,532
Ive never had an issue
2015 335i xDrive 10.95@124.99mph w/bm3 - SOLD 2015 X3 x35i pwg 12.96 catless w/bm3 stage 2 93 ots IG: @n55david For pics and updates! Youtube: @ n55david For videos or Racing etc |
Phyrexia502.50 |
10-19-2019, 02:52 PM | #9 |
Rep 1,115
335 has a different fuel tank than the M235i. People have had issues on track days with these cars going into fuel starvation at low fuel level. I haven't had the problem myself, but I usually avoid beating on the car when it's below 1/3 tank to avoid it.
10-20-2019, 03:02 PM | #10 |
Rep 4,131
How do I post logs? Found it
https://datazap.me/u/amuroray/stage-...og=0&data=3-17 https://datazap.me/u/amuroray/stage-...og=0&data=3-17 Last edited by AmuroRay; 10-20-2019 at 03:11 PM.. |
10-21-2019, 11:44 AM | #11 | |
Rep 4,131
10-21-2019, 12:20 PM | #12 |
Rep 1,499
Yeah man your HPFP takes a shit on both those logs. In the first log, it craps out at 4700rpm, dropping down to 1490psi when 2890psi is requested. The second log you take a big hit at 6197rpm, pressure dives to 1397psi when 2899psi is requested. You either need a new or upgraded HPFP or reduce the boost target. Is this a 93 octane tune or ethanol mix?
AmuroRay2267.50 |
10-21-2019, 01:27 PM | #13 | |
Rep 4,131
It痴 a 93 octane tune - do you think that I知 in need of a HPFP or a LPFP? |
10-21-2019, 02:06 PM | #14 |
Rep 1,499
Honestly, it's hard to diagnose. I don't think fuel pressure target, pre-HPFP can be logged. If so that would be cool because you could look at the output of the LPFP vs the target. A large delta here would point to an issue with the low-pressure side supply. If your fuel pressure, low side, is good then you would know it is an issue with your HPFP.
If might be worthwhile to pay the $150 diagnostic fee to a reputable BMW mechanic and have them test both your low pressure and high-pressure fuel supply. You could do it yourself but need some special tools. Also, I don't know about MHD, but with bm3 there are some additional parameters you could log to give you some insight. LPFP (Raw) LPFP Sensor Voltage (should be between 0.5-4.5 volts) Overview of the fuel system https://www.newtis.info/tisv2/a/en/f...ystem/F7eAStOK https://www.newtis.info/tisv2/a/en/f...ystem/F7tmyyiA Testing Procedures https://www.newtis.info/tisv2/a/en/f...th-drive-line/
10-21-2019, 02:28 PM | #15 |
Modder of everything I own
147
Rep 491
What codes did it throw? when my HPFP was going out it gave me 110001, 11A031 and 11A002 for fuel pressure and also 193001 for fuel level sensor. No misfire codes
2013 BMW 335xi F30 N55 PWG/VRSF DP/ER CP/Injen CAI/AA FMIC/JB4 map 7/Fuel= E50 w/ E85:93oct/Stock LPFP & HPFP/CATuned coilovers/Megan Racing Rear Swaybar/Powerflex Rear Subframe Bushing Inserts/Dual aFe Power Mach Force Mufflers/Resonator Delete/MHD & BMS Race BEF
10-21-2019, 04:01 PM | #16 |
Rep 4,131
10-22-2019, 08:13 AM | #18 |
Rep 1,499
118001 - mixture control: mixture too lean
Makes sense being that your rail pressure took a dive.
AmuroRay2267.50 |
10-22-2019, 08:22 AM | #19 |
Bmw Inside
50
Rep 210
I would look into the upgraded HPFP as its basically maxed out stock AFR's are probably being sent through the 200's which is mostly air no fuel the HPFP in the car now probably can't handle higher end tunes.
heres the upgraded pump sadly its the only one on the market right now for N55's so its quite expensive. http://tuningtechfs.com/ttfs-xdi-35-...grade-for-n55/ |
AmuroRay2267.50 |
10-22-2019, 02:19 PM | #20 | |
Rep 4,131
10-22-2019, 05:00 PM | #21 |
147
Rep 491
You have the same HPFP as me, stock turbo (mine is 335xi, don't know if we have the same turbo but mine is stock) and I am running JB4 Map 7 and MHD with BMS Race BEF, I run e50-e60 I am FBO and I have no issue with fueling so I don't believe you are maxing out your HPFP if I'm not unless I'm missing something, which I may be.
10-22-2019, 06:18 PM | #22 | |
Rep 1,105
Any current logs you can share for comparison?
435i M-Sport | Pure Stage 2 Turbo | MHD Tune | XHP Stage 3 | Wagner Comp Evo 2 | MPE | Evolution Racewerks CP/DP/TIC | M-LSD | XDI-35 |
