08-04-2017, 10:55 PM | #1 |
Rep 295
Pretty sure I popped my motor tonight
Replaced my slightly leaking oil filter housing gasket tonight and broke one of the 3 bolts that fastens in to the block (think my torque wrench is out of spec). Thought it would be okay to drive to a nearby hardware store to buy a temporary replacement. I was mistaken! The housing seperated from the block under acceleration and spewed out oil. The engine then shut off and would not restart. I get a starter/ignition error when i attempt to start it. Sounds like the starter is trying to rotate but the motor is seized. Does this sound accurate? What are my options engine wise? I'm not aware of any known bmw engine rebuild specialists in the Maryland area, but the block is probably toast anyway.
thanks, Chris |
08-05-2017, 07:10 AM | #2 |
Rep 104
Wow that sucks! You seem suprisingly calm about this. Anyways I would reccomend taking a look at car-part.com. Its all used stuff but in my area there are a lot of sub 30,000 mile engines.
08-05-2017, 07:24 AM | #3 |
Mike: Everyone's Pal
2044
Rep 2,972
Drives: F80 M3
Well see if it's better off getting an m3 now, because apparently, getting a new motor will be more than a base m3.
Alpine MSS Stage 2+ E30 tune|MST Intakes|VRSF Single Mid Pipe|Agency Power Intercooler|VTT Full solution crank hub fix |
08-05-2017, 09:05 AM | #4 | |
Rep 295
08-05-2017, 09:05 AM | #5 |
Rep 58
It wouldn't just instantly seize, if you stopped the moment the housing separated you should be fine. If you kept driving with no oil pressure for 5 minutes, thats a different story. Did you over heat? Were there any oil pressure lights? You can try spinning the crank manually with a tool to verify if the motor is seized.
08-05-2017, 09:08 AM | #6 | |
Rep 295
08-05-2017, 09:11 AM | #7 | |
Rep 295
08-05-2017, 12:50 PM | #8 |
Rep 709
Are you sure it's not simply the ECU disabling your engine from starting in order to preserve from seizing? Also if in MD, maybe talk to Frank Smith, he could be able to help you out.
Current: 12' E70 X5D | 04' Yamaha Warrior
Past: 13' Audi S6 | 13' E70 X5M | 13' E92 M3 Comp | 14' BMW 335xi GT | 95' E36 M3 | 84' BMW 733i | 06' Porsche Boxster S | 15' Jeep Grand Cherokee | 06' Acura TL | 85' Honda Shadow VT700 | 05’ Yamaha R6 | 12’ Triumph Tiger |
sly1types431.50 |
08-05-2017, 01:38 PM | #9 |
Rep 1,782
Getting a man F30 motor will not cost you 60k. Fym. Lmfao
13' 335i M Sport. EBII/Coral Red 6MT. RPI GT exhaust, Resonator delete, PS1, GFB DV , BM3 Stage 2, ER CP, VRSF DP, VRSF 5.5in Stepped FMIC, Dinan Shockware. Carbon M Performance rear diffuser. M4 trunk lip. Conti DWS06 225/40/19 and 255/35/19
08-05-2017, 01:39 PM | #10 |
2044
Rep 2,972
Drives: F80 M3
I know it was a joke referencing that other thread..that no one got
08-05-2017, 02:10 PM | #11 | |
Rep 295
08-05-2017, 02:59 PM | #12 | |
Rep 1,782
08-05-2017, 08:21 PM | #13 |
Rep 488
2013 ActiveHybrid 3 (335ih) • N55 PWG • Meisterschaft GT catback • Wagner tuning catless DP and Stage 2 Evo Comp Intercooler • ER chargepipes • CTS intake • io2V3 O2 simulator • Pure Stage 2 turbo with high-flow inlet and DV upgrade • Fuel-It Stage 2 LPFP • JB4 ISO firmware • Fuel-It DIY PI Kit • bootmod3 •
08-05-2017, 10:30 PM | #15 | ||
Rep 709
08-06-2017, 02:44 AM | #16 | |
Rep 295
08-06-2017, 02:49 AM | #17 | |||
Rep 295
08-06-2017, 11:17 AM | #18 | ||
Dejan
1753
Rep 4,197
Drives: 2018 Audi S3
Don't take this the wrong way, but you have one less fastener on your oil filter housing (lifeline of lubrication along with oil pump to your motor) but you felt the need to go "full tilt" or WOT why the hell would you do that on a partially fastened oil filter housing?? You noticed the car didn't like the first WOT run and you persist to stay on it or try again? This really confuses me... And you aren't aware where the jb4 or the BT device is located? Did someone else install this for you? Forgive me if I'm jumping to some type of conclusion but this just seems a tad strange to me. Since you have an E93 m3 listed in your sig, are you running an F30/32? Is it on a PS2 upgrade since you're seeing 21psi? You realize the stock t map is only good for 20-21 psi and it would shut your car down into limp if you hit that. If you're on a stock turbo how the hell are you seeing 21psi? Meth?? I've just seen a lot of things in this forum over the years and I just need some clarification I guess. :
FBO-PS1 and stuff
08-06-2017, 05:32 PM | #19 | ||||
Rep 3,947
This thread proves common sense is not quite so common. Last edited by Polo08816; 08-06-2017 at 05:39 PM.. |
08-06-2017, 06:43 PM | #20 | |
Rep 463
08-06-2017, 07:37 PM | #21 | ||
Dejan
1753
Rep 4,197
Something ALOT more is at play here than meets the eye. Hardware store for an automotive metric M8x25 with an E socket fastener or even more rare if it's main oil housing M8x28-M8x43-M8x78 ( for a foreign car at that) common man. How are you so sure and know the motor is seized up but you don't know where the BMS Bluetooth module is located? Which gasket was changed? 11428637821 or 11428637820? 21psi statement is a dead giveaway IMO.
FBO-PS1 and stuff
08-07-2017, 10:35 AM | #22 |
Rep 351
modern engines running modern oil don't seize after being without oil for a couple of minutes. there's something else going on here.... actually there are probably several things going on here based on the crazy description of what happened lol
2013 335i M-Sport 6MT, MPE, VRSF CP and IC, BM3 Stage 1
2006 330i 6MT, Sport Package - sold |
