09-30-2017, 06:59 AM | #23 | |
Rep 366
435i Gran Coupe | ///M Sport Pkg | 430hp | MHD Stage 2+ | BMS Intake | Catless Downpipe | FMIC | Black Sapphire exterior | 9H Ceramic Coating | Black Anthracite interior | 19" Black ///M Wheels | Red ///M Brake Calipers | ///M Steering wheel | ///M Metal Pedals | Alcantara dash panel | Carbon Fiber trims and gear knob | Angel Eyes LEDs | Surround Cameras | Spoiler | Coded ///M iDrive, Mirrors, HUD |
09-30-2017, 08:49 AM | #24 |
Rep 1,876
But backing in is how you get a nice and easy getaway! Always park to leave easier. She dominates the garage spot anyway. :
Mine: BSM F30 335i M Sport
Hers: AW F30 328i M Sport |
LiquidMercury212.50 |
09-30-2017, 11:16 AM | #25 |
Rep 589
Mountain_Commando303.00 |
09-30-2017, 12:40 PM | #26 | |
Rep 190,777
09-30-2017, 01:48 PM | #27 | |
Rep 589
I've read more positive feedback on the RC, but I'm not investing in it myself. |
09-30-2017, 10:26 PM | #28 |
Rep 366
I got the RC mainly due to ease of installation (plug and play into the MAP sensors rather than the ECU) and because they are licensed sellers here in Oz.
10-01-2017, 07:09 AM | #29 |
Rep 115,980
10-01-2017, 07:11 AM | #30 | |
Rep 115,980
Mike |
10-01-2017, 06:00 PM | #31 | |
Rep 589
10-02-2017, 02:13 PM | #32 | |
Rep 547
FABSPEED high flow cat- no CEL, great sound ER charge pipe ER intercooler JB4
2014 435i xDrive M-Sport, Fabspeed cat, Active Autowerke axle back, CTS Turbo intake, ER charge pipe, ER Competition Intercooler, MHD Tuning Stage 2+
10-05-2017, 08:42 AM | #33 | |
Rep 115,980
With second hand tunes you have to be careful. We have seen a lot of fried boards and damaged harness's recently. (from second hand purchases) Mike |
10-14-2017, 09:27 PM | #34 |
Rep 366
Hey fellas,
Will this pipe fit in my 435i GC?: http://cgi.ebay.com.au/ws/eBayISAPI....m=162520693186 Just to make sure before I pull the trigger. Thanks.
10-14-2017, 09:51 PM | #35 | |
Rep 366
https://www.knfilters.com/search/pro...x?prod=33-2997 How does this differ from the cylinderical/conical filters? Which one's better for more power?
10-15-2017, 09:33 AM | #36 | |
Rep 6,990
This particular filter is one that uses an oiled-cotton filter element, which allows more air to pass through than the OEM paper type, but can also allow more dust and dirt to pass as well. These filters tend to "dry out" and need re-oiling fairly soon, but they are less restrictive. As far as the shape versus power goes, there is no significant power advantage to be gained from either design on a forced-induction engine. The stock intake with one of these filters will perform equally as well as one of the cone-filter models, including those that are enclosed in a housing (such as those sold by AFE). The cooler the intake air, the better, so any model that remains on the left (intake) side of the engine is better than one that is placed on the exhaust side. That said, the air has to pass through the turbo on our cars, which will be quite hot, and the intercooler is what ultimately cools it back down before entering the throttle body. Again, normally-aspirated engines gain more benefit from these aftermarket intakes than our turbocharged engines.
10-15-2017, 08:40 PM | #37 | |
Rep 366
So if I wanted to go with the cone filter (just for looks), how would that work?
10-16-2017, 06:56 AM | #38 |
Rep 6,990
Depends on if you get the open one or the enclosed one. The open one will not be a "cold-air" intake, as it will suck in underhood air. If you get the enclosed one, it will likely breathe through the same opening near the front grille that the stock unit uses. Check the AFE website and look at the different models they offer.
10-16-2017, 08:41 PM | #39 | |
Rep 366
Or is there a way to squeeze in a cone filter into what looks like a rectangular air box on the N55 engine?
10-18-2017, 09:46 AM | #40 |
Rep 6,990
There is no "cold air intake pipe" for open-style cone filters- they draw air from under the hood on the intake side of the engine, whereas the closed systems will draw it from the same opening behind the upper left grille as does the stock unit, although the Dinan intake includes a "snorkel" to draw air from the area in front of the left front wheel and behind the small left-side lower grille.
10-31-2017, 06:42 AM | #41 |
Rep 366
Hi guys,
I installed the BMS high flow intake and a catless downpipe. Here are my observations: 1. First installed the intake. No noticeable power gain (as expected), but turbo spool sound was prominent and unmistakeable when flooring the throttle. 2. Installed a custom catless downpipe today. The good: Turbo spool sound is MUCH louder and more frequent (is that normal?). Can hear some popping on downshifts. The bad: First pull attempt was very hesitant and jerky. So I turned my Racechip setting down from F to E and that eased the jerkiness a bit. Turned it down further to D and that seemed to help some more. Still have extreme hesitation (1-2 seconds) if I go to WOT from a rolling start in Sports mode. Doesn't feel like I've gained any power due to the downpipe in fact feels like I lost power....though maybe it only feels that way because of the hesitation (before the pipe, the response was immediate and authoritative). I'm wondering if I should give the Racechip/ECU some time to get used to the new pipe, or just dial the setting down even more (stock setting was B, currently at D)?
11-01-2017, 06:50 AM | #42 |
Rep 366
Hi guys,
I eventually fixed the issue, thought I'd report my solution. I first tried unplugging the MAF sensor. This made the car run even worse. So I plugged it back in, and unplugged the Racechip. This immediately smoothed out the ride (sans the extra power that Racechip used to provide of course). So that confirmed that Racechip was the culprit. Thereafter, I dialed down switches S2 and S1 all the way to stock settings, and there was no more jerkiness/hesitation. Then I experimented with half a dozen different settings before eventually settling on B1 (stock was B0). With that done, finally did some pulls and enjoyed them immensely. Butt dyno registers a noticeable albeit small increase over pre-intake/pipe. But the sounds are pretty sweet. Turbo spool sound is unmissable even with windows/sunroof fully closed. And for the first time ever, I'm hearing a mean burble on downshifts. It finally sounds and feels like a true sports car, whilst earlier it sounded like just a fast but quiet sedan. Cheers.
01-17-2018, 06:17 AM | #43 |
Rep 366
Hey guys,
Quick question which is probably related to my catless DP. Back when I'd installed the catless DP, I got a CEL which was as expected. I just ignored it and didn't notice any negative effects. Last week I put in an MHD tune and it removed the CEL. But a couple days later, the CEL came back. I used the app to read the fault code, and it says "12B104 - Oxygen sensor heating before catalytic converter activation, Line disconnection". So is code this what one would get from a catless DP anyway (and thus I can ignore it), or is it something else that warrants concern? Cheers.
11-21-2019, 06:37 AM | #44 | |
Rep 474
J. D. Cordier
