01-19-2020, 06:54 PM | #1 |
Rep 422
Drives: F87 M2 DCT, F15 X5
Passenger Side Heat Not Working - Tried Vacuum Bleeding Already!
Hello!
I recently purchased a 2012 F30 335i 8AT. Car has 94k miles on it. After purchasing, I noticed the passenger side heat does not blow hot. It will blow very cold and mild (~70-80F) when turned to the hottest setting. I do notice that when the car is static and the fan speed is very low that the air is warmer. I did some searching on forums and found that vacuum bleeding has shown to be successful for some. So I bought a Schawben bleeder off ECS tuning, and performed the vacuum bleed, which I added maybe 1/2qt of coolant. I continued to do the 12 minute electronic bleed and drove the car. No dice. Still blows cold, no improvement. So what shall I try next?
‘18 F87 M2 DCT
'17 F15 X5 xDrive35i M-Sport Sold in 2023 '12 F30 335i 8AT Sport Line Sold in 2020 '08 E92 335xi 6MT Sold in 2016 '08 E90 335i 6MT - FBO |
01-19-2020, 08:22 PM | #3 |
Rep 422
Thanks for the response. Have you experienced or heard of this problem before? Is there a way to check if the value displayed matches the value commended to the HVAC controller?
01-19-2020, 08:28 PM | #4 |
Rep 2,015
I have heard of this on my e90.
ok if you have ISTA programming tool, I think.....and I am not 100% sure, .... there is a way to test or move the valves through ISTA. This link might be a good start: https://f30.bimmerpost.com/forums/sh...d.php?t=696777 |
01-20-2020, 07:23 PM | #6 |
Rep 422
Did some diagnostic work today playing around with the climate control to understand more how it works and what could be wrong.
1. Do the blend doors work? I went to manual climate mode, front vents only, minimum fan speed. Turned each knob max hot to max cold a few times and listened/timed the blend doors. All the blend doors seems to be working correctly. On the passenger side, cold air turns to warm air (not hot). 2. Is the cabin temp sensor working correctly? I turned both knobs to max cold, then turned knobs to 61F (one click up) and each blend door actuated the same. Thought there is that 60F is max cold (no heat), and 61F is now the target cabin temperature, so the blend doors go to heat (its like 15F outside). Verified that both sides went from ice cold to heat (hot on driver side, luke warm on passenger side). So I have two thoughts on what is going on. 1. The passenger side blend door is working, but maybe not reaching full stroke. I am skeptical this is the case since both actuators are actuating for the same times and there is heat. 2. The heater core is clogged and is somehow bias to one side. Judging by F30 heater core pictures, it looks pretty simple. But I haven't seen a picture of how the air flows over it. Maybe the passenger side flows over the right side of the core which is clogged and limited/no flow. I think this is the most plausible and my next step will likely be to flush the core. Further, it seems at low fan speed the passenger side is gets warmer. I suspect the heater core is able to build more heat over the whole core, not just one side.
‘18 F87 M2 DCT
'17 F15 X5 xDrive35i M-Sport Sold in 2023 '12 F30 335i 8AT Sport Line Sold in 2020 '08 E92 335xi 6MT Sold in 2016 '08 E90 335i 6MT - FBO Last edited by E90convert; 01-20-2020 at 07:30 PM.. |
01-20-2020, 10:17 PM | #7 |
Rep 422
http://www.agcoauto.com/content/news/p2_articleid/121
Some good diagrams here on why my passenger side may be blowing cold if the heater core is clogged on one side. |
01-21-2020, 01:45 AM | #8 |
Rep 2,015
Good Diagnostic,
read this thread if you have not read it already? https://f30.bimmerpost.com/forums/sh....php?t=1460558 Possible heater core or air in the the coolant. |
01-21-2020, 02:12 AM | #9 |
Rep 276
I have the same issue on my 2012 335i n55 f30! Have done little research and nothing to fix it but I've heard that flushing the heater core works for most people. Definitely subscribed to this thread
03-02-2020, 11:47 AM | #10 |
Rep 422
Just an update. I ordered equipment from Amazon, just need the time to actually perform the work. If this works, I'll post a list of the equipment I purchased for future people with this problem. Maybe this weekend since the weather is above freezing.
‘18 F87 M2 DCT
09-20-2020, 03:41 PM | #11 |
Rep 3
Hey did you manage to fix this.
I have the same issue with my 335i. It just only started to get colder at night and felt that passenger side doesn't blow air at all in automatic. When in fan in manual it blows cold air. |
09-21-2020, 08:08 AM | #12 | ||
Rep 422
‘18 F87 M2 DCT
09-21-2020, 10:48 PM | #13 |
Rep 106
Hello everyone! If you have any questions about my procedure above that E90 convert posted, please let me know.
A couple tips I can add: Fill 3 gallons of Zerex 50/50 coolant for BMW in a clean 5 gallon bucket when refilling the system using the vacuum filler tool.(schwaben or OEM tools (OEM tools same, but cheaper) you have to overfill the bucket when vacuum filling to assure you have plenty of coolant to pull from so you don't suck up air. ISTA says this. Use Newtis.info - If you don't have ISTA for reference on how to perform this filling procedure. I would say the lisle heater core backflush tool is required because it seals perfectly at the end of the hoses you attached to the heater core. This perfect seal allows for optimal water pressure from your water hose to force crud from the system. Also when topping off the coolant reservoir after vacuum filling, remove the bleed screw on top completely while you topoff the coolant reservoir, then replace the bleed screw AND cap before performing the auto bleed procedure. Last edited by SilkySmoooth; 09-21-2020 at 11:01 PM.. |
10-27-2020, 08:44 PM | #14 |
Rep 422
So I did as described above, with a few deviations. I was not able to get the lower hose off the the heater core, it was seized on and I did not think it would be good to get aggressive and break the fitting. So I disconnected the lower heater core hose at the upper radiator pipe and was able to flush that way. Unfortunately I could only apply pressure to the upper fitting of the heater core. Not sure which direction it flows in vehicle.
Vacuum filled and then did the bleed procedure. After a few days of driving, I can say it helped with heat overall and a LITTLE bit on the left and right side. It is still noticeable to me that the passenger side is weaker heat than the driver side. Tolerable yes, annoying yes. Maybe next year I'll get ambitious again attempt to fix it.
‘18 F87 M2 DCT
06-02-2022, 07:45 AM | #16 |
Rep 74
Was this issue ever resolved?
Theres about a 10-15c difference between my left and right vents, measured via ISTA, and certainly noticeable by the amount of head (or lack there of) being produced. Ideally would like to find a way to resolve. Did a heater core flush at the workshop, but while that improved the situation, it didn't resolve it. |
