09-01-2020, 06:41 PM | #1 |
Rep 2,152
M-Sport Blue OEM Brembo Brake Kit (340/345 setup)
Hi everyone, Upgraded my brakes so I'm selling my old brakes, they are the blue M-sport brake option except with a twist. I originally had the M performance brakes so I kept the drilled/slotted rear rotors from that kit, then I got some Stoptech Sport Rotors in drilled/slotted pattern for my fronts to match the rear rotors. Pads are Hawk HPS 5.0, they create way less dust than the original pads. OEM brake lines included, and also old brake pads with brake pad sensors attached (pads are done). I've driven on this setup for around 14k miles and this should be a direct bolt on with everything you need for any F3x, please see pictures below for measurements of rotors and condition of brakes. NOT PICTURED - I'll give you new rear dust shields for the bigger 345mm rotor, I believe you don't need to replace it if you have x-drive. Original dust shields in the front already works for these rotors, so that can stay on. I AM NOT SPLITTING THE CALIPERS/ROTORS, FRONT/REAR, unless you find someone else to buy the part that you aren't buying. Looking for $1800 OBO picked up in social, not looking to ship at this point since it's super heavy. Last edited by Johnny250; 09-01-2020 at 10:03 PM.. |
09-01-2020, 09:44 PM | #4 |
Rep 2,152
if someone would take the fronts, sure.
09-02-2020, 11:10 AM | #6 | |
Rep 2,152
1000 shipped for rears |
09-02-2020, 11:20 AM | #7 |
Moto Lover
187
Rep 591
Drives: '19 BMW S1000XR
Bump for a local. Wish these were the 370mm fronts.
If you were selling just rears (picked up), how much are you asking? |
09-02-2020, 11:26 AM | #8 |
Rep 2,152
I can do 800, if someone buys the fronts though.
09-02-2020, 02:24 PM | #9 |
Rep 1,934
The front (340mm) come on 6cyl F3x stock. They are just painted.
09-02-2020, 02:56 PM | #10 |
Rep 2,152
yes I am aware of this. thank you.
09-03-2020, 12:31 AM | #11 |
Rep 24
Very interested in buying the whole set. I have a couple questions:
1) are these 370 and 345 mm rotors? Are they OEM bmw or another make? 2) cost of everything, including shipping to NJ. Thanks!! |
09-03-2020, 12:49 AM | #12 |
Moto Lover
187
Rep 591
09-03-2020, 11:15 AM | #13 | |
Rep 2,152
2. I can do $2050 shipped, but I rather sell local if someone wants to pick it up. |
09-06-2020, 08:58 AM | #14 |
Rep 424
Anyone know how much it will run to install these? Does this fit F36? Or the front need to be 370mm
//'17 F36 440i Mineral Grey
//MPPSK w/carbon tips //Apex ARC8 255/40/18 //MST intake //AutoTechnik brace |
09-06-2020, 12:40 PM | #15 |
Rep 2,152
To install this, could be anywhere from 350-700. Yes it fits F36, no the front doesn't need to be 370mm.
