07-06-2020, 03:55 PM | #1 |
Rep 26
liquid in amplifier
Hi, hope someone can help. I had a bottle of chemical toilet fluid that leaked in the boot and dripped onto the amplifier (basic audio only 2x2+2 subs). I now have no audio.
I have disassembled the amp, lightly washed the circuit board and thoroughly dried it out but still no audio. I'm hoping that some safety has cut out rather than component damage. Is there anyway to verify this or to reboot the system? Thanks |
07-06-2020, 03:57 PM | #2 |
Rep 63
I had mine replaced a few years ago under warranty due to water damage.
Never knew how the water got there in the first place but bmw said the unit had to be replaced. |
07-06-2020, 07:19 PM | #6 |
Rep 26
Its a small unit (Harman Becker HS B224) approx 3x4 inches that sits vertically at the back of the caddy. I think its just for the 2 subs whereas the HiFi unit has a separate larger amp and heatsink. I would be happy if I do actually have the HiFi option because that will open up a few other options when it comes to replacing the unit!
07-07-2020, 04:06 AM | #7 | |
Rep 385
Current:
Range Rover Sport - Alpina D3 Bi Turbo |
07-07-2020, 12:20 PM | #11 |
Rep 649
Crikey, that's an unfortunate and likely costly accident. Maybe get a bootliner as I've always done after a paint pot decided to leak and self-decorate the boot interior of an earlier non-beemer.
Hope you manage to sort it economically. Cheers Q
2018 440i Gran Coupe, MPPSK, Champagne Quartz, Ivory White, Adaptive Susp., Sunroof, Active Security, CA and a few other bits.
07-07-2020, 01:48 PM | #12 |
Rep 26
Boot liner sounds like a great idea! I've managed to clean it up mostly by removing the all the interior boot panels and giving them a good hosing down. Still has a bit of a smell about them but hoping that will fade in time.
I've seen a few amps on ebay so will pick up second hand. I didn't realise it would need coding in though. I will have to look up how to do that. Also worth following up that the unit is the basic as no tweeters. Thanks again all. |
