08-24-2019, 11:05 AM | #1 |
Rep 178
F30 (N55): Drivetrain Malfunction/Misfire
F30 gang: drivetrain malfunction & loss of power. I had what felt like a cylinder misfire last week and seemed to be losing boost yesterday. Frankly, it sounds like the typical blown/cracked chargepipe but I have an ER chargepipe so that shouldn’t be an issue here????
Note: full bolt on, with MHD Stage 2+ tune. Any thoughts?
2014 335i | 6 MT | M-Sport | X-Drive | MPE | Black Sapphire Metallic | Coral Red | MHD 2+ | DP/CP | KN Intake
09-30-2019, 05:38 PM | #4 |
Rep 178
Hey,
I finally got around to scanning the car, here are the codes that came up: DME ACTIVE CODES: 120308- CHARGING PRESSURE CONTROL, PLAUSIBILITY PRESSURE TOO LOW. 1FBD08 DME SHADOW (INACTIVE CODES): - 1FBD08 - DRIVING READINESS: MSA DEACTIVATION REQUEST FROM BDC. Thoughts? |
08-25-2020, 07:23 AM | #5 |
Rep 12
Did you end up figuring this out? I am on a custom tune off of MHD and my symptoms are on cold start (first start of day) my revs will dip low then pop back up. Almost as if it is about to die. Then the rest of the day no issues. Clear code it goes away.
10-09-2020, 06:28 PM | #6 |
Rep 23
Did you solve this issue?
boost leak, drivetrain error, power loss |
