10-16-2020, 08:25 AM | #1 |
Rep 199
Wagner 200 cel cat
Who has fitted a Wagner 200 cel cat to their n20 328i?
Did you find that the gearbox bracket does not line up and therefore is only secured via one bolt (top one)? Pic is of oem but that bracket is not secured. |
10-18-2020, 05:27 AM | #3 |
Rep 59
Drives: F30 328i RWD
Hey,
I've got the same DP on my n20. It's been a while since I installed mine, but if I remember correctly, I used a bolt and nut that I had lying around the garage. I don't know if Wagner actually provides one because my box was empty. But the bolt was a bit slimmer than the factory DP one and I had to "wiggle" and sort of jam it in. Then I used loctite on the nut because of vibrations that I was worried about loosening the nut. Good luck with your install. |
