08-03-2017, 03:34 PM | #23 | |
Rep 525
08-04-2017, 06:58 AM | #24 |
Rep 1,547
Drives: '22 Tesla MY + '23 Tesla MY
Sounds like it
| '22 Tesla Model Y P - My daily | '23 Tesla Model Y LR - Wife's daily | '17 F15 35D - missed daily |
08-05-2017, 08:32 PM | #26 |
Plenipotentiary
2614
Rep 3,046
Incorrect. Attached is the GFHB pattern from an ECE F30 LCI for reference.
08-06-2017, 09:29 AM | #27 |
Plenipotentiary
2614
Rep 3,046
Some actually do have shutters and it so far has been limited to mostly Hella supplied units. They are significantly different from the Walze used in the Bi-Xenon AFS units. The attached image shows a 1x1 Oslon SMD with Microshutters. They appear as a grid across the diode surface.
This isn't a guarantee. The F10 LCI LED have different part numbers but there is no hardware difference. US lights have the Microshutters but the operation of them is blocked. CAS will not issue a function release to ZGW as it is blocked by the VIN which includes the COP Region. Instead faults for Implausible Signals are generated. |
08-07-2017, 07:41 AM | #28 |
Rep 1,547
So this adds even more confusion. Almaretto kept insisting that the Euro and NA F30 headlights must be different because of different part numbers, but you say the F10 is the same.
The f30 has two different suppliers for the Euro LED headlights, Hella and Magneti Marelli https://www.schmiedmann.com/en/bmw-f...3-11-7-419-627 https://betaautoparts.com/product/f3...7-oe-original/ Which one of these should I purchase for coding with FLE?
08-07-2017, 12:35 PM | #29 |
Rep 8,364
The part numbers are not the only factor. It is known that the hardware is different.
08-07-2017, 12:47 PM | #30 |
Rep 821
My cars anti dazzle works. It may not be the full on system like in Europe, but it works. Never ever have I been flashed by on coming drivers. You can watch the lights dance & move out of the way. Another member contacted me on this forum for a ride along. Seeing is believing. I did a remote hook up with my coder so he could duplicate what he did for others. He said cars with LCA and LKA do not work because of different cameras. When I go to the dealer I tell them do not update my car, so not to lose the feature.
08-07-2017, 02:41 PM | #31 | |
Rep 8,364
08-19-2017, 03:38 PM | #32 |
Rep 190
This is actual for me as well. I've just created topic about this, but after that found this one already existing. So if we have FLE module only, so we only remove 2 values in FA and that's it? But system will not function as fully expected?
08-19-2017, 04:30 PM | #33 |
Rep 8,364
No. Coding requires VO and FDL coding. And yes, there is a difference between capable lamps and not. For example, and i3 with FLE is not capable.
08-19-2017, 08:02 PM | #34 |
Rep 190
But what VO and FDL coding is required in this particular case? I did VO coding to FEM_BODY and KAFAS2 modules, but what else is required? I appreciated if you can provide some details
08-19-2017, 08:20 PM | #35 |
Rep 8,364
08-19-2017, 11:01 PM | #37 |
Rep 8,364
08-19-2017, 11:58 PM | #38 | |
Plenipotentiary
2614
Rep 3,046
Attached is a Filtered composite I made of an isolated GFHB array with the Dynamic Shadow both Active and Inactive. The section within the Orange boundary is the problem and does not have a solution for this application currently. |
Almaretto2374.00 blue dragon1193.00 |
08-20-2017, 12:11 AM | #39 |
Rep 190
So should I then add back 5AP and 8s4 to FA to restore to original settings? What I don't clearly understand if this specific FA changes changed somehow operation of automatic high beam or no?
08-20-2017, 12:16 AM | #40 | |
Plenipotentiary
2614
Rep 3,046
Almaretto2374.00 |
08-20-2017, 12:24 AM | #41 |
Rep 190
08-20-2017, 04:05 PM | #42 | |
Rep 703
2018 M3 ZCP "Edition Velocity"
2018 X3 30i (wife’s) 2017 340i w/ MPPSK & Many M Performance Parts (sold) 2016 328i (sold) |
08-21-2017, 11:15 AM | #43 |
Rep 190
08-21-2017, 01:01 PM | #44 |
Rep 8,364
