04-24-2017, 12:49 AM | #1 |
lurker
Rep 222
Front Sway Bar for our F30 diesel?
I'm seeing compatibility for front sway bars only for the gasoline versions of the F30 on websites but it doesn't mention diesel (specifically 2014). Is it because the diesel is actually a different size than the gasoline version? If so, what are some aftermarket options for front sway bar to reduce the body roll?
04-25-2017, 12:02 AM | #2 | |
Rep 700
04-25-2017, 12:24 AM | #3 | |
lurker
Rep 222
04-25-2017, 03:53 AM | #4 |
Rep 700
04-26-2017, 08:29 AM | #5 |
Rep 520
Eibach have an upgraded anti roll bar kit available, you'll need to upgrade the rear as well to keep the balance of the car and not induce understeer. To get access to the front ARB you will need to drop the front subframe assembly so figure for around 4hrs work for a competent mechanic
https://www.kamracing.co.uk/manufact...30d-335-i.html Cheers |
