04-21-2020, 12:21 PM | #45 | |
Rep 2,302
In other forums, some users also said that the DME could also be flashed, but I don't think anyone ever did. Or no one has ever written what changes as a result. But maybe you want to try it. 350PS - yes that would be nice. |
xpro170.00 |
04-28-2020, 12:01 PM | #46 |
Rep 468
Does anyone know what is the typeschlussel for Alpina EGS on an 640D 2016 ( F06)
The XA71 does not work! I tried all possible production dates and istep and I cannot get it to load. Also does anyone know if SWFL.xx210B is the same for all Alpina EGS models? As in D3 and D5 Thanks |
04-28-2020, 03:04 PM | #47 | |
Rep 2,302
8HP70 F3x 210b 8HP50 F3x 1EE4 F11 LCI - 5D71 F10 - 5D51 F11, F06 - XB71 1211 F10 - XA71 1211 F31, F36 - 3E51 , 8K72 for cars from 2016 (Thanks to xpro for finding out) F32 - 3R51 (geht nur beim F32 scheinbar) F36 - 3E51 F25 - WY71 0316 (swfl 210C) |
04-28-2020, 03:32 PM | #48 | ||
Rep 468
Thank You! I will try this tomorrow |
05-10-2020, 05:24 AM | #49 |
Rep 56
Just seen this any the newer model is there any reason or benefit to re flashing with Type Code: 8K72 ( in conjunction with 9XA & 920 Alpina Package code) if flashed previously with 3E51.
Cars 335d xd lci |
05-10-2020, 05:54 AM | #50 | |
Rep 2,302
There will be no difference. |
05-10-2020, 08:37 AM | #51 |
Rep 56
08-18-2020, 07:03 PM | #52 | |
Rep 7
Did you or anybody ever try the Alpina DME😁? Also 8K72, will that work for a 2017 335d F30 Saloon or have they got a different typeschlussel |
09-04-2020, 06:25 AM | #53 | |
Rep 468
8K72 works fine with LCI models, theres no need to change any dates,etc After all, this is only for simplicity of flashing. All Alpina EGS software will be using identical firmware for all models across the f3x range |
03-07-2021, 06:52 AM | #54 |
Rep 1,992
Drives: F30 335d
Thanks Xpro for finding out the type code for LCI models. I was trying to flash my mates car (2016 f31 lci) and I was having the same experience as you - all modules in blue and SVT calculation not working.
I'll update my original guide too. For anyone contemplating the alpina DDE update: the alpina turbo arrangement is 2 turbos running in parallel, 3 cylinders per bank. Rather than the sequential setup in the 335d. For this reason alone I wouldn't want the alpina DDE update.
if I've helped - an Appreciate would be, er, very appreciated!
