BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > F30 DIYs and Coding Discussions > Bimmercode Question
      07-06-2019, 06:11 PM   #1
328iking
Drives: 328i
Bimmercode Question
Most cars I owned had a tripometer in the cluster which resets on every journey (when ignition turned off) along with avg mpg etc.
Is there a way to turn a tripometer feature in the cluster via bimmercode?
      07-06-2019, 06:46 PM   #2
eleven11
eleven11's Avatar
Drives: -F85 X5M-
Just in case you're not familiar, you can cycle through various data (average fuel consumption, current fuel consumption, etc.) by pressing the top button of your signal lever. I'm not sure if you can instruct it to reset for each trip directly from the cluster. However, this is possible in iDrive under the Trip Computer settings (automatic reset requires 4 hours of vehicle inactivity, I believe).
2017 X5M - Current
2017 F31 Wagon - Current
2014 M5 ZCP - Retired
2011 135i Coupe - Retired
2007 335i Sedan - Retired
      07-07-2019, 01:42 AM   #3
328iking
Drives: 328i
Yeah I seen it in idrive (pretty crap there tbh). I know you can cycle through options via the indicator stalk that's why was wondering if I can add the tripometer there (where it normally should be)
