BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > F30 DIYs and Coding Discussions > Doubt: Lights when press close button once the car is already closed
      05-03-2017, 05:06 AM   #1
00punisher
Spain
19
Drives: F36 420d
Hi all,
When I press once the close button of the key fob with the car already closed, interior lights and door handle lights turn on.
I would like more lights to turn on (front and rear fog lights, for example), because if you are looking for your car in a parking those lights may not be enough.
There are a lot of info for welcome lights but not for this case, at least I found nothing.
Could someone share the coding parameters to be changed, if possible?
Thanks!!!
      05-03-2017, 09:58 AM   #2
Billfitz
Billfitz's Avatar
Drives: '15 328iX GT
They're here, search the threads.
      05-04-2017, 01:25 AM   #3
Almaretto
Almaretto's Avatar
Drives: Test Vehicles
If locking car, you are looking for follow-me-home.
If unlocking, you are looking for welcome lights.
Alternatively, you can also use BMW ConnectedDrive App for remote features.
      05-04-2017, 02:38 AM   #4
00punisher
Spain
19
Drives: F36 420d
Thanks, mates!
      05-07-2017, 05:39 PM   #5
00punisher
Spain
19
Drives: F36 420d
Hi!
I have been searching and testing this during the weekend and I think that there should be a third option or alternative:
- Follow-me-home -> xenon on during few seconds after locking the car.
- Welcome lights -> some lights on (depending on coding) when unlocking the car
- "Searching lights" -> OVT (door handle lights) and interior lights on, when pressing the lock button with the car already locked.
I would like to add more lights to this third option/alternative, if possible.
Any clue will be highly appreciated!
Thanks in advance!!
      05-14-2017, 09:05 AM   #6
00punisher
Spain
19
Drives: F36 420d
Anyone? Only remote features of ConnectedDrive? There should be an alternative via coding...
      05-23-2017, 02:33 AM   #7
00punisher
Spain
19
Drives: F36 420d
Hey, guys! Could anyone test this? Same behaviour?
As alternative, activating follow-me-home lights from key fob would be fine, but as far as I have searched, it is not possible in F3x...
Thanks!!!
      05-23-2017, 02:47 AM   #8
Almaretto
Almaretto's Avatar
Follow-me-home should be configured through IDrive.
      05-23-2017, 10:40 AM   #9
jkwhar
Drives: F30 328i Xdrive | F15 x35i
As far as I know, the default method from BMW, follow me home is triggered by shutting the car down and pulling the high beam stalker will activate it for the preset time configured in iDrive.
Did my post help? Click "Appreciate!"
F30 328i xDrive | 475 BSM | 2A5 18" | Cold Weather | Nav Pro | Tech Pkg | Injen Intake | CW DP | VRSF IC | MR Dual Exhaust | BM3 | BC coilovers | Swift springs | Integral Audio | Retrofit: 522 & 524 EDM | 5AC | VLD | 2TB SAT | 508 | 3AG | 5DL | 6WB | 8TH
      05-24-2017, 03:13 AM   #10
00punisher
Spain
19
Drives: F36 420d
Totally right, but in some Exx they can be coded to be activated from key fob, but it seems it is not possible in Fxx.
      06-21-2017, 10:56 PM   #11
Mwahab
Egypt
51
Drives: F30
2015 BMW F30  [0.00]
I will search and let you know.
      06-21-2017, 11:41 PM   #12
Mwahab
Egypt
51
Drives: F30
2015 BMW F30  [0.00]
While looking into your issue, i have found very useful parameters, which controls like literal everything.
time to start raising windows after pressing lock button
FENSTERHEBER_FREIG_DELAY
and
FH_KURZHUB_DELAY_BEI_TUERE_SCHLIESSEN
Disable Anti-pinch
FH_MANUELL_MIT_EKS
For ( Remote Light) I didnt find any parameter for such thing, there isnt a parameter to control (which output lights when follow me home is triggered, or remote light is)
search for this: CTR_FN_POLI , translate it, and see if there any clue.
I have found different parameters, but they are all abou the duration, already spent one hour looking.
      06-21-2017, 11:43 PM   #13
bimmer456
Drives: 340i
You can also use connected drive to sound the horn if you lost your car in a parking garage as well as flash headlights.
      06-22-2017, 01:55 AM   #14
Jdmdc5teg06
Drives: '15 328i
and
Disable Anti-pinch
FH_MANUELL_MIT_EKS
With those parameters you posted, that's to change the time you hold the lock button to raise the windows? Kind of like how you can change the mirrors to fold at 00 instead of holding the lock button?
Every time I go to lock the doors and put up windows, I have to hold the lock down until all windows are up. I would like for it to be one touch and that's it
      06-22-2017, 11:02 AM   #15
00punisher
Spain
19
Drives: F36 420d
and
Disable Anti-pinch
FH_MANUELL_MIT_EKS
Thanks for your time!!
Mwahab51.00
