BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > 2012-2019 BMW 3 and 4-Series Forums > General F30 Sedan / F32 Coupe / F36 Gran Coupe Forum > F**k this key fob!
      09-14-2018, 07:05 AM   #23
tex2670
tex2670's Avatar
Drives: '23 X1 28i xDrive
Originally Posted by tsm007 View Post
CA is ok. Line control is extremely annoying. All of these aids are making drivers lazy as well as unaware of their surroundings. Instead of offering all of these conveniences, manufactures should offer driver training. Cars are always improving but the shitty drivers are still on the roads.
Drivers already are lazy and unaware. Shitty drivers don't know/don't care they are shitty, and won't take training. Embrace advanced safety features.
tsm00764.50
      09-16-2018, 08:36 AM   #24
dm335
Drives: 440 Convertible
I've discovered that my keychain presses up against the trunk button on the key fob when in my pocket. If I carefully put the keys in my pocket with the keychain against the back side of the fob, it doesn't happen. Of course, I'm not very good about doing that. I have put a small gym card (grocery stores have the same type) on the key ring so it fits between the keychain and the fob. That seems to eliminate the problem.
The button seems to be super-sensitive.
Imperial Blue 2018 440i Convertible
      09-16-2018, 10:46 AM   #25
IAmATeaf
IAmATeaf's Avatar
Drives: 2015 F30 335i
2015 BMW 335i  [0.00]
I just have the fob with just the round key ring ring on it. Maybe that ring which sits at 90 degrees to the fob is enough to stop the button being pressed when my pocket?
      09-16-2018, 11:15 AM   #26
InstigatorX
Drives: 2018 440i GC xDrive
This is hilarious...didn't even know my car had this feature. Ran downstairs to try and low and behold it works. There were a couple times I was under car and trunk popped open...thought it was the key in pocket triggering it somehow.
tex26702412.50
      09-19-2018, 07:12 AM   #27
B58 parts
B58 parts's Avatar
Drives: '17 340ix 6MT
Again this morning I go into the garage to leave for work, and my trunk is OPEN...
The light was on. Does that light shut off if it's left open for a long time? i.e. did it just pop open a few seconds before when I grabbed my keys, or was it left open for 10 hours, draining the battery all night.
Luckily it was in the garage and not out in the rain. Probably the 4th time this has happened now...
      09-19-2018, 08:07 AM   #28
IAmATeaf
IAmATeaf's Avatar
Do you have CA? If you do then would the key be within range? If within range is there anything in your garage that might run under the back might open the trunk?
      09-19-2018, 09:09 AM   #29
COKen
COKen's Avatar
981
Drives: M Rster / Z4 M40i / X5 M50i
On mine, the light goes out after a few minutes.
2002 M Roadster, Steel Gray Metailic, Gray Nappa Leather, HT, TC Kline DA Shocks & Camber Plates, w/H&R Springs, Stromung Exhaust, SSR Type C. Looking for new home.
2022 Z4 M40i, Misano Blue Metallic, Driver Asst Pkg, Prem Pkg
2023 X5 M50i, Phytonic Blue, Black Extended Merion Leather, Driving Asst Pro Pkg, Park Asst Pkg, Exec Pkg, Climate Comfort Pkg.
      09-19-2018, 09:41 AM   #30
B58 parts
B58 parts's Avatar
I do have comfort access. I did not have any small animals in the garage this morning.
I'll have to pop it open when I get home and see if the light goes out eventually. I assume it does. So, I probably jabbed the button inadvertently when I picked up the key fob this morning. In which case, the OP is 100% validated, F**k this key fob.
It should be a hard press and not a quick tap. I'll have to see about programming it that way, I know right where all those knobs are in esys.
      09-19-2018, 10:33 AM   #31
Mikesmith2939
Drives: 2013 320i xdrive
I have to press and hold the button on my fob for a few seconds before the trunk opens.
Never had a problem with it being open when I don't want it to be.
I don't have the foot waggly opener either.
      09-19-2018, 02:19 PM   #32
tex2670
tex2670's Avatar
The fob being "within range" would have to be about 2 feet from the trunk lid.
      09-19-2018, 02:21 PM   #33
tex2670
tex2670's Avatar
Mine is a hard press, not a quick tap, to open the trunk. You have to hold it down for a couple of seconds.
      09-20-2018, 10:10 AM   #34
IAmATeaf
IAmATeaf's Avatar
Mines the same, a quick tap does nothing, I have to press and hold for a good 2-3 seconds.
      09-20-2018, 01:37 PM   #35
jmg
jmg's Avatar
18697
Drives: G82 M4C X-Drive
2022 G82 M4C X-Drive  [9.85]
2018 F80 M3 CS  [9.87]
2019 i3 BEV  [0.00]
Originally Posted by Billfitz View Post
Don't blame the fob. If you're pushing the button it's your fault. If you're not something else is triggering the trunk release.
It's a design issue with the fob. I've had both my F30s and my F80 open their trunks while in my garage because my trunk button was accidentally pushed while in my pocket. The problem is with the F30/F80 fob, the trunk release is almost flush with the fob face. It needs to be slightly more recessed, smaller, and harder to press. I don't have the same issues with my i3 key fob nor my Subaru fob.
2022 G82///M4 Competition X-Drive - KW-HAS, EBC Bluestuff, Millway Race Camber Plates, Cup2 Connect*, PSI High Flow Midpipe, Lightweight Front Lip, M Perf Flow Through Wing
Previous • 2018 F80 ///M3 CS • 2016 F80 ///M3
IG: Raging_G82
      09-20-2018, 01:51 PM   #36
Billfitz
Billfitz's Avatar
Drives: '15 328iX GT
Wear looser pants.
      09-20-2018, 04:02 PM   #37
IAmATeaf
IAmATeaf's Avatar
Wear looser pants.
Or start hanging your keys on your belt loops, 80’s style 😀
tex26702412.50
      09-22-2018, 12:13 PM   #38
alainv1029
alainv1029's Avatar
42
Drives: 2015 328i xDrive GT Bootmod3
Since no one mentioned this I'll throw it in. You can code a delay into the remote opening function. Bimmercode and a bluetooth dongle does the trick.
2015 328i xDrive GT
      09-23-2018, 04:12 AM   #39
Mikesmith2939
I would recommend a WiFi dongle rather than bluetooth, as bluetooth can interrupt the coding as it will be connected to the head unit.
Also in my experience WiFi is more stable.
      09-23-2018, 04:31 AM   #40
IAmATeaf
IAmATeaf's Avatar
I’ll trump that with an enet obd connector and e-sys 😀
      09-25-2018, 11:02 PM   #41
alainv1029
alainv1029's Avatar
42
I'm folding...lol
2015 328i xDrive GT
      10-08-2018, 10:38 PM   #42
bobiam
bobiam's Avatar
Drives: Mineral White 2015 335xi
Valet switch in glove box?
BTW--how are you accidentally pressing the trunk button so often overnight?
This happens easily with the fob in your pocket. My garage is within 30' or so and it's happened at least 6 times in a month. Even easier if you have anything in the pocket, even a coin. My big worry is that it will happen when I have it outside or at a hotel/motel!!!
2015 Mineral White 335xi Sport trim
      10-08-2018, 10:45 PM   #43
bobiam
bobiam's Avatar
I have the same problem, but much worse, with my Subaru Outback (second car). Not only does the fob open the motorized hatch with the fob in my pocket, but the motor thing actually drains the battery continuously while the hatch is open, even though the light go out with the "battery saver" feature.
I now have a lithium battery emergency starter pack tucked under my seat. Had the car batt die in a day and a half once.
      10-08-2018, 11:02 PM   #44
bobiam
bobiam's Avatar
Thanks to the guys that brought the TSB to light that will convert the fob to a two button control to open the trunk. I'm going to get it done asap....
