BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > N55 Turbo Engine / Drivetrain / Exhaust Modifications > 13 335i
Studio RSR
      03-27-2017, 08:58 PM   #1
I6 di don
Drives: 13 335i
13 335i
I'm kinda new to the bimmer world and I wanted to noe how can I make 400+ on the stock turbo...Also to does anyone anything about meisterschaft products specifically exhaust and dp. Please help
      03-27-2017, 09:24 PM   #2
F30_SixSpeed
F30_SixSpeed's Avatar
1171
Drives: 335i M Sport
You need full bolt ons + tune (or JB4.)
I made 400whp/473wtrq with e40. If you don't have access to e85 or use meth you won't be close to the 400whp mark.
Here is my dyno:
http://f30.bimmerpost.com/forums/sho....php?t=1312822
Meisterschaft makes awesome stuff, specifically their exhaust. Expensive though.
335i M Sport 6MT || PS2 Turbo, FBO, XDI-35 HPFP, BM3, KW, MP BBK, OEM+
INSTAGRAM || BUILD THREAD
FSociety3811.50
      03-27-2017, 10:54 PM   #3
I6 di don
Drives: 13 335i
Ok but I've been hearing such great things about bootmod3.. How efficient is that tuning platform?
      03-27-2017, 11:20 PM   #4
J_MENIS
Drives: 435i
I just made the switch and while I do not have dyno sheets.
BM3 on 91 does feel slower than my E40 JB4. But the power and smoothness on the BM3 is far more superior. With that said, I'm going to look into a E30 BM3 tune.
@Menis_F32 2015 435I Msport EWG - Muffler Delete, JB4, E30/40, VRSF Catless DP, Resonator Delete, BMS Intake, H&R Super Sport Springs, VRSF CP, Phoneix FMIC, BM3 STG2 OTS 91 - JB4 BEF
      03-28-2017, 12:13 AM   #5
I6 di don
Drives: 13 335i
What about the diverter valve? Will that make a big difference?
      03-28-2017, 03:30 AM   #6
Krelle
Denmark
90
Drives: M2C
It doesn't give hp as such, but a larger spring help keeping closed. Maybe a cyborg can feel the difference..
How much are you prepared to spend? And how safe do you want your complete installation to be?
Ist der Motor kalt, Gib ihn sechs ein halb.....
      03-28-2017, 11:13 AM   #7
I6 di don
Drives: 13 335i
I'm trying to get a wicked setup.. I want to get the best bang for my buck
      03-28-2017, 11:17 AM   #8
F30_SixSpeed
1171
Those 2 don't go together sorry bro.
Cheapest setup/most power would be catless downpipe, FMIC, chargepipe and tune (BM3, flash tune, or jb4 are your options.) run race gas or e30-40 mixture.
FSociety3811.50
      03-28-2017, 12:17 PM   #9
J_MENIS
Drives: 435i
+1 if you want cheap power
Power : Catless downpipe (VRSF) , Phoenix FMIC, JB4 with E30-40 or race gas(Used)
The setup above will be pretty close to 400whp for about $800-1000
-I actually happen to be selling my JB4 , for $400 if interested.
      03-28-2017, 01:06 PM   #10
mike@x-ph.com
mike@x-ph.com's Avatar
Drives: 07-335/12-328/18-M4/21-M4CP
JB4 + Downpipe + Intercooler + Intake + Fuel it stage 2 + E85 ( or upgraded fuel)
GThaus make aggressive exhausts that sound really good, keep in mind most of the time there will be a wait on these exhausts.
They use AR design downpipes
https://x-ph.com/sale/
Phone number 702-494-9435
      03-28-2017, 02:00 PM   #11
I6 di don
Drives: 13 335i
Hey Mike are you familiar with the meisterschaft dp?
      03-28-2017, 05:07 PM   #12
Chicken_Joe
Chicken_Joe's Avatar
Drives: 2013 F30 335i M Sport. EB 6M
You can make close to 400, relatively speaking. 370ish is about where it's going to cut off on the F30 without a Flash or meth or E85 though
13' 335i M Sport. EBII/Coral Red 6MT. RPI GT exhaust, Resonator delete, PS1, GFB DV , BM3 Stage 2, ER CP, VRSF DP, VRSF 5.5in Stepped FMIC, Dinan Shockware. Carbon M Performance rear diffuser. M4 trunk lip. Conti DWS06 225/40/19 and 255/35/19
      03-28-2017, 06:43 PM   #13
GTBrandon
GTBrandon's Avatar
Drives: 13' M3 Competition
If you want a practical but fast daily driver: Go with a catless DP, K&N drop in air filter, CTS Intercooler, and Chargepipe. Then get a flash, either Frank Smith's(What I run) or BM3.
You can continue to add power through a new fuel pump, which allows for more aggressive tunes, or Meth/Ethanol. If you want to run meth/ethanol, you are going to need to get a unit along with them to control everything.
I would personally stick with the first option as it is the most safe, least to worry about, and most cost effective. After that, you start getting into mixing ethanol buying JB4 or other units to control ethanol or meth. Buying meth, running lines, just not worth it in my opinion for a daily. Now if you are building a pure track car, or pure drag car, then it's a different story.
Also, after you go the FBO/Flash route, before spending any more money I would recommend getting lighter rims, better tires, and a lowering for better handling, or else all that power is useless!
Current: 12' E70 X5D | 04' Yamaha Warrior
Past: 13' Audi S6 | 13' E70 X5M | 13' E92 M3 Comp | 14' BMW 335xi GT | 95' E36 M3 | 84' BMW 733i | 06' Porsche Boxster S | 15' Jeep Grand Cherokee | 06' Acura TL |
85' Honda Shadow VT700 | 05’ Yamaha R6 | 12’ Triumph Tiger
      03-28-2017, 09:11 PM   #14
I6 di don
Drives: 13 335i
So if I went stg 1 pure turbo upgrade I'll be in the consistent 4s with the supporting mods?
      03-28-2017, 09:19 PM   #15
GTBrandon
GTBrandon's Avatar
Are you PWG or EWG, if you are EWG then Stage1 is almost useless. Also, I would strongly recomend doing supporting mods first and seeing what you want afterwards before dumping $5,000 all at once.
Just to give you context:
DP: $300
CP: $250
FMIC: $400+
AirFilter: $50-100
or
Intake(a good one): $300
Flash Tune: $800
That already puts you at $2,000 and you haven't even touched turbos, fuel pumps, ethanol controllers, or meth set ups.
Best way is to do install the above first, and then go part by part afterward because everything else builds off each other.
Can't stress enough the importance of a good tire/suspension set up though or else you are honestly wasting your time and money.
      03-28-2017, 09:20 PM   #16
GTBrandon
GTBrandon's Avatar
DP: $300
CP: $250
FMIC: $400+
AirFilter: $50-100
or
Flash Tune: $800
      03-28-2017, 10:42 PM   #17
I6 di don
Drives: 13 335i
My car is pwg
      03-28-2017, 11:02 PM   #18
Krelle
Denmark
90
Drives: M2C
Then I think you'll get the biggest Bang for your buck
      03-28-2017, 11:57 PM   #19
donkey
donkey's Avatar
464
Drives: 6MT M2
400rwhp ftw!!! bcuz its like, a big number and stuff and sounds cooler than 300-something lol
Polo088161604.00
      03-29-2017, 07:36 AM   #20
Chicken_Joe
This guy....
      03-29-2017, 09:46 AM   #21
GTBrandon
GTBrandon's Avatar
My car is pwg
I would say if you want to go stage 1, just wait and save so you can go all out on stage 2 or 3
      03-29-2017, 10:35 AM   #22
Chicken_Joe
This guy....
