BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > N55 Turbo Engine / Drivetrain / Exhaust Modifications > O2 sensor codes
      10-09-2021, 07:02 PM   #1
Logicoeur
Logicoeur's Avatar
993
Drives: F30 335i xDrive
O2 sensor codes
Chasing down the cause of an active CEL for the front o2 sensor. I've been able to get voltage reading for the sensor using BimmerLink, but I'm not versed enough to understand what the voltage reading is against it's resistance.
I logged a 3-2-3-4 run today to see if anything appears in the logs. Running a non-guaranteed catted dp, Vrsf competition IC, and Mhd 2+ 93oct.
Log and code attached
https://datazap.me/u/logicoeur/10-9?...#38;zoom=0-353
Googling the specific code and text, I have found users with loose o2 connectors on installation, or just come to the conclusion they have to replace the sensor. It's not a cat efficiency code. I keep clearing it and it returns on the next start. Connectors are correctly plugged and secure (triple checked).
Is anyone able to tell from the datazap whether it is indeed a bad wideband sensor?
      10-09-2021, 11:48 PM   #2
n55david
n55david's Avatar
2017 m240i xDrive  [0.00]
2015 X3 x35i  [0.00]
2015 335i xdrive  [0.00]
02 is unplugged or there isna break in the wire(s)
2015 335i xDrive 10.95@124.99mph w/bm3 - SOLD
2015 X3 x35i pwg 12.96 catless w/bm3 stage 2 93 ots
IG: @n55david For pics and updates!
Youtube: @ n55david For videos or Racing etc
      10-10-2021, 09:46 PM   #3
Logicoeur
Logicoeur's Avatar
993
This is what my buddy and my own google searching indicates. I unplugged and plugged it a few times, even attempted to swap the two plugs just to rule out installation. However those Germans thought of everything because they are keyed one way.
I guess I do have to get a new o2 sensor installed . The stack of maintenance receipts is growing.
      10-11-2021, 03:19 AM   #4
n55david
n55david's Avatar
2015 X3 x35i  [0.00]
swapping them wouldn't have mattered anyway since they are different types of sensors. if you were able to just swap them the car would have freaked out since it wouldn't have been able to control fueling anymore.
      10-11-2021, 11:36 AM   #5
thejeremyman9
thejeremyman9's Avatar
4364
Drives: 2015 BMW 335i
It's hard to tell anything from the log because at part throttle your target AFR is constant but your fuel trims don't move. I would also suggest it is the O2 sensor or its wiring.
      10-11-2021, 11:46 AM   #6
Logicoeur
Logicoeur's Avatar
993
This is what I was looking for. I believed that there was some stream or function of streams that would indicate something is wrong with input from the sensor. From the docs it did say when the sensor fails the DME falls back to a constant value as a failsafe or something or other. Cool!
      10-11-2021, 12:13 PM   #7
n55david
n55david's Avatar
2015 X3 x35i  [0.00]
if its just the heater the sensor may be work but they need to be at a certain operating temp to work properly. so it may or may bit be using the values it sees for a longer period of time or if even at all.
so it didn't matter if the log showed anything, it needs to be replaced.
      10-11-2021, 12:26 PM   #8
thejeremyman9
4364
Yup just open the log and turn off everything (including RPM), then 1 at a time turn on labmda bank 1 AFR, STFT, and LTFTs. Leave only 1 on at a time. You can see they arent right.
n55david1295.50
      10-11-2021, 12:35 PM   #9
n55david
n55david's Avatar
2015 X3 x35i  [0.00]
I'm just imaging that it's set to a certain estimate for filing but he's basically running the equivalent of no 02 sensor.
OP,
I'd drive it as little as possible till you get it fixed.
      10-11-2021, 12:41 PM   #10
Logicoeur
Logicoeur's Avatar
993
I did this actually! I tried watching stft and ltft but nothing moved while driving around or on the gas, so I pulled the entire log hoping the behavior would be more apparent with some context. Thanks
      10-11-2021, 12:42 PM   #11
thejeremyman9
4364
OP,
Yeah looks like he is running open loop. It's probably conservatively rich (usually fuel tables are) but definitely wouldnt do WOT pulls or anything.
      10-12-2021, 10:16 AM   #12
5w20
@_sunbish
5w20's Avatar
282
Drives: Bmw 435i & 340i
https://data.me/u/logicoeur/10-9?log...-19&zoom=0-353
Had the same code but for the secondary o2 sensor. Replace your sensor.
https://f30.bimmerpost.com/forums/sh....php?t=1784694
Logicoeur992.50
      10-12-2021, 10:20 AM   #13
Logicoeur
Logicoeur's Avatar
993
OP,
I did one pull to 6 from 3 for the log above, but that was it. I've never revved the car up that much anyhow 😅. With MHD I may also be getting an extra conservative fuel map in open loop. I believe that mhd is a lot more deliberate with their failsafes than some other tuners, just from reading around here.
      10-12-2021, 10:22 AM   #14
Logicoeur
Logicoeur's Avatar
993
Part is ordered and on the way from FCP. If it happens again; life time warranty. Scheduled to replace it this Friday. Hopefully it makes the tune feel more powerful. Right now I feel like I am back at stock power/torque after going FBO on my pwg. Felt like a waste of a few grand
      10-12-2021, 11:30 AM   #15
thejeremyman9
4364
Yeah i saw you were only at like 30% throttle in that pull. And i agree based on everything i have seen, MHD is very stock-like
      10-19-2021, 09:06 PM   #16
Logicoeur
Logicoeur's Avatar
993
Update:
Car feels much stronger now. Not noticing the lag as much anymore with the new wideband o2 sensor. Will take another log and compare.
n55david1295.50
      10-20-2021, 08:53 AM   #17
BMWILUVU
Drives: 340ix
Update:
Curious as to how many years your wideband O2 sensor lasted?
      10-20-2021, 08:56 AM   #18
Logicoeur
Logicoeur's Avatar
993
Update:
Assuming from the factory. No idea if the prev owner ever changed it. 2013 build date, 86K mi. It happened after downpipe install so likely was moving it around that severed a wire somewhere we can't see.
BMWILUVU809.00
      10-21-2021, 10:29 AM   #19
Logicoeur
Logicoeur's Avatar
993
High way on ramp from a light. 1-2-3-4-3-4-5.
The 4-3 is after the on-ramp apex. https://datazap.me/u/logicoeur/1021-...-9-10-16-19-20
Seems and feels a lot better than before. The afr definitely move much higher when I'm on the throttle hard. I guess that is expected. Didn't know the readings would get so high like that though.
      10-21-2021, 10:42 AM   #20
thejeremyman9
4364
I didnt really see above like 30% throttle and 5psi in the log, did you log WOT?
Anyways, the good news is LTFTs and STFTs seem to be moving as they should now, and AFR is tracking target. It's easier to see the AFR tracking if you trim the very end of the log off where the AFRs spike super high off throttle.
Logicoeur992.50
      10-21-2021, 10:44 AM   #21
Logicoeur
Logicoeur's Avatar
993
No idk if I was WOT. I'll have to make a note to mash it next time. The car pulls pretty hard I thought I was almost to the floor 🤣
