07-06-2020, 11:39 AM | #925 | |
Rep 919
Drives: F30 328d Sport Line
parmap1.50 |
07-07-2020, 04:41 PM | #926 | |
Great Teacher
1088
Rep 1,305
Drives: 06 e91 325ix
If it was working before you added the y cable your Y cable is bad.
over Terra (one of 1), Nav, Sport, L7 A few OEM+ mods: MTech front bumper, MSport wheel & handbrake, 4AD trim, full rear shades, more to come… |
haagm58809.50 |
07-09-2020, 02:47 AM | #927 |
Rep 4
For cars without lighting package (no footwell led, no cupholder led): I also don't hace the package, but I manage to wire the trim.
You will need a lighter, a cutter (if you don't have the female connector), and a multimeter. What to do: -Take off the top trim (with the vents) and unplug the wires. -You will need to connect to the "+" which is supplying power to the door lock button LED. To find it, hook up the multimeter to the pins and adjust the dashboard light intensity, and find the pin which has voltage changes when adjusting the dial. When you find it, that's your guy. -Hookup the ground and the color wires, like in the original DIY -Put everything back In order to 'hook up', you will need the lighter. Just heat a small aprt of the wires a bit, and then remove the plastic with your hand. I'll provide a picture of the wires I used when I'll get the chance. Mine works perfectly and it even changes intensity with the rest of the dashboard. |
07-11-2020, 12:54 PM | #930 |
Enthusiast
468
Rep 1,791
Drives: F87 M2 / F31 330d
Garage List 2004 E46 BMW M3 [0.00]
2017 F87 BMW M2 [10.00] 2013 F31 330d Touring [9.50] 2009 E89 Z4 Sdrive 30i [9.00] 1989 E30 320is 2-door [10.00] 1986 E28 M535i [9.00] |
2017 F87 ///M2, Long Beach Blue, 6MT
2013 F31 330d Touring, ///M-Sport, Alpine White, Alcantara/Cloth, 19" Style M403, 8AT 2009 E89 Z4 SDrive 30i, Titanium Silver, Coral Red Leather, 19" Style 296, 6MT 1989 E30 320is, ///M-Technik II, S14 Engine, Sterling Silver, Black Leather, 16" BBS RS 003, 5MT 1986 E28 ///M535i, Agate Green, Pine Green Velours, 16" ALPINA, 5MT |
07-11-2020, 03:45 PM | #931 |
Rep 47
07-14-2020, 07:02 AM | #933 | |
Rep 1
07-15-2020, 02:31 AM | #934 | |
Rep 89
Thanks |
07-16-2020, 11:02 PM | #935 |
Rep 177
Later build non-LCi cars with Lighting Package but no Cupholder LED can do what I just did, which will add both the LCi trim light AND the cupholder light. It's the same idea as Chew's (pg. 15)... but for people who don't want to make their own cables.
1. Order the LCi radio trim (64119358940) and Cupholder LED module (63319242162) 2. Order the longer "footwell length" cable from eBay. I bought this one from a seller in the UK and even though it was a bit expensive... this gave me the option to power both the trim and the cupholder lights via one integrated cable. If there's not one for sale, you can contact him via eBay and I believe he can list one for purchase. You can also go the cheaper chinese route and get something like this one, but that will only power the trim and NOT the cupholder light... you'll need another splitter for that like this. I found it was worth it to get the cable from England, as it's built with OEM sleeves and connectors plus length is perfect. He also included some detailed instructions. 3. Once you have all of these, it should look something like this: 4. I decided to tap the footwell light from the passenger side... it's the same as the driver's side, just less clutter (no pedals). Follow Chew's post for the general idea. 5. the new LCi trim will have a slight gap between the edges and dash... which I initially thought was something not lined up correctly. But after looking at it closely, that gap is where the light shines through... by design. I also used Bimmercode to "decouple" the ambient lighting from the dash lights, so they can be controlled independently... one via iDrive and the other with the dimmer wheel. All in all this is a subtle interior enhancement for $100-150 |
07-17-2020, 10:39 PM | #936 | |
Rep 919
Torquey92.00 |
07-22-2020, 03:18 AM | #938 |
Irish Beemer
Rep 31
Yep. Seems perfect to me. The white is hardly noticeable on the doors so I keep it on the orange which gives a really nice effect in the cabin. Matches perfect.
08-14-2020, 02:41 PM | #939 |
Rep 100
I know I'm late to this, if anyone makes the Y Cable pls let me know. I will purchase from you. Thanks
09-26-2020, 12:52 AM | #942 |
Rep 19
Amazon has it.
09-26-2020, 11:54 AM | #943 |
I even mod my cereal
246
Rep 3,441
Drives: 11 ZCP DCT M3 14 328d 21 GT4
Nice find! thanks for posting...
2011 Mineral White M3 ZCP - Opticoat, Ventureshield, some CF, B&B exhaust, AFE Intake Vorsteiner VFF 101s Ohlins
2014 Mineral White 328d Xdrive Wagon - Opticoat, Ventureshield, B8s, H&R, Apex SM-10s Hawk Pads 2021 718 Cayman GT4 - Fire extinguiser |
10-23-2020, 08:42 PM | #944 |
Rep 153
Hey
I did this retrofit on my f80 m3 but the lower center trim panel is loose with the new f30 Lci trim. I called dealers for newer Lci trims on m3 and it’s the same part number for the ac control trim. Anyone else experience the lower trim not snapping back in place or loose? It’s the lower trim with cup holder light. I checked the wires to make sure it’s not causing as well. Another solution I’m thinking is to somehow 3m double side tape by the tabs or something. Let me know folks! |
10-28-2020, 12:32 PM | #945 | |
Enthusiast
468
Rep 1,791
Make sure nothing is in the way, then firmly push up. The new trim is a tighter fit.
11-03-2020, 08:58 PM | #946 |
Rep 240
Not sure if anyone else in here has done the research or not; or if you really care. However, if you're tired of paying for BMW's ridiculously inflated prices trying to build a adapter harness.. I've done the ground work finding equivalent part numbers for you. It blows my mind that for some reason BMW thinks it's ok to charge owners a 200-900% markup on electrical parts because they put the part into a BMW zip-lock plastic bag.
Anyways, I found alternate part numbers available outside the BMW network which shouldn't cost you much more than five dollars to build the harness.. 2x Universal pin terminal uncoded 3 POL. p/n 61136931929 ~$ 915% markup 2x TE Connectivity AMP uncoded pin housing 3 POL p/n 1-968700-1 ~$0.60 ea 2x Universal socket housing uncoded 3 POL. p/n 61138377072 ~$ 900% markup 2x TE Connectivity AMP socket housing uncoded 3 POL p/n 1-1718346-1 ~$0.50 ea 3x bushing contact 0,2- 0,5MM² #61138369696 (without cable) ~$ 750% markup 3x TE MQS Connection Socket 0,2- 0,35MM² [20- 24awg] p/n 5-928999-1 (without cable) ~$0.20 ea 3x pin contact 0,2- 0,35MM² #61131383672 (without cable) ~$ 700% markup 3x TE MQS Pin Contact 0,2- 0,35MM² [20- 24awg] p/n 1-928918-1 (without cable) ~$0.24 ea 3x pin contact 0,5-0,75 MM² #61131393723 (without cable) ~$ 700% markup 3x TE MQS Pin Contact 0,5-0,75 MM² [18- 20awg] p/n 5-963716-1 (without cable) ~$0.24 ea Only other thing that you would need is some 20awg hookup wire in whichever length you require.. So you have the wire harness picture, I copied the location from the first page. Last edited by zibbit; 12-16-2020 at 10:31 PM.. |
