02-26-2022, 05:45 PM | #969 | |
Rep 339
02-27-2022, 05:38 AM | #970 |
Rep 8
The white wouldn't bother me anyway but I only have one trim piece with the white LED and the rest are all red. I just want to match all of the ambient lighting but I don't have the option to set the color to red or white. So my trim piece with both white and red LEDs are lit up at the same time.
02-27-2022, 04:31 PM | #971 |
Great Teacher
1088
Rep 1,305
Drives: 06 e91 325ix
Probably Your Y cable is bad, and you are getting the feed from orange and white coming together. Or something is wrong with the connection on the ambient light piece and both are joined somewhere by accident.
Either way it ain’t coding, it’s a physical issue. You’ll have to break out the multimeter or get a different Y cable.
over Terra (one of 1), Nav, Sport, L7 A few OEM+ mods: MTech front bumper, MSport wheel & handbrake, 4AD trim, full rear shades, more to come… |
02-27-2022, 10:17 PM | #972 |
Rep 8
I'll try switching the Y cable. Does anyone have a trusted link for a replacement Y cable.
Onizukachan, did you have trouble with this yourself or have you just run into this issue before? Either way, thanks man. |
Onizukachan1088.00 |
03-11-2022, 01:41 PM | #975 |
Rep 1
Hello guys i have also done this mod, have developed issues since so the panal works and changes colour . However my Radio /AC panal now shows no sign of life , my streeing wheel controls + indicators are also not working and the light control panal is not working. I have try to plug and unplug the cable going into the radio as thst was the only one i unpluged but no luck snyone have any ideas on what have done , what i could do to repair this?
Thank you in advance |
04-01-2022, 06:39 PM | #976 |
Great Teacher
1088
Rep 1,305
No issue, I just understand dc electrical and how that circuit works is all. Glad I could help.
04-04-2022, 02:53 PM | #977 |
Rep 10
Hey guys! I just have a quick question as I couldn't find anything about this anywhere on this thread.
I own a 2016 M4 (pre-LCI), and I decided to do this upgrade. I bought the ambient light mod from amazon so it's safe to assume it's not a genuine BMW piece. Link: https://www.amazon.ca/gp/product/B09...MQ4SRWIMW&th=1 It already has two cables coming out of it, but they're both 3 pin connectors. The amazon ad says the M4 uses a 4 pin connector. Can anyone confirm if this will be a direct plug and play for my year M4, 2016? I was thinking maybe the connectors changed in the LCI models of the M4 or something... Am I gonna need some kind of Y cable made that uses 4 pins instead of the 3 that is being talked about throughout this thread? Thank you in advance! |
04-04-2022, 07:27 PM | #978 | |
Rep 339
04-07-2022, 12:07 AM | #979 |
Great Teacher
1088
Rep 1,305
That on3 isn’t OEM or close to it, it’s the china blue and orange.
The china blue orange bpillars are easier to install and a better design than OEM, and easy to convert to white. This thing? I’d return and get the real one if you can.
04-07-2022, 01:44 AM | #980 |
Rep 10
Now you've got me rethinking... are the non-oem ones really that bad in comparison? Would like to hear more of peoples opinions!
04-07-2022, 09:42 PM | #981 |
Great Teacher
1088
Rep 1,305
Frequently have 4 pin connectors, or are wired wrong, and are always the wrong color. OEM are cheap enough to not deal with the china ones or having to solder 603 5k smd leds into them to fix the color issue.
04-19-2022, 08:05 AM | #982 |
Rep 138
Quick question..have this oem lci piece from my f30 that i sold, does this fit the f36? Kept it from f30 because i was buying an f36. If not ill post it for sale.
04-20-2022, 10:16 PM | #983 | |
Rep 339
04-27-2022, 09:42 AM | #984 |
Rep 138
05-10-2022, 05:57 AM | #985 | |
Rep 1
Thanks Adam |
07-03-2022, 01:55 PM | #987 |
Rep 224
Classic/sport
I did This mod along with the ambient led door strips. I have classic/sport mode on I drive but the LEDs only
Work on orange. They go dark when I switch to sport mode. All Plug and play and everything is correctly Wired as far as I can tell. Any ideas?
Martin
08-19-2022, 02:45 PM | #989 |
Rep 20
08-22-2022, 04:10 PM | #990 |
Rep 339
If you had to tap the foot light connection for power, it is the pinout on your connection, it won't work with both colors, only one. Depending on who you got the connection lead from will determine what color will work, either one or the other, but not both. If you connected it the normal way, by the dashboard power lead, chances are, it is also the vendor who sold you a cable that is incorrectly pinned.
