09-13-2019, 01:10 AM | #1 |
Rep 3,540
DIY Rear Height Adjustable Spring Setup for <$250!
Video Overview and Installation Guide
DIY HAS Writeup So, I've wondered for a while if one could DIY a rear HAS setup at a reasonable cost. If possible, this would solve common issues like not getting the rear height/wheel gap/rake you want, not being able to choose your rear spring rate and flat ride ratio, and having to buy expensive "BMW fit" springs. Spring Mounting Hardware I noticed that aftermarket coilover systems typically had flat ground springs (like standard coilover springs) that seated against their ride height adjusters, and wondered if it was possible to obtain just the rear ride height hardware. As it turns out, both BC Racing (PN I-29-HLK) and Solowerks offer their rear perch/adjusters. I ended up buying a set of the BC Racing perches/adjusters for $100 shipped (you can select any F2x/F3x/F8x on the linked site's drop-down menus and it'll bring up the right PN). One thing I bought that was completely unnecessary was Swift's Thrust Sheets. These are supposed to act like a radial bearing to allow the spring to spin so it doesn't bind during compression/decompression. You really don't need these. Next, in order to use a standard coilover spring I'd need a lower spring perch/pad to rest it on. Since that side is also ground flat the perch/pad needed to have a flat base. I looked through Energy Suspension's Catalog and on page 14 found universal polyurethane spring pads. PN 9.6116 and 9.6121 looked like they'd fit over the protrusion/mount in the rear camber arm, so I bought the cheaper of the two (9.6116). This part's flange/seat is too large to allow it to sit flush in the lower camber arm, but that was easily remedied by cutting it to the appropriate profile. Lower spring pad not sitting flush Modified lower spring pad Picking Springs The last piece of the puzzle was choosing which spring to use. Both the BC Racing and Solowerks perches can use 60mm ID springs, although you'll probably need to remove the plastic perch on the BC unit. With the perch you can use 2.5" (63.5mm) ID springs. 65mm ID springs also probably fit fine, and you can choose to use a 60mm to 65mm adapter if you like. To pick my spring I looked through Hyperco, Eibach, and Swift's catalogs. For my particular application I'm targeting a rear ride freq around 1.8Hz, so a 900lb/in spring is what I was after. When looking through the catalogs and searching the PNs for the spring rates I wanted I was surprised at how cheap standard coilover springs are. I saw them ranging from $50 to about $80 each, and the ones I wanted (Hyperco 2.5" ID, 900lbs/in, 10" long), ended up only being $57 each shipped. A 9" coilover spring is probably optimal for having the most adjustment range, however 8" and 10" springs are far more common. If you decide to go with a spring rate as high/higher than mine (or you want to drop your rear height really low), you'll probably want an 8" spring instead. If you're keeping things around OE rates or up to M3/4 (~650lbs/in) then a 10" spring will be fine. One thing that's important to note is that you want it so that when the camber arm is up and bolted to the rear knuckle the spring has some load on it so it can't pop out. This is a concern if you go with too short of a spring, and is why helper springs and couplers exist. Rear HAS in Practice Rear HAS installed I ended up having to adjust my rear perch all the way to the top (minimum height) to achieve the 14" hub to fender measurement I was targeting. I might drop the rear a bit more, but will have to remove the locking ring to allow the height adjustment ring to get closer to the top. Many coilovers don't use a locking ring on the rear, like Bilstein, and KW, so I'm confident I don't need them. So far I've been driving around on this setup about five days now and have been pleased with it. I'm also quite pleased this setup came in at <$250, which is less than it'd cost you to get a pair of M-Performance rear springs. But what about the front? I'm thinking about the front too, but haven't found anything yet that would be easy and cost effective...
-My YouTube Channel for some of the best DIYs and in depth information Please don't PM me for suspension recommendations unless interested in paid private consultations. Last edited by FaRKle!; 09-13-2019 at 01:30 AM.. |
dsc88864.50 cfm56d7b5890.50 scostu1623.00 kern4174449.50 andino479.50 whitesedan1.50 ali820271.50 redEYEjedi769.50 kpgray333.00 pauli18c211.00 WallaceK6.00 xingqianli5.50 DLag30103.50 |
09-13-2019, 07:53 AM | #2 |
Rep 1,499
Nice work!
09-14-2019, 01:10 PM | #4 |
Rep 10,261
FaRKle!, I always appreciate your posts as suspension and brakes are my favorite areas of focus. Do you have your own shop?
09-14-2019, 01:33 PM | #5 | |
Rep 3,540
I don't have an auto-shop, and my day job really has nothing to do with the auto industry (well unless you consider a great many orders up the supply and manufacturing chain). I'm hoping to produce more guides/tips/ideas content in the near future. The videos thing is pretty new for me, so I'm still working on a format I like, that is effective at giving people the relevant info they need without making it too long ("brevity is the soul of wit" and all).
09-15-2019, 12:25 AM | #6 |
Rep 1,934
This is great stuff. I went the same route on a previous vehicle. The set of BCs, on those were designed with the rear spring seat sitting under the spring. It was a pain to adjust. Found another supplier who had designed the opposite, got swift springs, poly thrust sheets, and adjust able arms thoughout. I never got to power mods on that car, but it sure rode, and handled well. You're making it difficult not to go down the suspension rabbit whole as a first milestone.
FaRKle!4020.00 |
10-15-2019, 06:04 PM | #7 |
Rep 77
FaRKle! Great work as always! Been lurking on-and-off, and your analysis/modifications are always well thought out.
How are the 900 lb/in springs working in practice? I'm considering making the same change for my F31 (petrol instead of diesel). Background is I installed Bilstein B16 Komforts a while ago--wish I had seen some of your analysis of these earlier! Bilstein say the f/r main spring rates are 289/428 lb/in, which by my calculations puts the f/r natural frequencies at ~1.8/1.3 Hz. (Interestingly the B16 spring rates give much lower rear frequency than front for all applicable F3x models--still scratching my head over that.) A bounce test by hand seems to confirm the front at 1.8~1.9 Hz, and the rear at ~1.5 Hz, so I'm still refining the motion ratios and masses on my spreadsheet, but it seems clear a higher rear spring rate will be beneficial. I'm curious if the 900 lb/in springs worked as expected to provide flat ride paired with the higher rate front springs you already have. I'm also wondering if there's a way to know whether the B16 dampers will work ok with that much higher spring rate. A custom damper tune may come in the future, but not right now. |
10-16-2019, 12:22 AM | #8 | |
Rep 3,540
Most coilovers I've seen (with exception of Ohlins R&T on 6cyl models) produce a higher front frequency. I believe they do this for a couple of reasons. The first is they want the user to have a "sporty" feel, meaning they want you to make you "feel connected to the road." If you've ever been in a really smooth riding car and looked down at the speedo and said "wow I didn't know I was going that fast!" (because it was so smooth), well that's what they don't want you to experience... They'd rather make slow "feel fast." The second reason I think they run really high front rates is to try and support the front of the car better due to the Macpherson struts. As the struts compress you lose camber, and thus cornering grip. Since they can't count on end users upgrading sway bars, they'd rather handle it themselves by stiffening the front springs to reduce roll. Lastly, higher front frequencies make the front more responsive due to shorter transients. My final spring rates once I get the dampers retuned will be 245lbs/in front and 900lbs/in, in the rear. If the B16 dampers' dampening range encompasses the regular B6's behavior, then there should be a setting to accommodate the 900lbs/in springs. Heck, you may even want to go higher than 900lbs/in (with a shorter spring and helper spring) if that's the case. I can look through the data I've built up to plug the numbers for ride frequency and damping ratios with the B6, and check PNs to get a better idea if that's true, but I usually charge a small consulting fee for that.
10-16-2019, 07:32 PM | #9 |
Rep 77
Glad to hear it's working well, and I'm certainly looking forward to your review of the damper tune later.
Even higher than 900 lb/in might be a good idea like you mentioned to get a good frequency ratio. I haven't seen any application of main+helper spring in a non coil-over-damper setup, but I also don't see any reason it wouldn't work. My original thinking was to do 900 lb/in rear and then later decrease the front spring rate slightly. For that I need to find an upper spring perch to adapt the stock roller bearing to a standard spring size (perhaps the perch supplied with Ohlins R&T coilovers). That's a project for another time though, and changing rear springs is so cheap/easy, maybe I should start with a higher rate and decide later on decreasing both front and rear. Back to the spreadsheets and catalogues to do some optimizing... You make some good points about why manufacturers might choose the spring rates they do for coilovers. I don't have much experience with various cars/suspension setups, but I do think the B16s make some tradeoffs for "feeling fast" over actually maximizing grip, hence I'm here thinking about more modifications! Also the 428 lb/in rear springs are not very happy when there's a bike rack and two mountain bikes hanging off the back--sometimes there are practical considerations too. |
10-16-2019, 09:24 PM | #10 | |||
Rep 3,540
Your existing springs have a similar function. Bilstein uses progressive springs with two spring rates. If you look at your spring at static height you'll see all the initial rate coils already bound! So in normal driving you're only using the final rate coils. If the suspension becomes unloaded, that's when the softer rate comes into play to keep the overall spring loaded and in place. Quote:
10-21-2019, 08:59 AM | #11 | |
Rep 5,395
I'm wondering if your method may work for my issue. I'm finished my suspension mods but I still have a slight reverse rake. Wondering if it's possible to adjust the rear slightly higher? Here's my setup: 2015 335i xdrive non-adaptive suspension. Koni Special Active Shocks, Eibach Spring Kit (-06 part number with mild 0.8"/0.6" drop). H&R sway bars and a front strut brace. Tires are summer Michelin PS4S 245/40-18, winter Michelin X-Ice il3 225/45-18 What parts would I need to slightly raise the rear while still using my rear Eibachs? What would the adjustment range be? Thanks in advance! |
10-21-2019, 10:12 AM | #12 |
Rep 272
nice work, i wonder if the ground control f80 coilover sleeves would work for the front of an f30. I've read f32 springs have been put on an f80 so i'm assuming it could work.
They have a place holder in their shop for f30 coilover conversion but the link is empty. Might be something there in the future. |
10-21-2019, 12:15 PM | #13 | |
Rep 3,540
10-25-2019, 11:02 AM | #14 | |
Rep 3,540
If you need a set I can make some fairly cheaply.
10-25-2019, 11:39 AM | #15 | ||
Rep 5,395
11-03-2019, 10:20 PM | #16 |
Rep 77
Just a couple FYIs to add to this:
If anyone is interested I can comment on how the B16 dampers work with the much higher spring rate after I have some time on the setup. |
03-07-2020, 06:17 AM | #17 | |
Rep 1,934
03-08-2020, 10:08 PM | #18 |
Rep 77
The increased rear spring rate has certainly been an improvement. I feel like the car settles faster after bumps and the front and rear feel more in sync in turns. Before it felt like the rear was transferring weight much more slowly, so the car would sort of twist on the longitudinal axis at turn entry. I can't say I can feel the rear being particularly underdamped (rear adjuster set to 5 now, FWIW), but perhaps a more sensitive driver would notice. I wouldn't say the higher spring rate made the rear much (or any?) harsher.
06-07-2020, 04:15 PM | #19 |
Rep 272
Farkle, you know if I should target 650lbs/12k with off the shelf b8s? I ordered the BC hardware for the rear and and going to order swifts.
Watched your vid that the dampers will raise the ride height and can’t have that lol |
06-07-2020, 10:44 PM | #20 |
Rep 3,540
B8s can handle a 650lbs/in rear springs no problem. You can even go higher in spring rate if you want.
06-08-2020, 03:19 PM | #21 |
Rep 272
08-01-2020, 02:07 PM | #22 |
Rep 1,934
Have you figured anything out for the front?
