05-29-2018, 08:46 AM | #199 | |
Rep 2,382
2013 F30 328i: MHI Big Turbo, GFB DV+, Mishimoto CAI, ER TIC/CP/Catless DP, AWE Touring Quad Exhaust w/ Resonated Midpipe, NGK LI Plugs, BM3 with PTF Stage 2 91 AGG Tune, Fuel-it Stage 2 LPFP, Solowerks S1 Coilovers, and DEPO/M-Sport Retrofit |
05-31-2018, 07:22 AM | #200 | |
TH320i
23
Rep 41
A bit over worried at the moment or you could say paranoid haha, i just got rid of a super knocking issue, it was either a leaky injector or a cracked timing chain guide but its sorted now all replaced and fault code free...
2012 BMW 320i - Catless DP - Full 3" exhaust system - Cold Air Intake - S55plugs - GFB DV+ - ProjectA Stage 2 Remap (270 hp on E20).
05-31-2018, 09:02 AM | #201 | |
Rep 2,382
Once you fix her up, she'll hold much more I'm sure.
THbimmer23.00 |
06-26-2018, 09:18 AM | #202 | |
TH320i
23
Rep 41
Now i am still worrying a bit about the amount of boost i am running... as the 320i stock boost is only 8psi which is allot less compared to your 328i!!! I do not want to snap a con rod or crack a piston... that is the last thing i need right now!!!
06-26-2018, 09:36 AM | #203 | |
Rep 2,382
06-27-2018, 09:52 PM | #204 | |
TH320i
23
Rep 41
I am running e20 fuel at the moment... only higher octane fuel i can go is e85... Fuel in Thailand is crap... This is whats available... E20 E85 Regular 95 Gasohol 91 is 10% ethanol and 90% Gasoline in octane 91 Gasohol 95 is 10% ethanol and 90% Gasoline in octane 95
06-27-2018, 11:40 PM | #205 |
Rep 307
Generally higher compression ratio means you’re more limited on boost compared to a lower compression motor. However, you don’t NEED as much boost to make the same power.
07-10-2018, 01:55 AM | #206 |
Rep 42
Drives: F30 320i
I am very interested with your MHI upgraded turbo and will going to upgrade soon. Thanks for sharing.
2015 F30 320i: AFE Momentum CAI, ER Castless DP, FTP TIC/CP, RES valve-electronic Quad Exhaust full Catback, BM3 OTS Stage 2 91 Tune, Koni FSD/Eibach Prokit, Brembo GT6/GT4 Yellow BBK, Vorsteiner VFF 103 19", NGK 2-step colder spark plugs, Custom Intercooler
M2_MEDUSA664.00 |
07-11-2018, 09:12 AM | #207 |
Rep 2,382
Good to hear! I think you'll enjoy it. It's a well-priced turbo considering how much of it you actually get to use.
07-11-2018, 12:22 PM | #208 |
Rep 3,679
Can you link where you got your MHI turbski from? Not that I'm in the market right now, just want to see.
07-11-2018, 05:14 PM | #209 |
Rep 245
Drives: F10 M5, E36 M3
Awesome build BunkerJ, love these kinds of threads. Curious as to what you think since I'm starting out close to how you did. In my 6mt 428i, I got Injen CAI, 435i MPE, and running the Dinan Sport at race mode with our good old San Diego 91 octane. What kind of hp gains do you believe I have on my N20? Certainly feels way better then stock, and she performs well at the track for what she is.
I also have my VRSF HD intercooler and Charge pipe on the way! Excited to put that in, I should feel a little more gain right? Last edited by JG_Coupe88; 07-11-2018 at 05:16 PM.. Reason: Spelling error. |
07-11-2018, 07:55 PM | #210 | |
Rep 3,679
JG_Coupe88255.50 |
07-11-2018, 11:13 PM | #211 |
Rep 42
Drives: F30 320i
Do you have any recommendation upgrade together with the turbo for safety to the engine internals? I'm not going to bump boost higher than 22 psi. engine 20i has higher compression ratio on piston although I believe it has same part as 28i.
07-12-2018, 01:06 AM | #212 |
Rep 42
Drives: F30 320i
I found this part in Bimmerworld website and saying this must be replaced if I upgrade the MHI turbo. Also it mentioned that with old part there might be a oil leak.
http://www.bimmerworld.com/Exhaust/B...-X3-X4-Z4.html
07-12-2018, 03:46 AM | #213 | |
Rep 307
JG_Coupe88255.50 |
07-12-2018, 08:14 AM | #214 | |
Rep 3,679
JG_Coupe88255.50 |
07-12-2018, 11:29 AM | #215 | ||
Rep 2,382
Otherwise, since you're in San Diego, we will likely see each other around either on the street or at a meet. Just look for the MG F30 with quad tips, BM3 decals, and a skull mask on the passenger seat headrest. As of right now, one other member has upgraded the rod bolts to ARP ones. The rod bolts put in our engines stretch several times during the torquing of them. While it's not bulletproof, the new bolts will provide another layer of protection and likely allow you to reach higher power numbers. Your rods are still the same old weak ones of course but as of this message, there are no none rods being thrown due to the rod itself snapping. It has always been a bolt breaking and then snapping a piece of the rod (Even then, it's usually the 'broken' cap).
07-12-2018, 07:21 PM | #216 |
Big Turbo Boys N Girls
327
Rep 579
Pretty much on par with Bunker J reply and others. All research I have done has shown the bolts stretch due to heat cycles which cause the rod/ cap to break. I feel confident that the motor will be good for around the high 300 to around low 400 HP mark once Bolts are upgraded and you have all the proper bolt-ons to support the motor and you don't beat on it till fully warmed up with a solid flash tune. If you can add meth or go E85 it all helps with Detonation and add another layer of protection for the motor.
Past low to mid 400HP the cylinder walls will start to egg shape and flex eventually, potentially cracking as with any open deck motor I have encountered. At that point motor will need to be either sleeved or the deck will need to be pressed/ closed or do both at the same time to have a bullet proof 4 banger. If you doing all this, might as well get all the internals done at the same time and go all out, haha. Limiting factor will be the 6 speed and at this time I am not sure if the 335I trans will bolt up as I have not gone down this route yet. My trans at 450TRQ with a stage 2 clutch rated for 540lbs has had 2nd gear whine and eventually broke apart. For Auto boys you should be good for around 500HP but will require a Valve body in near future and possibly Trans ECM flash to handle more power as you will begin to slip sooner than later. |
07-13-2018, 10:44 PM | #217 | |
Rep 245
Look for an all blacked out BSM 428i with the rear 428i emblem black ,with 435i MPE on MP rear diffuser. I'll be on the lookout for ya , if you go to car's and coffees, a SD BMWCAA member, or track with Speed District hopefully I'll see your sick F30 around. I'll be at tomorrows autoX event. To anyone on here, you see me come say what up haha. And everyone else, thanks a lot for further input. I was feeling like I was somewhere around 270-290 and 300+ lb/ft crank currently so glad to read the responses. |
07-14-2018, 07:00 AM | #218 | |
Rep 42
Drives: F30 320i
07-14-2018, 02:23 PM | #219 | |
327
Rep 579
I love higher compression builds when going very big turbos as it aids in daily driving and creates less lag. You will be fine. You can make some power just do the same upgrades as any 328 motor. Your tune will be the only thing different.
2012 F30: G25-660 Bottom Mount Mani+ DP+ Intake, CSF FMIC, VRSF CP, Walbro 450 LPFP, PR Injection with AIC 4, S63TU Injectors, Tuned with BM3, ZF Race 4 Puck and Non SSA Pressure plate, Catless, 3.5" Quad Muffler, Custom Valved Bilstein B8 + H&R SS. Max 456 WHP - 452 WTRQ. Currently tuned down to 434 WHP and 362 WTRQ to save the rods.
07-14-2018, 09:38 PM | #220 | |
Rep 42
Drives: F30 320i
