07-14-2018, 02:51 PM | #1 |
Rep 155
E85 on stock 340i
I just filled up 2 gallons of e85 on my completely stock 340i and the rest 91 and wow, huge difference in sound, and feels way more torquey. The pulls are way harder and I am having no problems with the car misfiring.
Try at your own risk, every car is different |
07-14-2018, 03:00 PM | #2 | |
Rep 2,964
Estorilblue340i23.00 |
07-14-2018, 03:02 PM | #3 | ||
Rep 155
07-14-2018, 03:09 PM | #4 |
Rep 2,964
07-15-2018, 06:29 PM | #5 |
Rep 293
Drives: 2016 340i X Drive
Putting 2 gal. of E85 into a tank that had 13.5 gal (3/4 full) of E10 gas resulted in 20% ethanol in your tank. Do you realize the internal damage that can occur to a vehicle long-term with that much ethanol if it wasn't designed for it? The ethanol will attack the aluminum and magnesium parts. Hoses may swell. You're not going to notice it immediately, but the engine will be wrecked and the cause will be obvious, voiding the warranty. From a short-term perspective, water in the tank can settle out and clog various parts. Don't do it!
eluded3029.00 |
07-15-2018, 10:33 PM | #6 | |
Rep 5,776
Last car: 2011 335i Msport. JB4. Vrsf CP |
07-15-2018, 11:25 PM | #7 | |
Rep 155
07-16-2018, 06:39 AM | #8 |
Rep 6,989
Ethanol has only about 73% of the thermal efficiency of gasoline but has a higher octane rating. It just allows a stock engine to develop its full power by raising the octane level of lower-octane fuel and preventing the DME from pulling back boost/fuel/ignition to counter detonation. Ethanol is corrosive to some of the seals and rubber parts in the fuel system and can eventually damage that system if used in large quantities. BMW clearly states that no more than 15% ethanol content should be used in any of its current gasoline engines.
Essentially, ethanol is nothing more than an octane-booster that enables higher states of tune while preventing pre-ignition. It's not rocket fuel.
2015 F80 ///M3 Sedan 7DCT Tanzanite, 2022 X3 sDrive30i 8AT Brooklyn Grey Last edited by RoundelM3; 07-16-2018 at 06:44 AM.. |
eluded3029.00 |
03-04-2019, 12:56 AM | #9 | ||
Rep 155
eluded3029.00 |
03-04-2019, 10:55 AM | #10 |
Rep 279
13' F30 335i - BMS Intake -- VRSF DP -- VRSF CP -- VRSF 5" Stepped Intercooler -- Corsa Touring Catback -- JB4 -- H&R Springs -- Miro Flow Formed F25's
03-04-2019, 11:25 AM | #11 |
David
786
Rep 2,010
Ethanol is also less energy dense, meaning you need more fuel to make the same power. Your injectors aren't calibrated for this, so effectively you're running your car lean.
03-04-2019, 11:40 AM | #12 |
Rep 245
My average MPG dropped by 2 MPG with 2 gal of E85 to a full tank of 91.
Yes, less energy dense.
2017 F30 340i RWD // MG Flasher // xHP // CG DS-1 // ZTR ZMP ZCW ZLP
