BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Suspension | Chassis | Brakes > Has anyone only upgraded shocks?
      09-29-2017, 02:12 PM   #1
cu260r6
Drives: 428i
I'm considering Koni orange, yellow, or Bilstein B6 shocks to firm up the ride slightly on my daily driver. I live in a climate that gets a lot of snow and can't afford the ride height decrease that comes with most performance springs. Has anyone done only their shocks? How has it altered the ride, specifically the comfort?
      10-08-2017, 07:24 PM   #2
superherorockstar
Drives: 2014 335
I?m considering the b4 sports. I?ve heard that the b6 can be extremely harsh
      10-09-2017, 10:47 PM   #3
cu260r6
Drives: 428i
Good call, that's what I meant. Anyone tried only the B4's without upgraded springs?
      10-10-2017, 07:07 PM   #4
cu260r6
Drives: 428i
Bueller? Bueller?
This seems like the most logical upgrade for a daily driver. Stiffer springs require stiffer shocks, and there's no guarantee the rates will be matched well enough without trying several combinations. I was hoping slightly stiffer shocks could be used with the stock springs but was curious about the spring/shock match.
      10-10-2017, 07:11 PM   #5
Polo08816
Drives: 2014 335i M Sport
Originally Posted by cu260r6 View Post
Bueller? Bueller?
The only guarantee is the BMW M Performance Suspension Kit.
      10-15-2017, 06:52 PM   #6
js 84
js 84's Avatar
84
Drives: F30 2012 320d
I have upgraded my shocks to Bilstein B6 with stock springs. I think this was my favorite upgrade so far. To me B6 have just right amount of stiffness.
On highway I would say that B6 are more comfortable as they do not bounce around on bumps. Currently have done 15k km on the B6 and still love them.
      10-16-2017, 12:21 AM   #7
nickf30
Drives: 2014 335i xDrive
Looking for same upgrade here, for comparison all 3 cars are driven on same road for at least 100 miles: my 2014 stock 335i xDrive suspension with conti run-flats is so bouncy / floaty at highway speed. 2017 330i xDrive is 90% free of the bouncy feeling / similar body roll. 2017 430i Gran Coupe xDrive (0.5 inches lower) has 0 bouncy feeling (little harsh at low speed) / much less body roll.
My guess for upgrade path:
1) Bilstein B4 upgrade --> 330i Level damping, same body roll
2) Bilstein B6 upgrade --> 430i Level damping (slightly harsh), same body roll
3) Bilstein B6 + 10-20mm drop -> 430i Level handling (quite harsh)
4) Bilstein B8 + 30mm+ drop -> too much for NYC -> require tire change / significant PSI change
Anyone running these upgrades ?
      10-16-2017, 02:11 PM   #8
YR430D
YR430D's Avatar
46
Drives: BMW 430D
What is the difference between M Performance suspension and M sport suspension??
      10-16-2017, 04:22 PM   #9
Polo08816
M Sport Suspension = Sport Suspension.
It's the factory 704 suspension for RWD cars.
M Performance Suspension Kit is an M Performance upgrade.
      10-16-2017, 04:29 PM   #10
cu260r6
Drives: 428i
Thank you, look like the route I'll be going as well.
      10-16-2017, 04:46 PM   #11
MacklinUSOB
Drives: f30 328i 6MT Sport
I am planning on replacing both front shocks with a set of B6's. One of the first mods I did to my CPO car is replace the rear shocks with B6's and it made a **massive** improvement, the stock 704 rears were utterly shot. Now there is way less brake dive and squatting under acceleration, I am expecting that to go even further once the fronts are done.
Past: E36 328is & E38 740i
      10-16-2017, 05:05 PM   #12
YR430D
YR430D's Avatar
46
Drives: BMW 430D
Thank you but is m performance lower and stiffer than m sport from factory?
AashC6.00
      10-16-2017, 05:53 PM   #13
Polo08816
It is 10mm lower than the 704 Sport Suspension from the factory. All the high end coilovers like Ohlins Road & Track and AST are recommended to be 10mm lower than the 704 Sport Suspension. It is likely the optimal ride height for performance.
It is slightly stiffer than the 704 Sport Suspension as well.
      10-17-2017, 04:28 PM   #14
YR430D
YR430D's Avatar
46
Drives: BMW 430D
If and when I do replace the dampers I will go Ohlins R&T.
      10-24-2017, 02:34 AM   #15
nickf30
Got a pair of B6 rear shocks installed to my 2014 335i xdrive today. Stock front struts (800 mls old replaced by dealer recently) + stock springs + OEM continental run flat 34psi Front/ 38psi Rear. Initial 40 miles impression is very positive: the rear feels much more stable over bump at I-95 / NYC street. Ride is tighter it feels almost the same as 2017 330i xdrive over the same 40 miles drive. It also improves the steering response the whole car feels more lively at slow speed (similar to LCI 4 series). There is no change in amount of body roll during hard corning (as expected) but it feels more confident inspiring / less body roll for highway overtake (quick left -> right / right -> left move).
Going to install B6 front struts + AC Schnitzer Springs to complete the upgrade in the next 1-2 weeks.
      10-24-2017, 12:46 PM   #16
MacklinUSOB
Definitely let us know how the feeling progresses with those new fronts and springs! I'm glad it made such a difference for you, my feelings on the upgrade are absolutely in line with the examples you provided. It is way more confidence inspiring when you're tossing it around, the damping in the rear is substantially improved, it keeps the whole track of the car more stable in pretty much every condition.
      11-14-2017, 12:31 PM   #17
nickf30
Bilstein B6 front struts are still out of stock in U.S. fact the latest date as told by my vendor is at least Jan-12-2018. The only way to complete the upgrade is either bite the bullet on PSS10 coilover (which is way overkill) or change to Koni Sport (Yellow). Any thoughts?
      11-14-2017, 04:27 PM   #18
MacklinUSOB
I'm not sure of any purchase constraints you may have, but I do see them in stock at Bimmerworld.com, haven't looked elsewhere. However, I have heard good things about the Koni Sports. I do believe those to be comparable to the B8's (for lowering applications), though.
      11-14-2017, 08:17 PM   #19
nickf30
I had placed the order at Bimmerworld few weeks back but they told me Bilstein B6 is back ordered at least 8 weeks so I ended up order through ECS and hoping it will arrive early (was showing Nov 2nd online). It turned out Bimmerworld's estimation is correct and everybody is back ordered on B6 until mid Jan 2018.
