08-10-2017, 05:04 PM | #1 |
Rep 647
Can someone explain the concept of "fuel limits"?
Google is useless. I have the MPPSK on my 340 and am considering the Dinantronics. In reading up on that vs JB4, I keep seeing people referencing fuel limits when discussing the potential increase to HP. I just haven't figured out what the fuel limit of a car is.
Current: 2023 G80 ///M3 Competition xDrive in Atlantis / 2021 X3 M40
Previous: 2020 M340 / 2017 X3 / 2016 340xi / 2013 335xi / 2011 X3 / 2010 328i / 2007 328i / 2004 325i |
08-10-2017, 05:18 PM | #2 | |
Rep 3,216
There is no point in chucking unburnt fuel down the exhaust. It doesn't add to power generated by the engine when it flames out by the tailpipe. |
08-11-2017, 12:25 PM | #4 |
Rep 1,509
It's sometimes called a "flammability limit" or "explosive limit."
If the air/fuel mixture is too rich, it can actually inhibit combustion. https://en.wikipedia.org/wiki/Flammability_limit |
08-11-2017, 01:17 PM | #5 | |
Rep 369
08-11-2017, 07:29 PM | #6 | ||
Rep 216
2017 340i M Performance Edition: Fashion Grey, MPPSK, M performance front splitter, rear diffuser, side sills, black grille, CF spoiler, 405M 20s, 8AT, full Marino interior and dash, adaptive suspension
jalkster220.00 |
08-14-2017, 01:31 PM | #7 |
Rep 484
Drives: 440 xi MPPSK JB4
Location: Socialist People's State of NY - Long Island, NY
The fuel limit we talk about has to do with the amount of fuel we can deliver to the motor to reduce the AFR while balancing the amount of boost and usable timing (Boost plus timing = power). I rarely see the fuel limit hit unless your adding octane... When you add octane (such as E85, etc.) your boost is limitless up to 22psi, timing will be well advanced... thus your ability to make power and suck in air is amazing - thus you need more fuel... if you dont add more fuel you WILL run lean (NOT RICH!!!!)..
When your AFR runs lean you need to add more fuel to richen the mixture. To do this you must increase fuel pressure... issues come into play as you add fuel pressure one of two things occur 1. the trick to increase fuel pressure could cause a fault since your tricking the car into thinking fuel pressure is low, thus the computer raises it OR 2. As you raise your fuel pressure (within normal parameters) it lowers your boost target as a different protection mechanism which no one has yet to figured out. High amounts of E85 have diminishing returns because E85 is essentially diluting your tank of gas (E85 is less efficient as a combustible - but dont confuse this with octane rating), thus you need to add MORE fuel, above and beyond the fuel needed for the added Boost and Timing you just added. Eventually you will cause the fault since your computer will think it lost too much fuel pressure .. With race fuel, your volume of gas is not affected thus you can push the limit and will hit the fuel limit lowering of boost target well in advance of any fuel pressure issues... |
08-27-2017, 01:57 PM | #8 | |
Rep 9,709
.....but there is a limit to how much fuel it can deliver written into the software. That fuel limit is in effect a horsepower limit too. That's why you can't go much beyond 400hp without fuel coming from an additional source, meth injection, or upstream extra fuel injector(s). So in your case, MPPSK already uses up some of the fuel limit headroom. Adding another tuning device might not bring the additional power it would on a non MPPSK car, due to the hard fuel limit. Hope that makes sense. |
08-28-2017, 02:21 AM | #9 |
2JZ-GTE
3005
Rep 3,986
