09-19-2021, 11:38 AM | #23 | |
Rep 3,752
On the side note , try using all the above method |
Wires1644.00 |
09-19-2021, 04:14 PM | #25 |
Rep 1,641
There is…if you have the power port for cell phone chargers, etc. I have the power seat ejector button there. But for the same reason as noted above I am worried about a coffee spill. Don't want to accidentally launch the misses.
09-19-2021, 04:37 PM | #26 |
Rep 844
I had this same thing happen to me. I had to pull the fuse and use a flathead screwdriver and needle nose pliers to get it out as the fit is super tight.
2019 x5 50i - current
2016 340i THP stage 2 - gone but not forgotten. |
VP_5675.50 |
09-19-2021, 04:55 PM | #27 | |
Rep 16,054
I'd get that penny out by putting a dab of RTV on a length of 1/2" dowel, pushing the dowel against the penny, leaving it overnight. Pull the dowel and penny out the next morning. Then put a cap on the outlet. |
09-19-2021, 05:02 PM | #28 | |
Rep 4,870
09-20-2021, 09:26 AM | #30 |
Rep 1,641
09-20-2021, 05:57 PM | #32 |
Rep 141
Drives: 2016 BMW 340i RWD
I was able to get it out today. I purchased a bag of wooden kabob skewers from the grocery store for $3. The one penny turned out to be 3 pennies, and still not sure how that happened. The last penny was really lodged in there. I went through 6 skewers to get them all out. Now it appears the fuse is blown. I haven't used the car lighter in about a year. I'll replace the fuse later this week. For now, I put a black plastic cap cover on it. I really appreciate everyone's advice and comments with this.
2016 BMW 340i | DINAN Lowering Springs | DINAN Stage 1 v1 Tune | DINAN Mid Pipe | DINAN CAI | DINAN Turbo Inlet Pipe | Koni Sport Dampers | BMS 12/15 mm Spacers | Active Autowerke Exhaust
bavarianride1503.50 Wires1644.00 |
09-21-2021, 01:47 PM | #35 |
Rep 943
Drives: F30 328i Msport
I have two ways that have universally worked for me whenever i run into a similar issue.
1- If you have an air compressor\air gun, give it a few blasts, it will either blow the coin out or put it on its side so you can grab it with pliers. 2- Detailing clay is super sticky and hard, put some on the tip of a screwdriver or wooden skewer or whatever you have on hand, it'll stick to the coin easily and you can pull it out. |
CajunBMW1288.50 |
10-14-2021, 03:50 AM | #39 |
Rep 474
Try using a vacuum with a hose attachment if you haven't been able to yet. Lmk how it goes.
J. D. Cordier
10-14-2021, 08:58 AM | #41 |
Rep 923
I'm sure your fuse blew...when I got mine, I had a penny in it too.
It's one in the trunk...some weird graphic on the car giving you no idea what it's for--it's one of those fuses. Last one on the right column in this pic. #66, 69, or 162 https://f30.bimmerpost.com/forums/sh...&postcount=112
11-03-2021, 06:51 AM | #44 |
Rep 2,015
