03-17-2015, 06:56 AM | #1 |
BMW Fanatic
331
Rep 1,076
Possible to retrofit the garage home link mirror?
Checked the forum, no posts when I searched "Home Link" so is this possible or not?
18 BMW M2 | ER DP | ER CP | Wagner Evo 2 Comp Intercooler | Aquamist HFS4 | BM3 | CSF Oil Cooler | AFE Drop-in Filter | Bilstein B16 PSS10 |
03-17-2015, 11:54 AM | #2 | |
Rep 1,527
04-07-2015, 02:53 AM | #3 | ||
BMW Fanatic
331
Rep 1,076
04-07-2015, 02:11 PM | #4 | |
Rep 713
When I get home I'll check to see what mirror I had (sitting in the garage) and let you know tomorrow.
04-16-2015, 11:01 AM | #5 |
Rep 713
Double checked and the mirror that came with my car was the standard auto-dimming and replaced it with PN 51169285514 and was plug and play for me.
04-22-2015, 10:53 PM | #6 | |
BMW Fanatic
331
Rep 1,076
04-23-2015, 01:41 AM | #7 |
Rep 931
Retrofitted on my car.
No problem
BMW F82 M4 Black MHD CS Map - GTS DKG - Navi -Performance Brake RSL1 Pads - USB - DivX-DVD - Bluetooth - VoiceControl - Connect - Apps - Online - H&K - TrafficInfo - SpLimInfo - WhiteMerino- PDC - Cam - Adaptive Led - Antitheft - CP Steering- Performance ST - Adaptive CP Setup - GarageDoorOpen - Pipercross - Stock Exhaust - Mdrivers Pack - 437M Wheels
04-25-2015, 09:11 AM | #8 |
BMW Fanatic
331
Rep 1,076
Just a quick question, under what section did you find the mirror on realoem? I searched for it for a solid 45 minutes and was only able to find the alarm light and irrelevant stuff.
04-25-2015, 09:47 AM | #9 | |
Rep 92
http://www.etk.cc/bmw/EN/search/sele...CE/51/51_7914/ I also retrofitted the GTO mirror in my F31. Was just plug & play. Greetings Radair |
12-09-2018, 03:24 PM | #10 | |
Rep 277
D90D25 interior rear-view mirror: oncorrect variant fitted and D90D2D garage door opener: unexpected LIN-slave So for those interessted this does need CODING, Only there is no one who knows what. |
12-11-2018, 09:47 AM | #11 | |
Rep 64
I got the mirror on eBay for 50USD used, but fully functional and in mint condition.
for King & Country
12-11-2018, 09:52 AM | #12 |
Rep 64
Here is another thread on this.
https://f30.bimmerpost.com/forums/sh....php?t=1548828
for King & Country
12-11-2018, 01:42 PM | #13 | |
Rep 277
05-18-2021, 12:02 PM | #14 | |
Rep 6
Hello guys, I know that the topic is old,, but I registered here only for this answer (maybe not?). I spent few hours finding any solution to delete the errors: D90D25 and D90D2D. I have an F15, but it should be a similar to F30 and other BMWs. I have found two variable in BDC which must be changed to FF. BDC BODY 3120 PfInternalMirror PF_INMI_LIN_VAR -> set to nicht_aktiv (werte=FF) PF_UGDO_LIN_VAR -> set to nicht_aktiv (werte=FF) That's all - Now the BDC_BODY module will not check 'the mirror' and 'the universal gate door opening' variants anymore. The errors disappeared. Enjoy! |
09-25-2021, 12:45 AM | #15 |
Rep 6
Hi guys,
Sorry for replaying to a post so old :-) I need to retrofit a mirror with Homelink into a F31 EU ( I live in Italy). Can anyone remember the exact code to be retrofitted if the mirror comes form USA? I need that Homelink can operate with 433mhz frequenze. Thanks in advance, Andrea |
12-05-2021, 01:02 PM | #17 | |
Rep 17
BDC BODY - >3120 PfInternalMirror Note - UGDO stands for Universal Garage Door Opener PF_INMI_LIN_VAR - ISP_G_EC_DWA_UGDO_ECE_IR // the value here should correspond to the retrofitted mirror. Mine is electro cromatic (EC) with alarm LED (DWA), homelink (UGDO) and complies with the Europen frequencies (ECE) UGDO - aktiv // this is self explanatory UGDO_COUNTRY - Rest of europe // the value here should correspond to the area where you live. If your country is in the list go ahead and select it, otherwise select more generic area (like in my case) PF_UGDO_LIN_VAR - ece // the value specifies the region (ECE or US) |
05-23-2022, 01:32 PM | #18 | |
Rep 243
The ISP_G_EC_DWA_UGDO_ECE_IR option is not available for me. Do you have the “werte” code for me? |
06-13-2022, 10:13 AM | #19 |
Rep 17
11-11-2022, 04:40 PM | #20 |
Rep 1
F30 frameless mirror with garage opener
Hi guys,
Check this link. I managed to get this mirror with 3 buttons delivered to UK and fitted. I will test with my new liftmaster myq door opener and update. But mirror looks amazing! https://www.schmiedmann.co.uk/en/bmw...1-16-2-471-107 Rish |
