07-30-2015, 07:19 AM | #1145 | |
Rep 1,894
08-03-2015, 08:09 AM | #1146 |
Rep 18
After NBT retrofit to a F20, the little wheel at the steering wheel doesn't work anymore. It used to change radio station or song. any idea why is this or how can it be coded someway?
Furthermore, I do not have a BT mic. Can I use a mic, other than BMW's, as I have trouble installing it somewere conveniently? |
08-03-2015, 08:55 AM | #1147 | |
Rep 1,894
You need to code the following if you have the basic KOMBI: Info: Option to allow watch next track on Basic Kombi with a retrofitted NBT HU_NBT [3000] BASIS_KOMBI_MMI_LIST New Value: aktiv Default Value: nicht_aktiv |
08-03-2015, 09:58 AM | #1148 |
Rep 18
No, I do not have it.
I think that this was at aktiv, but I will check again. |
08-04-2015, 06:50 AM | #1149 | |
Rep 18
Thanks. Any idea on below? |
08-04-2015, 10:08 AM | #1150 |
Rep 1,894
To install the official microphone; cut a hole in the roof liner. Ask a member to measure the size of the hole. The Mic is attached to the cover which just clicks into the hole. Run 2 electrical wires from the mic down to the NBT qualock connector as follows:
Mic 1: Pin 17 +ve Pin 22 -ve Mic: 2 Pin 18 +ve Pin 19 -ve If you initially hear nothing try switching the wires into the Mic. |
08-07-2015, 03:21 AM | #1151 | |
Rep 18
08-07-2015, 03:22 AM | #1152 | |
Rep 18
08-13-2015, 12:34 PM | #1153 |
Rep 15
DONE!
I have retrofitted my f20, now bt with freehands, voice control, gps. I bought a mic and today I installed it and works perfect. Waiting for the usb' cable. Doesn't work the aux, does anyone know why? It's the only part the car came with (hu_entry with aux, no bt). And the office doesn't appears at main menu, shawn could you pm with codes please? Another one question, is there any guide to upgrade the firmware version? Thank you everybody who write and solve ours problems! You are great! |
08-13-2015, 03:01 PM | #1154 | |
Rep 1,894
If your F20 came with the combox then it'll be routed to that. Personally I wouldn't bother attempting to fix it. In rgds to Office, you'll need to remove 6NH and replace with 6NS in your VO. If you want to upgrade the NBT firmware then you'll need to a constant external power supply as you can't upgrade the NBT firmware whilst the car is switched on. Upgrade is done using esys. Search the forum for instructions. |
10-12-2015, 10:25 AM | #1155 |
Rep 3
Hi all,
I have read this thread long long time ago and now I am deciding to retrofit my F20 from HU_ENTRY with Combox and basic KOMBI to HU_NBT. I am new to do the retrofit and I got a few stupid questions, 1)I am wondering where is the MOST cable originally connected to the combox? 2)Should I unplug the MOST cable in the combox after installing the NBT? any error if i do so? 3)Does anyone got a wiring diagram regarding the MOST cable connection among NBT, 6WA, ZGM? 4)Since I may also retrofit a 6WA kombi, i am wondering if I can use the original cable connector from the basic kombi Thanks for your help in advance : ) |
10-12-2015, 05:51 PM | #1156 |
Rep 307
Since my install everything has been good, cept for a couple of times when using the navigation the GPS location drifts maybe 50 yards from the road i'm on which sometimes throws the navigation out, then after 5 mins its back to normal
So the question is where have you guys installed your GPS aerials? mines on the bar under the 8.8" screen (under dash) I've toyed with the idea of running it up to the roof (near interior light?) just wondering how big a job that would be? Thanks |
10-13-2015, 11:09 AM | #1157 | |
Registered user
78
Rep 422
Drives: G05 3.0d MSport / F23
606 on Entry Nav F23
Thanks in advance Simon
2019 G05 3.0d MSport in Artic Grey/ Black 2015 F15 3.0d MSport/ 2014 F15 3.0d MSport, Carbon Black with Ivory White/ Black interior. 2015 f23 2 series convertible in Glacier Silver / Black. 2010 F07 5GT SE Sapphire Black with Ivory White/black interior
10-13-2015, 12:21 PM | #1158 | |
Rep 1,894
Send a message to shawnsheridan he might have a contact for importing the FSC code. I warn you the HU_ENTRYNAV FSC codes are DF based, which the current freebie FSC generators don't support. They only support 1B (CIC) and DE (NBT). |
10-13-2015, 12:33 PM | #1159 | |
Rep 1,894
10-13-2015, 04:30 PM | #1160 | |
Registered user
78
Rep 422
Thanks again Simon
10-13-2015, 04:37 PM | #1161 | |
Rep 1,894
1)I am wondering where is the MOST cable originally connected to the combox? The MOST cable connects into the COMBOX, you can't miss it. When retrofitting you want to completely disable it because the NBT has a built in combox. 2)Should I unplug the MOST cable in the combox after installing the NBT? any error if i do so? You need to remove the MOST cable from the combox and close the loop by attaching a terminating MOST Loop. Also you'll need to move the MOST cable from the quadlok and into the emulator quadlok. 3)Does anyone got a wiring diagram regarding the MOST cable connection among NBT, 6WA, ZGM? See above. 4)Since I may also retrofit a 6WA kombi, i am wondering if I can use the original cable connector from the basic combo Sorry had the 6WA as standard. Heard the retrofit is quite involved. |
10-13-2015, 08:09 PM | #1162 | |
Rep 3
10-14-2015, 06:42 AM | #1163 | |
Rep 263
There are 2 options as I learned here: 1. Like speuk, trying to enable nav function in HU_Entrynav. +: HU remains original incl. integrated combox with service data. -: Is there a gps antenna plug? FSCīs, map, etc. available? Using emulator wouldnīt be a problem. 2. Buying new NBT Evo HU. What happens with integrated combox and service data? Installation would be almost plug&play? If I have a brandnew HU, is it normally completely empty and will Iīll need FSCīs? Could I use FSCīs from another car - with emulator? The question in case of such retrofits is also what can BMW see via combox communication (Teleservices etc.)? |
10-14-2015, 10:45 AM | #1165 | |
Rep 1,894
+: HU remains original incl. integrated combox with service data. -: Is there a gps antenna plug? FSCīs, map, etc. available? Using emulator wouldnīt be a problem. Unless you can get an FSC code generated for your car's VIN you will need an emulator. 2. Buying new NBT Evo HU. What happens with integrated combox and service data? Installation would be almost plug&play? If I have a brandnew HU, is it normally completely empty and will Iīll need FSCīs? Could I use FSCīs from another car - with emulator? - The combox is built into the NBT. What do you mean by service data? - If your USB connects directly into the headunit, then it's 90% plug&play. You won't get the handwritting feature to work without adding the module. Everything is just coding and plugging into the back e.g. GPS Antenna. - Don't get a brand new head unit, it'll cost a fortune and without the FSC codes it's an expensive stereo without NAV. Get one off ebay and don't forget the emulator to use the donor FSC codes. If possible get one with the 6NR (BMW Apps) FSC codes, unfortunately most sellers have no idea if the code is there or ask them for the donor VIN and check online for the original build spec. |
10-16-2015, 05:06 AM | #1166 |
Rep 263
Thanks kitster!
Iīm a little bit careful with the retrofit as itīs a brandnew car… One of my main points is this built-in combox and the SIM card. What happens with that if I install a new HU NBT? As the new HU has a different SIM card, how does it match my car? Will Intelligent Emergeny Call (6AC) and Teleservices (6AE) still work? This is the factory equipment I have. With service data I meant the maintenance intervals (oil change etc.). Are these normally stored in the Kombi and then transferred to HU (Entrynav or NBT) and its built-in combox? What happens if I have a new HU? Iīm still waiting for my emulator, but maybe Iīll already install NBT. It should work, but only navigation will be inactive (grey), right? Then I could also check FSC codes etc. In the unlucky case there are no FSCs, I could still inject some from another car, if I can get some.., right? |
