BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > 2012-2019 BMW 3 and 4-Series Forums > Regional Forums > UK > P115d fault code
      04-13-2016, 01:26 PM   #1
mike-tomo
mike-tomo's Avatar
71
Drives: F30 320d + e90 318d
P115d fault code
Alright guys so I've had my 320d 2 weeks now n it's came up with engine management light, and car running weird in lower speeds ( hesitation around 30-45 mph around 3rd n 4th gear, I plugged it in got the p115d code to which I replaced the maf sensor with new one and it's still having the same problems lights back on and the engine feels hesitant again at certain speeds 😕 Any advice guys ? Anyone had this ?
      04-13-2016, 04:04 PM   #2
teaston
Drives: X3 M40d
Originally Posted by mike-tomo View Post
Alright guys so I've had my 320d 2 weeks now n it's came up with engine management light, and car running weird in lower speeds ( hesitation around 30-45 mph around 3rd n 4th gear, I plugged it in got the p115d code to which I replaced the mad sensor with new one and it's still having the same problems lights back on and the engine feels hesitant again at certain speeds 😕 Any advice guys ? Anyone had this ?
Sorry I can't help, but what the hell is the mad sensor??
      04-13-2016, 04:20 PM   #3
SteveChester
SteveChester's Avatar
Drives: F82 M4
2014 BMW F82 M4  [0.00]
Maf
Steve Roberts UK
F82 M4
I'm running the 2024 London Marathon for the British Forces Foundation - https://www.justgiving.com/fundraising/sr5/
      04-13-2016, 04:31 PM   #4
Kal101
Kal101's Avatar
Drives: 335xd Msport +
Mutually assured destruction sensor - lets you know when the nukes are coming.
      04-13-2016, 04:32 PM   #5
teaston
Drives: X3 M40d
Ah thanks, glad you cleared that up!
      04-13-2016, 05:02 PM   #6
robbiep
Drives: VW e-Golf !
So is it a 320d, or a 318d, like your profile says ?
More information needed. What age is the car, for example ?
      04-13-2016, 05:06 PM   #7
mike-tomo
mike-tomo's Avatar
71
Sorry that's my old e90 it's a f30 2012 320d efficient dynamics 90.000 on clock
      04-14-2016, 12:52 AM   #8
RobUK
RobUK's Avatar
Drives: 340i MPPSK
Yep, computer says - P115D Mass air flow (MAF) sensor signal offset. Leaky hose?
Life is a state of mind
      04-14-2016, 02:59 AM   #9
robbiep
Drives: VW e-Golf !
Oh, and if you've only had it 2 weeks, then how was it bought ?
Private buy : you're on your own
Auction : you're on your own
Retail sale from a dealer : take it back there for them to fix, and look up "consumer rights act"
      04-14-2016, 03:33 AM   #10
snipnoob86
Drives: 335D Saloon
its a maf code but it could mean an issue before or after the maf, the maf talks to the lambdas and vice versa. ill bet money on it being either a blocked air filter or an air leak either before or after the maf. also check your replacment part, was it used? and is it the correct part * sillyish i know but happens *
check the hoses etc and listen for a hiss. check the maf connector for a greenish corrosion buildup, clean using electric contact spray, the maf sensor itself can be cleaned with some success also with the same spray gently on the thin wire .
if the part you replaced it with was new and fitted properly your issue isnt maf related but air intake related
edit: if you cant diagnose the issue yourself your car will soon throw bank codes aswell, too lean, too rich etc etc. so if you are unable to find a fix yourself get it in the garage you will save yourself a huge headache and alot of money
JLR19691882.00
      04-14-2016, 04:49 AM   #11
mike-tomo
mike-tomo's Avatar
71
Thanks alot for all your help guys been tossing and turning all night I bought the car from a dealer, I have since told him the problem and he has booked me in with a BMW specialist local to me and paid for diagnosing it, I was hoping it would be just a faulty maf, but I think it's more likely to be a vacuum leak it's just trying to locate it, is going to be the headache 😩 The maf was out of a 2011 f10 520d which hasn't shown any faults however maybe that maf sensor was faulty aswell, it's booked in for Monday so fingers crossed they find either a leak or what is really going on, once again thanks for your opinions guys appreciate it 👍
      04-18-2016, 08:44 AM   #12
mike-tomo
mike-tomo's Avatar
71
Garage rang me up today claims it is down to the egr valve time to replace hopefully this fixes the issue 👍
      04-18-2016, 02:50 PM   #13
stefan4
Drives: 340i on order
Diesels and the fecking egr, seems shockingly common. Fingers crossed its sorted !
      05-19-2016, 03:50 AM   #14
mike-tomo
mike-tomo's Avatar
71
The plot thickens I'm afraid guys need some advice
So the garage replaced the egr ( under warranty)
Problem persisted
Done a check came up with back pressure sensor or fault
Replaced that
Problem persisted
Done another check and the p115d code was the maf sensor
Replaced that
Problem persisted
I've now rang the garage n told them the light still on and I'm not happy, waiting for boss to call me back don't really know where to go from here smoke test? To check for caught leaks?
I can't hear any vacuum leaks to be honest I'd thought I'd hear a leak when accelerating but I suppose if it's small? I don't know, any clues folks?
      05-19-2016, 04:22 AM   #15
KM79
KM79's Avatar
Scotland
140
Drives: 2017 335D Msport Saloon
Get it looked at by a dealer,with correct Bmw diagnosis system and not someone who's just throwing parts at it hoping for the best.
      05-19-2016, 05:47 AM   #16
mike-tomo
mike-tomo's Avatar
71
I know I'm thinking that but the Indy has been paid a lot of money so I sort of think it's his responsibility to sort the car
      05-19-2016, 07:35 AM   #17
KM79
KM79's Avatar
Scotland
140
Ok well hope he sorts for you then but on a dealer Ista system the fault would be narrowed down very quickly.It is extremely good.
      05-19-2016, 09:33 AM   #18
snipnoob86
Drives: 335D Saloon
fuel pump??? or clogged filter....
      09-06-2016, 09:44 AM   #19
danny_brac
Drives: F30 320d ed
Hi is ur problem sorted now? My engine light cane on, plugged in my obd reader and got the same code. Booked dealer 2 weeks after. Is it safe to drive like this?
      05-17-2018, 03:42 AM   #20
craigbeal
Drives: BMW F31 330D
Did you get to the bottom of this. Have the same problem with my 330d as yours by the sounds of things. Replaced the MAF and still an issue
      01-10-2019, 07:02 AM   #21
partymartyy
partymartyy's Avatar
Drives: 11 535xi
My 2011 535xi has codes p115d, p112f, p306d. Just had the fuel pump recall taken care of, the codes are still showing. Hesitant if I should buy a new MAF sensor... I thought taking care of the fuel pump recall would remove the engine light but no success
      02-21-2019, 03:26 PM   #22
wabj
Netherlands
Drives: E39 325TDS ; F31 320d EDE
this code means possibly something else...
see this one to start with...
https://www.autocodes.com/p115d.html
