BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > N20, N26, B46, B48 Turbo Engine / Drivetrain / Exhaust Modifications > Limp Mode
      07-27-2021, 11:58 PM   #1
torynmorgan
Drives: BMW N20 F30
Limp Mode
My 2013 328i has been in limp mode since Sunday, the 27th.
It occurred after hard accelerating up a hill to pass someone.
On map 2 jb4 with FBO if that matters.
Two files with codes have been attached, AFR too lean has always been there as well as the exhaust flap one and catless downpipe one. The codes seem to change every time i scan the car and sometimes none show up at all except the exchaust flapper one.
I am at a complete loss as to what the problem could be and am just looking for some guidance. I am not really sure what information i need to provide so if there’s anything else i should add, please let me know & thank you.
Also, I apologize for horrid formatting as this is my first time using the forum.
      07-28-2021, 11:34 AM   #2
Rockinryan2424
Drives: Bmw f30 328xi m sport
I know you can't really drive it but clear it run it and see what comes back, low oil pressure one is scary
-Ryan H
      07-28-2021, 10:39 PM   #3
Luverse
Luverse's Avatar
Indonesia
176
Drives: BMW F30
low oil pressure is something needs to be fix ASAP
it can lead to engine seizure
Instagram: nightfall.f30
      07-29-2021, 04:24 PM   #4
jtalweezy
Drives: 2017 BMW 330i xdrive (B46)
Oil pressure too low. Could be the catalyst for all other codes as the ECU shuts down other systems in the car. (as a non-doctor would say) Id get that looked at.
2017 BMW 330i xdrive M-Sport Estoril Blue - B46 w/ ER Catless DP, ER Chargepipe, FTP Intake Charge Pipe, BMS Cone Intake, BMS OilCC, Bootmod3 Stage 2 OTS 93 octane (AGG Burble), FI Exhaust Suite with Secondary Cat Delete, xHP Stage 3 OTS Transmission tune
