10-21-2018, 11:17 AM | #1 |
Rep 1,045
BMW 428i (N20) coolant change interval ?
Ok, now that I got the engine oil done and sorted, I'm wondering what's the coolant flush interval for my 2015 428i (N20) ? I googled and searched, and came up with nothing again. owners manual mentions nothing either, my last E92 335i had "lifetime" coolant, but after 7 years, I can see a bit of rust in the reservoir already. Anyone have info or experience on this ? My mechanic friend says it's 10 years life for the blue BMW OEM coolant, they reduced it to 5 years now to increase coolant sales and I shouldn't worry about it (my car is still around 31,000 km / 19,000 miles). I use the car for daily to the office at 9km (6 miles) away, I don't race or drive it hard, mostly in ECO PRO mode. I like to hear you guys opinion on this, much thanks guys !
10-21-2018, 02:01 PM | #2 | |
Rep 387
I will look in my Bentley manual later on tonight when I get home and see if they specify an interval of any kind, but I believe BMW recommends every 4 years; 3 years for M cars. Last edited by IraHayes; 10-21-2018 at 05:19 PM.. |
10-21-2018, 03:16 PM | #4 |
Rep 5,089
There is no written coolant change interval from BMW(not in service and warranty manual). SAs usually say 100k miles for BMW blue coolant.
10-21-2018, 03:54 PM | #5 |
Rep 1,045
I read somewhere theres a coolant tester stick kit you can buy to test the coolant quality, is there such a thing? BMW sure doesn't make it easy for us to do our own maintenance on the cars.
Mods: Dinan Tuned, Intake, Catless DP
10-21-2018, 03:55 PM | #6 | ||
Rep 91
Drives: White 14' F32
10-21-2018, 08:26 PM | #8 |
Rep 1,045
dude, not sure if you even read what I wrote, that was my last E92 335i, that car is long sold
10-21-2018, 10:05 PM | #9 |
Rep 16,079
Sorry, it didn't occur to me that you were writing about two different cars, let alone that one of them you don't even have anymore. Back when I used to keep cars more than 6 or 7 years I'd change mine at 60,000 miles or when I saw it had rust or dirt in it, whichever came first.
10-21-2018, 11:06 PM | #10 |
Rep 387
Well, according to the Bentley manual, “BMW specifies the engine coolant, manual transmission fluid, differential fluid and transfer case fluid are lifetime fluids.” I think we all know better than to listen to that nonsense.
BMW TIS states four years for standard cars, three for M on coolant system servicing. This is probably a more realistic interval to follow. Last edited by IraHayes; 10-21-2018 at 11:28 PM.. |
10-21-2018, 11:16 PM | #11 |
Rep 1,045
I see, thanks, the lifetime is definitely BS. But 4 years seems quite short too, I mean Hyundai even says their coolant is good for 10 years and they have way longer factory warranty than BMW to take the risk of saying that. I guess just like the air filter, I just have to keep an eye on it at every engine oil change. I'll probably do the coolant flush around 6 or 7 year mark.
10-22-2018, 12:46 AM | #12 |
Rep 5,089
Mine was changed in 6 years. The coolant color cue turned from greenish blue to pale light blue. The freeze/boil points are the same, but the pH dropped from 8.5 to 7(neutral), so my coolant's anti-corrosion property is wearing out.
10-22-2018, 10:52 AM | #14 | |
Rep 5,089
FYI there was a thermostat recall@32k miles, and the coolant was supposed to be flushed. Unfortunately BMWNA was too cheap to pay for coolant flush, and the SIB instructed tech to reuse old coolant, plus 1L of topoff, or else my coolant should be still tip-top shape@52k. |
10-22-2018, 10:56 AM | #15 | |
Rep 5,089
https://www.amazon.com/Cool-Trak-311...s=coolant+test Also this tool can quickly check boil/freeze, plus the color cue of the coolant. https://www.amazon.com/ABN-Deluxe-An...ant+hydrometer Last edited by bavarianride; 10-22-2018 at 11:56 AM.. |
10-22-2018, 11:58 AM | #16 | |
Rep 1,045
10-22-2018, 12:05 PM | #17 | |
Rep 5,089
